Old 03-06-2014, 01:04 AM   #15
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
We tow our 25ft FB with an 08 GMC 6L 1500 with the Max Tow package.This gives us the heavier payload, 4.10 rear end and disc brakes all around. We previously towed our 08, 20ft Safari with it and to be honest was prepared to go up to a 2500 if I needed, but have found that the 25ft tows easier, is more stable . A half ton will be more than ample , just watch the payloads which had been mentioned before.
George
gandttimes is offline   Reply With Quote
Old 03-06-2014, 01:05 AM   #16
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Originally Posted by dkottum View Post
A question about gear in the back of the pickup for two retirees on an 8 month tour. What in the heck are you guys bringing that does not fit in the Airstream and takes a 3/4 ton truck to transport it?
We are out 6-7 months a year and don't take a generator or gas because we have solar power. In some areas you can't transport firewood around because of tree killing bugs. The bicycles are on the back of the Airstream. Never used 30 gallons of water the trailer tank holds before we could refill.
From reading here over the years it looks to me like weekenders and vacationers, as well as full-timers are more likely to transport large quantities of gear than than retirees on extended tours. And are less concerned about dealing with an oversized truck as a daily driver when not pulling, which is most of the time.
I'm sure everyone is different in this regard. Each Airstreamer has to look at their particular need and budget.
I don't know your name but I have to agree with you're assessment. On a few occasions I've been critical of others glamping habits as I tend to enjoy boon docking versus rv parks and in general like the solitude and freedom from others that camping brings me and wife. That said I'm also one to engage in long winded conversations with perfect strangers.
You make a great point about the amount of er.... stuff we drag along with us - a lot of which we don't need. Guilty as charged!
I remember my backpacking days... barely.... Two weeks and had it all on my back. And now - Airstream, and Crewcab PU loaded down. Why?.... I guess because I can.
You're right though, how much do you need? We generally wear half the clothes we bring, eat less than half the food we bring, but drink all the wine.... I guess we're doing something right?!
Mj: "I'm on the road again"
Markj55 is offline   Reply With Quote
Old 03-06-2014, 10:38 AM   #17
Ayr , Ontario
TinTin,
In my area I shop around on diesel using the app "GasBuddy". It works great and I can get diesel for the same or less than regular most of the time. There are also a couple of stations in my area, one has 10 cents off a liter once every month and other has 5 cents off if you use your AirMiles card. So between those 2 I do alright. But overall if I compare my diesel to my other car which only takes premium I'll take the diesel any day of the week. Overall the maintenance is less the millage is more and I get more miles on the vehicle. My "spare" care is a diesel and it has 440k on it now and it has never had any engine work. I'll change the glow plugs when they go and do the timing belt change every 100k. Other than that I change the oil every 12k. On my ML the oil change is every 18k.
Of course when you're travelling you have no choice but to pay what they have. But I still don't think I would give up the torque for a non diesel for towing.
gator.bigfoot is offline   Reply With Quote
Old 03-08-2014, 07:53 AM   #18
2016 27' International
Grand Rapids , Michigan
Thanks for all the information about what works and doesn't in the field. I was just looking at Chevy trucks yesterday and doing all the necessary calculations on paper about what might work. The sales person kept telling me this or that truck could pull 76,000 pounds, yes I mean thousand. At that point I knew he understood nothing about trucks, cars or anything else. The more research and number crunching I do, the more I understand.
We do plan to full time eventually. I enjoy reading all of the posting on this forum, even those about getting fuel with a RV. Going to the gas station with a 17 foot Egg camper is no big deal, but I always wondered how the big rigs do it.
Again, thanks for the input.
dorrph is offline   Reply With Quote
Old 03-08-2014, 08:32 AM   #19
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
I like to refer to the following page, as it clearly illustrates the dynamic relationship between towing capacity and load capacity. There may be other and better tools like this one. I'm not even advocating a particular solution for you, but I was shopping for a Ram truck at the time and found this helpful. The principles illustrated here likely apply, no matter what vehicle you choose to buy. Ram Trucks - Towing Capacity Chart
Have fun shopping!
Edit: A quickie search for "towing calculator" turned up a couple of other pages. I've not tried them yet, but they look promising. http://www.dodge.com/hostc/towing/basics/calculator.do
http://changingears.com/rv-sec-calc-...eight-tt.shtml
Rocinante is our 2014 International Signature 27FB
Old 03-08-2014, 08:55 AM   #20
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
For what it's worth, the towing specs on the 2014 GMCs:
1/2 tons (1500 series):
Tow rating: from 5900 - 11,500 lbs (depending upon configuration and equipment)
Max payload: from 1751 - 2108 lbs
3/4 tons (2500 HD series):
Tow rating: to 14,000 lbs for conventional trailering (more for fifth wheels)
Max payload: to 3760 lbs
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 03-08-2014, 09:55 AM   #21
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Seems like the 1/2 ton with 11,500# towing capacity and 2108# payload would be all any Airstreamer would ever need, and then some.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-08-2014, 01:19 PM   #22
1987 25' Sovereign
Oregon , Ohio
I have been looking at the F150 Eco boost for the last three years. Finally after talking to a dealer I learned that the 150 with all the options I needed for towing listed about $10,000 more than a F250 that had better ability to tow with only 1 to 2 mpg less when towing. So we sold our 2001 150 super crew with 80,000 on it for $10,000 and found a 2005 250 with 38,000 on it for $13,000. It has trailer tow and heavy haul packages, a 6.8 V10 and a 4.10 rear gear and is about $32,000 less than a new one with similar equipment. The 2005 250 gives me the same mpg as the 2001 150 when towing our 25 footer. $32,000 buys about 8500 gallons of gas, or about 85,000 to 90,000 miles of towing
msmcv51 is offline   Reply With Quote
Old 03-08-2014, 03:01 PM   #23
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
There are advantages/disadvantages to both. I'm a moderate, match the tow vehicle to the trailer coupled with the most effective hitch (ProPride/Hensley) to ensure stability.
We tow our 25' with a Ram Express 1500 5.7 gas, not expensive to buy or maintain giving us plenty of power, braking and decent gas economy while being easy to get around town when not towing.
I am new to the forum and we do not have an AS yet. But I do have a tow vehicle purchased in anticipation of buying a trailer. My truck is a RAM 1500 Crew Cab 4X4 Laramie with an eight speed tranny and a 3.55 rear. It was purchased with all the trailer towing options.
Based on your experience would towing a 25FB create any issues? As of now this is the size and type of AS we are considering. As always any thoughts are appreciated!
Old 03-08-2014, 03:38 PM   #24
1986 31' Sovereign
Miami , Florida
Your RAM should tow a 25 just fine. You will need to leave your bowling ball and Mosler safe collection at home, though.
Going is hardly ever a problem. Stopping, if your trailer brakes are properly adjusted and your brake controller dialed in, is seldom a problem. Payload is the limiting factor with a half ton.
My wife and I have been half-timing, traveling from Miami to Yellowstone every Spring for 5 months for five years now. Every year we have winnowed down the amount of "stuff" we carry and have actually gotten pretty lean so our old Nissan Titan does just fine (50000+ miles towing, 166000 overall).
Enjoy the journey,
Mike
Old 03-08-2014, 04:20 PM   #25
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Assuming your Ram has the Hemi 5.7 V8 engine, it will work very nicely. Always use tow/haul mode which keeps the transmission out of overdrive, and manually select the transmission speed that will match wind and grade conditions so that the engine does not continually down and up shift. You will notice no difference in fuel usage doing this. The truck and trailer have good brakes, but on steep descents keep your speed under control by manually shifting down as needed so you limit brake use.
As any vehicle it has a payload limit so keep that in mind when loading gear. We need and take very little that won't fit in the trailer.
We tried a couple of different weight distribution hitches but nothing comes close to the stability of the ProPride we now use. Worth the money.
Our Ram handles the 25' very well and I am sure you would have no problem with a 27' either. I doubt you would notice the difference.
Doug and Cheryl
Old 03-08-2014, 04:30 PM   #26
Rivet Slave
Rocinante's Avatar
Good advice, dkottum.
Meanwhile, according to the towing calculator link I posted above from Ram trucks, if your vehicle has a long bed and 2 passengers, it is capable of both a Payload of 1,089 lbs while Towing up to 7,311 lbs, assuming you max the payload on the slider. Compare the maximum weight of any trailer you might want to tow, as well as the likely tongue weight, to see whether it fits within those parameters.
Old 03-08-2014, 05:18 PM   #27
2014 25' Flying Cloud
Anna , Texas
As pointed out above, for the vehicles commonly used for towing you are more likely to exceed the payload capacity of the TV than the towing capacity. One of the surprising things is you might not add that much payload capacity going to a 3/4 ton, especially if you go with a diesel. Just as an example, a 2014 F150 SuperCrew 4x4 with the 3.5L EcoBoost engine has a curb weight of 5731 lbs, and a GVWR of 8200 lbs with the max payload package (according to the specs at ford.com). That gives you a payload capacity of about 2470 lbs. A 2014 F250 Crew Cab 4x4 with the 6.7L diesel has a curb weight of 7454 lbs, and a GVWR of 10,000, for a payload of about 2550. In practice your "empty" weight is likely to be higher than this...all the extras like step rails, etc. add up fast. I put my 2006 F250 on the scales a few years back and was stunned to see it over 8000 lbs with nothing but myself and my "driving around town" cargo. With the rest of the family and camping gear we would have been considerably heavier. I haven't weighed my new F250 yet, but I imagine it will be about the same.
kcollins is offline   Reply With Quote
Old 03-08-2014, 05:47 PM   #28
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
On our 2012 Dodge Ram 2500HD, the modifications after purchase added just under a thousand pounds to the empty weight. While the larger replacement fuel tank added 140 pounds in weight, the additional fuel capacity (56 vs 34 gallons) added another 176 pounds. The camper shell added 280 pounds, the running boards 60 pounds, the air suspension system that replaced all the steel springs added 100 pounds, front and rear Curt hitched added 120 pounds and undercoating and miscellaneous accessories added 280 pounds.
It all adds up.
Our first trip fully loaded with the wife and I plus two 2K Honda generators with 10 gallons of gasoline, spare 30 and 20 pound propane tanks, grill, power cords, chairs, etc in the truck plus the tongue weight found the truck 520 pounds over the door label GVW but 1,380 pounds under the axle and tire ratings which are the real concern. The trailer was at 6,960 pounds of the 7,300 pounds allowed. The total weight of the rig was 16,000 pounds out of the 20,000 pounds CGVW.
The new Classic model 30 trailer has a GVW of 10,000 pounds so I expect to see the CGVW approach or even exceed 19,000 pounds.
I kind of blew past the typical ˝ ton truck's ratings.
Do the scale homework with the TV to be sure it can handle the job. I have yet to see a sedan rated for a CGVW over 18,000 pounds.
Mercedes GL/ML as a tow vehicle SafariSS Tow Vehicles 93 04-09-2017 12:35 PM
Small Tow Vehicle Recommendations (considering XTerra) dhw Tow Vehicles 29 02-16-2014 06:01 AM
Van Conversion/Small Motorhome as tow vehicle? TG2500 Tow Vehicles 0 10-16-2011 06:07 PM
Tow Vehicle wiring - 2 days from first trip - please help!! ckbailey97 Tow Vehicles 16 09-17-2011 05:27 PM
Help a girl find a tow vehicle star kitty Tow Vehicles 58 08-14-2011 07:51 PM
