Old 07-24-2016, 02:37 PM   #1
North Falmouth , Massachusetts
Tow Vehicle
Hi, newbie here. Planning to purchase a 30' Serenity. Will a F150 be enough to safely tow, or would we need a 250.
Looking forward to feedback
Ernie
Big Can Man is offline   Reply With Quote
Old 07-24-2016, 02:42 PM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I can't answer your question (I have a 25FB and tow it with a RAM 1500). Sorry!
But I do want to welcome you to the forum.
Old 07-24-2016, 03:35 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ernie
What are the max towing specs for the F150 you have in mind? What is the weight and tongue weight of the 30 footer?
MICHAEL
Old 07-24-2016, 03:48 PM   #4
Sioux Falls , South Dakota
According to the airstream.com site, the 30' Serenity has tongue weight of 880 pounds, with a gross weight of 8800 pounds. From what I've read here, that tongue weight should be taken with a large grain of salt. Just adding a hitch would likely move that up to around 1000 pounds. Yes, a weight-distributing hitch will move some of that weight around, but I'm guessing that an F150 will be pretty close to the limit just with the trailer. Then add in all the stuff that will ride in the bed of the pickup and you will likely be overweight somewhere. Get the F250 and be safe.
I'm looking for a 34' which has a GW of 9800 pounds. I'm planning on an F250 for the tow vehicle.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 07-24-2016, 03:53 PM   #5
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
For safety you'll need a F1050. Get the dual diesel engine option. You'll also need dualies up front with triples in the rear for safety and traction. To get adequate payload double rear triples are your best bet. Order your truck for no less than 50,000 lbs of payload. You'll appreciate that extra capacity and safety buffer.
Sure a F150 can work, but for safety of your family and others, the F1050 gives you that little extra bit of insurance.
kscherzi is offline   Reply With Quote
Old 07-24-2016, 03:57 PM   #6
Williker's Avatar
1992 25' Excella
Orange County , New York
Towing capacity for 2016 F150
http://www.ford.com/trucks/f150/specifications/towing/
Williker is offline   Reply With Quote
Old 07-24-2016, 04:00 PM   #7
Williker's Avatar
1992 25' Excella
Specs for F150. There are more than a few models that will tow your trailer.
Old 07-24-2016, 04:23 PM   #8
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
Tow Vehicle
I have a 30. I started with a half ton pickup and was just never completely comfortable. Even after upgrading to a ProPride hitch and LT tires. The half ton had enough power, but it felt like the trailer was pushing me around sometimes. I changed out my truck for a 3/4 ton and it tows much more comfortably in my opinion. Others tow a 30 with a 1/2 ton (or smaller) and seem happy, so it is really hard to say. Will a F150 tow it? Yes, it will tow it. Will you be happy with it? Only you can answer that question.
Echelon73 is offline   Reply With Quote
Old 07-24-2016, 05:19 PM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Troll
Old 07-24-2016, 05:37 PM   #10
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I would highly recommend an F250. The F150 might be fine pulling an empty 30' trailer, but once loaded with all of your "stuff", you'll appreciate the added capacity of the F250.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 07-24-2016, 05:41 PM   #11
Gainesville , Florida
Other than giving you more payload a three quarter ton with the same engine as a half ton is not necessary. Get the diesel in the three quarter ton, then you'll see the difference.
Old 07-24-2016, 05:48 PM   #12
PaulnGina's Avatar
Good Ol' , USA
There's something other than diesel??? 😀👍
PaulnGina
1987 Avion 34W
1987 Avion 34W
Old 07-24-2016, 05:59 PM   #13
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Do you plan on short trips, longer or really long. And pack light, heavy or tie stuff on the roof? Has to do with payload. Flatland only or Rockies calling your name. Hear the engine saying yup, can do or oh no not a grade again!
Know anybody that can take you for a demo ride, their rig, even that will give you a feel for the road.
I'm a 3/4 T fan, many are not.
Choose wisely but have fun.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-24-2016, 06:06 PM   #14
PaulnGina
1987 Avion 34W
Yup, you can get a three quarter ton with a gas engine, don't know why you would though.
Old 07-24-2016, 07:11 PM   #15
Ambot's Avatar
2016 28' Pendleton
Cybertron , Illinois
Start here http://www.airforums.com/forums/f238/towing-capability-basics-152877.html
Watch it on the f-250 depending on equipment the payload will vary wildly, at times just 100lb more than a f-150
Ambot is offline   Reply With Quote
Old 07-24-2016, 07:29 PM   #16
2005 30' Classic
Burlington , Ontario
This pretty much parallel's my experience.
I had a GMC Sierra 1500 gasser when we bought the AS - it was fine with our previous 27ft SOB (much lighter than our present AS).
I did tow with it for a while and in a pinch could have kept it, but I just felt it to be marginal. Switched to a Sierra 2500HD Diesel and much happier - for me it was the right move and I am glad I made the change. A much more relaxing experience no matter where we travel, and a better matched TV IMHO.
If you already have the 1500, why not give it a try?
Brian.
Old 07-24-2016, 07:48 PM   #17
1990 32' Excella
jonesboro , Arkansas
I also say go with the 2500. Just because some one goes with a smaller vehicle and gets away with it does not make it safe....... besides the wt handling issues you might get lucky and not damage your vehicle or you could by an expensive trans. Towing to a vehicles max capacity is never a good idea nor is it safe. Just looking at horse power and torque #'s do not tell the whole . Power curves are diff with every vehicle are diff. You can have a gas and a diesel with equal up and torque a new they will tow very differently. Good luck and be safe.
joel is offline   Reply With Quote
Old 07-25-2016, 04:53 PM   #18
Towing Vehicle
Thanks to all who replied.. I'm leaning toward a F250
Thanks again....
Ernie
Old 07-25-2016, 06:55 PM   #19
PaulnGina's Avatar
Good Ol' , USA
Thanks again....
Ernie
Keep us posted.
PaulnGina
1987 Avion 34W
1987 Avion 34W
Old 07-25-2016, 08:34 PM   #20
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Do you have an F150, tell us more so we can make a useful recommendation.
The modern half-tons coupled to Airstreams with modern weight distribution hitches are a very capable with a comfortable ride for you and your Airstream as your head to your destination, and a nice daily driver when you arrive or at home.
Doug and Cheryl
Tow Vehicle - Jeep Wrangler to tow sport 16 iamcrazy Tow Vehicles 22 04-10-2016 07:37 PM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
Can you tow a 31' with 12 a bhp tow vehicle? goatfarmer Member Introductions 6 06-30-2010 10:40 PM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
