Old 07-27-2013, 07:16 AM   #15
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
One checks the TW scale (SHERLINE) against the values from a segmented weight scale.
1] The TV, solo
2] The combined rig, WD not applied
The distance from hitch ball to trailer axle center is the total length from which one deducts the percentage distance from hitch ball to jack.
"Weight ratings" are as subject to marketing (profit) as to any engineering. One does not exceed tire or axle ratings is about it. And TW can be shifted among it's three points of contact (TV steer and drive axle, and TT axles) to accommodate most situations. Not all WD distribution schemes are the same, and are often dependent on vehicle type.
Contact Andrew Thomson at CAN AM RV for advice about a particular vehicle, or a range of vehicles that might work given climate, terrain, trailer spec and expected use. No perfect TV out there, all have drawbacks. Focusing on "weight ratings" clouds the fact that the usual "solution" -- a pickp truck -- has not only higher operational costs than many other types, but is prone to handling & braking deficiencies that, loaded or empty, have a higher risk of injury for any miles travelled.
As to warranty I sure wouldn't worry over it. The trucks I've used for commercial service under conditions FAR in excess of ratings were serviced as any still under warranty. Do an online search if concerned, enthusiast webistes tend to report even the ridiculous, not just the useful.
A truck can be decent enough for a fulltimer (the tendency to carry too much stuff), but for the vacationer using the TT 30-days/5k miles annually, it may not be at all suitable for solo duties. Keep both uses in mind.
Old 07-27-2013, 04:04 PM   #16
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
1] The TV, solo
Wise words. Thanks Slowmover.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 07-27-2013, 05:33 PM   #17
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Going back to the five tire pad scale scenario I posted earlier where all four wheels are on weight pads, if the jack stand is on the weight pad or some contraption supporting the ball socket is on the weight pad, and discounting the weight of that support, the total weight of the trailer will be the same.
Old 08-03-2013, 12:40 PM   #18
JFScheck's Avatar
Rockville , Maryland
Images: 33
Myth alert - not much tongue weight is transferred back to the trailers axels, let alone the silly 1/3 that is often claimed (I bet I even have a 4-5 year old post from when I heard that).
This is proven via scale weights and Sean will even confirm at ProPride.
Scales with and without weight distribution enabled with the TV and trailer loaded up for travel is the only true way to know for sure....
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 08-04-2013, 08:44 AM   #19
switz's Avatar
2014 31' Classic
Images: 8
Sort of like the old adage, "only the hair dresser knows the color for sure..."
Old 08-04-2013, 09:22 AM   #20
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
This has probably been posted before, but some may find it helpful.
Trailer Towing Guides | Trailer Life Magazine
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 08-12-2013, 07:39 AM   #21
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
The other big issue IMHO on SUV's vs trucks, is the size and rating of the tires. Alot of SUV's only allow for a C rated or P rated tire, while a 3/4 ton truck can use E rated tires. Even 1/2 tons have a hard time finding an E rated but generally can find D rated. As far as gas rig vs diesel, it is still more of "I want a diesel" vs "I need a diesel", and modern gas rigs have consistantly shown they can go as many miles as a diesel without all of the fuel and maintenance hassles, not to mention the initial cost factors.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
