Old 04-07-2012, 11:45 PM   #1
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
Took a trip to the CAT scales
I weighed three times. Once was just the Suburban loaded with stuff but no trailer or hitch (flip the numbers because I pulled into the scales the wrong way), the next was with trailer but w/o any weight distribution and the third was with the weight distribution bars up.
phbarnhart is offline   Reply With Quote
Old 04-07-2012, 11:46 PM   #2
phbarnhart's Avatar
Eugene , Oregon
Images: 14
Here's the sticker from the drivers door:
Old 04-07-2012, 11:48 PM   #3
phbarnhart's Avatar
Eugene , Oregon
Images: 14
I know that the weight distribution needs adjusting. I may or may not do it because I've ordered a ProPride and I probably won't be going on any trips before it gets here.
What are your thoughts on the weights otherwise?
Old 04-08-2012, 10:55 AM   #4
Vintage Kin
Fort Worth , Texas
Good to see this kind of start: tickets and ratings.
By the information offered and no other this would be a crappy riding & towing combination. The RA is overloaded, the TW is too high ("why" needs investigating) and the WD is inadequate.
On this hitch or another we'd also want to see:
1] TV "unladen/solo" scale ticket where the adjusted empty weight is made: driver, full fuel and permanent supplies aboard, but not loaded for camping otherwise.
2] Chevrolet's estimated weight of the vehicle as spec'd
3] Airstreams standard given weight of the TT
4] Pictures of the hitch rigging made while on level ground; and,
5] Pics of the rig from the near distance that frame the "level" or attitude of the rig as a whole.
- Were it me I'd wait for the new PP hitch.
Chevrolet Suburban
Vehicle GVWR: 7,400-lbs
FAWR - 3,600-lbs
RAWR - 4,200-lbs
(The Ron Gratz Chart)
Weighing #1
TT attached and Weight Distribution Activated
Let Front Axle Load be "FA1" 3,000-lbs
Let Rear Axle Load be "RA1" 4,480-lbs
Let TT Axles Load be "TT1" 5,420-lbs
Then, while in same position on scales, take
Weighing #2
TT attached and Weight Distribution Not Activated
Let Front Axle Load be "FA2" 2,840-lbs
Let Rear Axle Load be "RA2" 4,700-lbs
Let TT Axles Load be "TT2" 5,380-lbs
Then, drive off scales and drop TT.
Return to scales and take
Weighing #3
TV only -- TT Not Attached
Let Front Axle Load be "FA3" 3,200-lbs
Let Rear Axle Load be "RA3" 3,360-lbs
6,560-lbs TV gross
From the above values, you can calculate:
TV weight = FA3 + RA3 6,560-lbs
Gross Combined Weight = (FA1 + RA1 + TT1)
- should also be equal to (FA2 + RA2 + TT2) if scale weights are correct
(12,920) = (12,900) [20-lb discrepancy within normal scale range]
TT Weight = Gross Combined Weight - TV Weight
5,380 = 12,920 - 6,560
Tongue Weight = (FA2 + RA2) - (FA3 + RA3)
(2,840 + 4700) - (3360 + 3200), or,
7,540 - 6,560 = TW 980 18%
Load Transferred to TT Axles
when WD System in Activated = TT1 - TT2
5,430 - 5,380 = 50-lbs
Thoughts are that if it rides like crap and doesn't follow well it's because the WDH is just along for the ride at present. TW is too high also.
A] RA is overloaded.
We might expect to see a TW of around 675-lbs to 800-lbs (12.5 to 15%) on a 5,400-lbs TT. When the TV FA is restored to "laden/loaded" solo value, then the RA ought to see from 405 to 600 pounds of TW once WD is activated and optimized.
- In the "laden/towing" ticket we want to see the same FA as when "laden/solo" for the TV. (It is heavy by 160-lbs).
- In the ticket showing WDH activated, we would want to see a RA of closer to 690-lbs additional, and a TT weight of 290-lbs additional in a 70/30 split of TW from TV to TT (and that could also be 75/25 or 60/40, etc).
1] Why the TW is at 18% needs investigating
2] Adjustments to the hitch need to "return" FA to unladen value
3] Adjustments to the hitch need to correspondingly "transfer" more TW to the TT axles.
My action plan (were this mine) would be about tire capacities (TV & TT; where a margin of 15% adheres for all loads). A 4200-lb rating, with a likely 90% load factor when all is said & done, means we'd want to know the exact per tire loading. What is the tire manufacturer load rating?
Then, why TW is so high (several hundred pounds). A trailer of this size shouldn't push margins so much. Was something added or loaded to truck rear? Something in the forward 20% of the TT?
Old 04-08-2012, 12:14 PM   #5
Vintage Kin
Fort Worth , Texas
Since the new hitch isn't available, might as well verify tire loadings and proper pressures:
A Suburban K10906 is a half-ton 4WD. Did it come with the 20" tires? Is it Z71 spec?
The OEM tire would have then been GY or Bridge in 275/55-20 with a Load Index of 111, or, 2,400-lbs each (4,800 combined).
To bring it 15% past RAWR would be 4,800-lbs (same as factory).
Other tires would bring it to an Index of 117 or 2,900-lbs ea in the 20" sizing (5,800-combined) an 18% increase past factory (certainly no more needed).
Not saying that the TV needs other tires. But if combined weights stay high on loadings, this is the suggested course to start with.
A per-wheel position scale ticket -- X4 -- would be good where the TV is loaded as heavily/highly as is ever likely. Per axle averages are good where the margin is not approached (in general) but ought to be mandatory when it is. One wheel or another may be 20-30% higher than the other on the same axle thus the load margin is needed per that position.
We can use the initial TW loadings to speculate about the likely range of weights seen on each wheel if we can get per-wheel weights, etc.
Hereis a recommended professional tire pressure gauge (with case). One for TT and one for TV (keep case with dedicated TQ wrench for TT wheel lugs). Always a spare.
A highly accurate gauge such as this allows one to set both TT & TV tire pressures with any air source with consistent reliability.
1] TT tire pressure should always be at sidewall maximum (10% higher for extended parking, but adjusted down for movement).
2] TV tire pressure is a bit time consuming (first time, like WDH adjustment) but we want no more than about 5-psi rise in pressure after 1.5-hr of steady state driving. Raise or lower in 5-psi increments until the lowest best value is acheived for the TV load at that time where factory upper/lower limits are respected, and the FF/RR psi balance remains.
I know it sounds like too much. But living in hurricane country makes one aware that nothing may remain of ones home. And that no area of the country is exempt from this scenario type. The advantage of a truck pulling a travel trailer is that one just might load the kitchen sink. Thus the wheel weights, individually, is the manner of determining if TV tires should be upgraded (the cost justified) if the margins suggest that this is advisable.
A survey -- in this way -- covers all contingencies.
Old 04-08-2012, 12:44 PM   #6
phbarnhart's Avatar
Eugene , Oregon
Images: 14
Thanks Rednax, you've pretty much confirmed my suspicions regarding this particular setup. I guess that I probably got used to it handling like crap because I don't really know any better.
The tires are already upgraded 117 load range. Nokian Vativa, if your curious.
The back of the Suburban had the little Weber Q BBQ, the two cocker spaniels and the Honda 2000i generator in it with the third row of seats removed and all the stuff (BBQ and genny) pushed up as far towards the front as they would go. Essentially they were right over the rear axel.
I should also point out that, the fresh water tank was a little less than half full so consider that there's another 160lbs in the trailer. My driveway is an such an angle that I cannot fill the fresh tank at home.
Even though the Suburban is painfully new I've been talking to the local dealer about a 3/4ton model. I'm towing with my two little boys in the car and the way things are now (even with a ProPride and perfect W/D) I'm right on the edge of my current vehicle's capacities.
Old 04-08-2012, 12:55 PM   #7
Attachment 155250
Attachment 155251
Attachment 155252
Your towing weights are way out of line.
You can clearly see that when you tow, the front axle has less weight on it. VERY BAD.
To be safe the maximum difference of weights between the front and rear axle, should be no more than 10 percent.
However, the closer the front and rear axle weights are are, the better.
Keep in mind that a good load equalizing hitch, properly installed and properly adjusted, will also move some of the weight in your tow vehicle.
Ideally, when your rigged up, the front axle should weigh 3660, and the rear axle should weigh 3820.
However, never let it become worse than 3350 on the front axle and 4130 on the rear axle.
If those weights are not as listed, then basically your load equalizing hitch is useless for towing.
Be safe, follow the rules, and observe the far better handling.
Old 04-08-2012, 01:08 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
phbarnhart,
...I would try for at least 260lbs more on the steering axle regardless of hitch being used. Your goal is to replace the lost str axle weight between ticket #1 and #3, keeping the entire rig level.
The hitch choice won't correct light steering.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 04-08-2012, 01:55 PM   #9
phbarnhart's Avatar
Eugene , Oregon
Images: 14
Bob and Andy,
Thanks for the input. I agree that the w/d is not working as it should. I've ordered the ProPride primarily because of the sway elimination but also because the weight distribution system seems much easier to adjust. I am concerned that it will add at least 100 lbs to the tongue. I guess that will just get distributed and not matter too much.
Old 04-08-2012, 03:58 PM   #10
Vintage Kin
Fort Worth , Texas
Yeah, theres room to work with on weights, no question. Glad to see TV tires are not at question for load capacity (so playing with pressure is just SOP). TT tires are worthy of the same per-wheel investigation (also at full load). TW . . . . ?
Get those first five bits of requested info (numbers & pics) as convenient, and the next go-round will have any/all questions framed in.
Old 04-08-2012, 06:27 PM   #11
dznf0g's Avatar
Oswego , Illinois
Bob and Andy,
Keep in mind that if you weigh the tongue on, say, a Sureline, with the PP attached....yes you will add about 100# to tongue weight. BUT, with the vehicle hitched up, the PP adds about 100#s to the rear axle weight but NOTHING to tongue weight. Think about it for awhile and you'll get it.
-Rich-
Old 04-08-2012, 09:31 PM   #12
Western slope , Colorado
So...with a weight distribution hitch, does original tongue weight even matter? I don't get your statement. The mass of the hitch is still there only the springs(bars) torque the system applying downward force to the tv front axle and the rv's axles in essence applying a bending moment with the fulcrum at the hitching point. You are not moving mass/weight, just redistributing load/force.
"If you come to a fork in the road, take it."
Yogi Berra
Streamside is offline   Reply With Quote
Old 04-08-2012, 09:40 PM   #13
A load equalizing hitch, redistributes tongue weight.
That weight total is from the weight of the tongue, the hitch weight, AND, the truck or rear axle extra load weight.
If a pickup truck, as an example, has a payload in it's bed, the load equalizing hitch can and does move some of it as well.
The hitch torsion bars have no idea where the weight is from, and doesn't really care. It's job is to "move it", to some degree.
Old 04-08-2012, 09:54 PM   #14
phbarnhart's Avatar
Eugene , Oregon
Images: 14
You guys are making my head hurt. Are we getting metaphysical about tongue weight v. axel weight?
Bathroom walls have some damage to the bottoms, can't think of good repair. mikeandnora General Interior Topics 5 04-10-2012 06:36 AM
Does anyone know where to get Parbond in Canada? TPickerl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 04-09-2012 10:17 AM
Chevy Avalanche & '71 Sovereign LY 31' Road Trip africaroots Towing, Tow Vehicles & Hitches 5 04-08-2012 12:14 AM
Is there a way to test the power converter? Taylormade Batteries, Univolts, Converters & Inverters 8 04-07-2012 09:36 PM
Airstream Overlander 26' ready to customize or restore. No Reserve Auction!!! eBay Watch Airstreams on eBay 0 04-07-2012 07:40 PM
