Old 10-16-2013, 06:42 PM   #29
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Happy Days
Do you have a vehicle now that you would like to tow with? I cannot think of any vehicle that will tow a 30' that won't tow a 34'. I generally find a 34 tows a little better than a 30'.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 10-16-2013, 06:43 PM   #30
aquinob's Avatar
Portsmouth , Virginia
Originally Posted by andreasduess View Post
We tow a 34' 1984 International with a dry weight of 6250lbs with a Honda Odyssey minivan. With WD in place, the car only carries about 500lbs when the trailer is fully loaded - payload is 1400lbs, hp are 260, weight of the vehicle and the trailer are roughly equal.
UMM. Are you saying you are towing a 6200 lb trailer with a van that has a 3500 lb tow rating? Maybe I'm missing something but it sounds like you are about double the max for that vehicle.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 10-16-2013, 07:06 PM   #31
andreasduess's Avatar
1984 34' International
Toronto , Ontario
There are a number of threads in existence that discuss manufacturer published tow ratings. This thread should give you all the information you need to come to your own conclusions.
andreasduess is offline   Reply With Quote
