Old 06-21-2015, 11:00 AM   #1
Ocala , Florida
Question tow Bambi 16' with Honda Odyssey?
The 3500 lb. towing limit for Honda Odyssey. Can you safely tow a Bambi 16? and which wiring harness is needed for TV?
dvbard is offline   Reply With Quote
Old 06-21-2015, 11:14 AM   #2
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
We have been successfully towing our Bambi 16 with a Pilot with factory tow package and 4,500 rating. I would think the Odyssey with its extra length, lower center of gravity and same drivetrain as the Pilot should be able to handle it.
remphoto is offline   Reply With Quote
Old 06-21-2015, 11:18 AM   #3
LongShot's Avatar
2015 19' Flying Cloud
Ashland , Kentucky
Images: 8
That's a loaded question; you'll get lots of options/opinions on here ranging from only trucks can tow, to get a diesel, to SUV's are perfectly fine. The Bambi 16 is fairly light and should be well within your towing limit at just under 2,900 pounds dry. The trailer's gross limit is 3,500 so you should be OK but now you're at your limit so watch what you carry. The best thing about the 16 is the relatively light tongue weight of 350 pounds - that shouldn't tax your set up too much. Of course you will absolutely need a class 4 hitch and a brake controller set up to connect the car to the trailer brakes. This is not as complex as it sounds, but it does need to be done properly. If you want to minimize as many towing issues as possible, I would also recommend a anti-sway/load leveling hitch set-up. (Budget about $1,200 extra dollars for the right hitch set-up and brake controller). Many out there that work quite well with the smaller set-ups. (I have a 19' and have gone overboard with the Husky Centerline, but then, that's one less thing I have to worry about!)
One Long Shot
Beastie - 19'FC
The Big Beast - GMC Yukon w/Max Tow Package
Held together with the Husky Centerline Hitch
LongShot is offline   Reply With Quote
Old 06-22-2015, 09:16 PM   #4
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
What you can do with a minivan if you set it up properly...
https://photos.google.com/album/AF1Q...W-ACGktrmti2IG
Andreas S, a member here, tows a triple axle Airstream with his Odyssey.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 06-23-2015, 11:36 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Absolutely.
See above post.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-23-2015, 12:40 PM   #6
2013 16' Sport
El Dorado , Arkansas
Tow Bambi 16 with Honda Odyssey
You surely can!
We have a 1999 Honda Odyssey and a 2013 Bambi 16 equipted with ----- Cub hitch.
Pulled it from El Dorado, Arkansas to Culver City, CA (L.A.)starting the 17th of December '14 and back on the first January.
Great weather and beautiful towing, back roads and Inter States going out.
Return was miserable weather (Ice, Sleet and Snow). On back roads and Inter States! Beautiful towing as well in advese conditions.
Total of 3700 miles and we deemed our trip a rip-roaring success.
Hook it up buddy, You will love it.
Pappa is offline   Reply With Quote
Old 06-23-2015, 01:07 PM   #7
m.hony's Avatar
2013 30' Classic
We met a lady at Jackson Center towing with a Lexus RX330. You've got more horsepower and a longer wheelbase and more payload.
Win, win, win!
TAC #MS-10
Airforums #70955
Old 06-23-2015, 01:44 PM   #8
Road Ruler's Avatar
Images: 38
No prob.... see post #4.
Old 06-23-2015, 08:16 PM   #9
andreasduess's Avatar
1984 34' International
Toronto , Ontario
As others have said, we tow a 1984 34' triple axle with our Honda Odyssey. We are within all payload, axle and tire ratings of the vehicle.
All details about our setup can be found in the link at the bottom of this post.
andreasduess is offline   Reply With Quote
Towing Bambi with Honda Odyssey 2011 TYPECK Tow Vehicles 14 03-20-2015 08:42 PM
Has anyone towed with a Honda Odyssey? m.hony Towing, Tow Vehicles & Hitches 93 12-02-2013 12:18 PM
towing Airstream 2012 16' sport with Honda Odyssey? lbg Tow Vehicles 8 03-11-2012 04:49 PM
Help! Will a 2000 Honda Odyssey tow a '75 Sovereign? aircreek Tow Vehicles 112 07-05-2008 06:26 PM
