Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 06-08-2015, 07:13 PM   #1
Caffeinated's Avatar
2015 27' Flying Cloud
Newberg , Oregon
Tow mirror extensions?
OK, this is a lame question, but. Are the tow mirror extensions that cost over a hundred bucks on Amazon worth the price vs the forty dollar plastic ones?
Mike
Caffeinated is offline   Reply With Quote
Old 06-08-2015, 07:22 PM   #2
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I had good luck w/ the cheap suction cup mirrors for the first five trips, but now the mirrors don't stay very good anymore ! Going to have to re think the cheap ones! I'm prob going to buy the $100+ ones
Cochese is offline   Reply With Quote
Old 06-08-2015, 07:33 PM   #3
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
I got the JR mirrors and while a little pricey, can confirm that they worked well on a recent 2500 mile trip. Once the adjustment are set they clip on and off in seconds and hold the adjustment when reinstalled.
http://www.amazon.com/JR-Products-28...towing+mirrors
remphoto is offline   Reply With Quote
Old 06-08-2015, 08:33 PM   #4
2016 22' Sport
Sandpoint , Idaho
extn mirrors
We tried several others, and the JR made in England are the only ones worth having.
Yachthalo is offline   Reply With Quote
Old 06-08-2015, 09:44 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
These are without a doubt the best mirrors out of four brands that I have used,
Amazon.com: CIPA 11800 Ford F-150 Custom Towing Mirror - Pair: Automotive
Unfortunetly they are not available for the Jeep GC. I am using these instead. In my opinion not as good as the Cipa but close.,
https://www.amazon.com/gp/your-accou...712647-5485806
MICHAEL
Old 06-08-2015, 10:11 PM   #6
Newberg , Oregon
Thanks for the feedback. I just ordered the JRs to replace the older plastic slip ons that have a broken clip.
Mike
Old 06-08-2015, 10:16 PM   #7
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
http://m.costco.com/JR-Products-Aero...100103655.html
George
gandttimes is offline   Reply With Quote
Old 06-09-2015, 07:14 AM   #8
AWCHIEF's Avatar
Images: 33
Mike
Mike, do not know what you are have for a TV but my Milenco's that are sold in North America by JR were much more stable after I shortened the arms by 5 inches. That they unnecessarily extended out so far from the vehicle made me a bit nervous. I mount mine on the bottom lip of the OEM mirrors because there is not enough room at the top. At stops I always give the mounting screws a twist just in case they have loosened up.
MICHAEL
Old 06-10-2015, 07:40 PM   #9
gator.bigfoot's Avatar
KW , Ontario
The JR mirrors are very good mirrors. My only complaint is that the little rubber pad comes off sometimes. I once lost it and was scrambling to find it. After not finding it I subbed it out with a wide elastic. I did the job until I found it again. On another trip my son attached the mirror and I didn't double check it so it wasn't as tight as I would have liked. It was in for service that day and as I was leaving a powerful thunderstorm came up. Shortly thereafter the mirror flew off. I thought it was a goner, but it was actually completely unscathed.
gator.bigfoot is offline   Reply With Quote
Old 06-10-2015, 08:28 PM   #10
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
The best mirrors for towing that I have found are McKesh mirrors. I don't know if they are still made, but you can find them on Ebay. Easy on and off, no vibration, well made. Mine were made in 1989 and are still flawless.
My 2c, and worth every penny
DryFly is offline   Reply With Quote
Old 06-14-2015, 06:10 AM   #11
remphoto's Avatar
2015 16' Sport
These are very solid mirrors -- I owned a pair 20 years ago. A Google search indicates that they are still available new for around $150. The only negative I found back in the day was that the white webbing strap would get dirty and surface rust appeared on the chromed strap crank but these did not affect the beauty of their operation.
Old 06-14-2015, 06:54 AM   #12
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
I have a brand new (used once) pair of Milenco Aeros.... If anybody needs some let me know? I don't need them for my current truck but, they work great. Pm me if you're interested.
Mark,
The path not taken is the one I take.
Mj: "I'm on the road again"
Markj55 is offline   Reply With Quote
Old 06-14-2015, 07:15 AM   #13
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
Hensley sells McKesh mirrors
We bought our McKesh mirrors from Hensley back in 2008. They are still selling them here:
https://www.safetowingstore.com/McKe...rs-p/70007.htm
Once I learned how to tighten the screws at the bottom of each mirror to lock in the adjustment, they've been great. A little block of foam between the mounting strap and the vehicle door stops them from "singing."
Old 06-15-2015, 07:03 PM   #14
DryFly's Avatar
1972 Argosy 20
The "singing" noise is a problem if you can't tighten the wing nuts sufficiently - which at my advanced age is an issue. The foam block is a great idea - thanks!
Old 06-15-2015, 07:05 PM   #15
DryFly's Avatar
1972 Argosy 20
The "singing" noise comes from not being able to tighten the wing nuts adequately, which at my age can be an issue. The foam is a great and simple solution - thanks!
Old 06-15-2015, 07:17 PM   #16
1966 22' Safari
You're welcome. Know what you mean about the age thing...
Mirror extensions for 2014 Volkswagen Touareg kevinmlamb Tow Vehicles 4 06-22-2015 05:21 PM
Mercedes ML350 wing mirror extensions. jmpgino Tow Vehicles 5 06-06-2015 12:29 PM
Mirror Extensions - Milenco or Bust? SeaAirstream Tow Vehicles 11 06-04-2015 04:53 PM
Mirror extensions Markj55 Tow Vehicles 24 06-19-2013 02:24 PM
Mirror extensions recommendations Engie Towing, Tow Vehicles & Hitches 23 12-17-2012 04:11 AM
