Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 04-10-2012, 09:31 AM   #21
bganso's Avatar
1994 30' Excella
Truckee , California
Took a trip to the CAT scales
This is a great thread, providing much needed info for us newbies. My used AS did not come with instructions for setting up a WD hitch and the manufacturer (EAZ-Lift) does not post this info on their website. The RV dealer went with "well, that's close enough". Although the trailer tows well, I now realize some adjustments are needed.
I found this info on the internet and it appears to be pretty accurate.
How to Setup a Weight Distributing Hitch | eHow.com
My questions: 1) When I weigh my TV, shouldn't "empty/solo" include myself and my wife since she'll be in the vehicle 99% of the time?
2) Is there a rule of thumb for a starting point as to how many washers to use, or just insure there are not less than 6 links between the lift unit and and spring bars. 3) I've been concerned about tongue weight as the P/O installed a Honda generator on the A-frame behind the propane tanks. to accomplish this the A-frame was extended about 6 inches. The genset addition/modification probably added about 300 pounds to the total weight. Can I assume, with a properly adjusted W/D system, that this weight will have minimal impact on tongue weight?
Obviously, I'm heading to the CAT scales in the immediate future.
Bruce
bganso is offline   Reply With Quote
Old 04-10-2012, 10:14 AM   #22
"Cloudsplitter"
Thumbs up
Bruce,
...just what I do, others may differ. I weigh the TV alone just as it will be used towing, full gas, DW, dog and camping supplies. I feel it's better to use loaded axle numbers.
Old 04-10-2012, 12:02 PM   #23
Vintage Kin
Fort Worth , Texas
You want both tickets: Adjusted from the shipping weight
1] Normal solo (driver & fuel)
2] Loaded for towing/camping
The first is a constant. The second can vary considerably (and may need changing).
Old 04-10-2012, 01:56 PM   #24
"Cloudsplitter"
What shipping weight?, I drove mine home.
Old 04-10-2012, 04:55 PM   #25
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
Question: If the weight from TV rear axle needs to be moved to front axle the weight distribution bar tension has to be increased e.g. less chain loops.
Also is min. 5 chain loops is a must requirement or can they 4 loops
Zia is offline   Reply With Quote
Old 04-10-2012, 04:59 PM   #26
Vintage Kin
Fort Worth , Texas
Bob, a Yankee needs always be more concerned by dead weight when its' neck/shoulder supported.
Adjusted empty weight is part of hitch rigging -- solo/unladen -- inasmuch as tire pressure needs also be established.
Solo/unladen and Towing/laden are the two distinct operating parameters for the TV where an established tire pressure number is required.
Just as height adjustments for the WDH are a good start, so also is the vehicle manufacturers "range" of tire pressure numbers. A FF/RR bias to always respect, but within the range the ideal tire pressure number to be found for either of the above conditions.
The TV is unlikely to ever be heavier or lighter. So best tire numbers for handling & braking per test, just as with scale values for WD fine-tuning.
There can be a situation where the conditions have changed. We now know where to start on adjustments.
Old 04-10-2012, 05:07 PM   #27
With a Reese full sway control hitch, 5 links under stress is the ideal.
However, 4 links works ok just as well, but at some point, the ball mount needs to be tilted a little more downward.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-10-2012, 05:20 PM   #28
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Reducing the number of links increases the tension and transfers more weight. The minimum number of links depends on the manufacturers recomendation. On my Reese trunnion WD hitch, the minimum is 5 links. I believe this has to do with the movement of the bars when the trailer is in a sharp turn.
Richard
Old 04-11-2012, 05:55 AM   #29
"Cloudsplitter"
Thumbs up
Red,
An optimist will tell you the glass is half-full; the pessimist, half-empty; and the engineer will tell you the glass is twice the size it needs to be.
Your verbosity rocks. KISS
Old 04-11-2012, 08:39 AM   #30
casa3805's Avatar
Corpus Christi , Texas
Images: 41
bottom or top
So...am I counting links on my Reese ”up” from the trunion bar and does the link that goes thru the bar get included? I know, rookie question but, I'm a rookie so....
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 04-11-2012, 09:18 AM   #31
Vintage Kin
Fort Worth , Texas
All links under tension.
Old 04-11-2012, 09:28 AM   #32
casa3805's Avatar
Images: 41
Dang....that would seem self evident, right? This being a rookie sure makes a person feel silly now and then.
Thanks!
Chuck & Skye
WBCCI 3805
Old 04-11-2012, 01:24 PM   #33
Vintage Kin
Fort Worth , Texas
"It" is not always obvious to me either; i.e., there's a reason some/most of us wound up on here.
Old 04-11-2012, 11:01 PM   #34
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
Yeah, and half the time it's "obvious" to me that means I've done it wrong.
phbarnhart is offline   Reply With Quote
Old 04-12-2012, 01:29 AM   #35
Vintage Kin
Fort Worth , Texas
The "right" TT and a nice TV cancel that out. Especially now that the best hitch is to be applied. Tires, same way. Etc.
Old 04-12-2012, 10:14 AM   #36
Zia
2007 20' Safari
Irvine , California
Thanks for the response, I will tilt the ball and reduce the links to 4 under tension.
After this adjustmustment I will take it to scale to see how the weight is distributed among the TV front and rear axle as well as the trailer
I do not what we will do without Andy.
May God bless you with good health and long life
Old 07-28-2012, 04:27 PM   #37
nilesrob's Avatar
Hampton , New Hampshire
Images: 12
Totally get the headache thing. Here are my results. Any thoughts appreciated!
The trailer tows great, although the tail end of my TV seems to hang a little low when hooked up...
ID:	164036   Click image for larger version
ID:	164038   Click image for larger version
ID:	164040   Click image for larger version
Brad (The Slowsky's)
2019 Airstream Classic 30RBT, 2021 Ford F350 King Ranch 4X4 w/6.7L Diesel, Hensley, ACI #1313
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 07-28-2012, 06:26 PM   #38
Bandits's Avatar
2008 30' Classic
Brad: your numbers look good. On my Hensley I move about 400# to the steer axle when everything is level. Looking forward to seeing you at the Canopener if not before. We may drive over to Falluminium since it's in the neighborhood but we have a rally at the Top of Georgia that we will be at. Hopefully next year the rally schedules won't conflict. Bandits.
Jerry, Irene & Clancy
Bandits is offline   Reply With Quote
Old 07-28-2012, 06:36 PM   #39
Bandits's Avatar
2008 30' Classic
Brad. If you go to one of the weigh scales along the interstate there is no charge. Just follow the trucks in and when you get on the scales tell them you want a weigh ticket otherwise you will just get a green arrow indicating you are good to go. Also when you first pull off the interstate to go to the weigh station you may come to a green arrow and a red x. When I followed the green arrow I ended up back on the interstate and missed the weigh station. All the red x meant was that I was not required for come in for weighing not that I couldn't come in. I proceeded through the red arrow, slowly at first, and proceeded to the scales. They know what you are before the turn off to the scales so basically the red arrow just means that you are not required to come in and. E weighed. Bandits.
Old 07-28-2012, 06:53 PM   #40
nilesrob's Avatar
Images: 12
Thanks Jerry - see you soon - somewhere!
Bathroom walls have some damage to the bottoms, can't think of good repair. mikeandnora General Interior Topics 5 04-10-2012 06:36 AM
Does anyone know where to get Parbond in Canada? TPickerl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 04-09-2012 10:17 AM
Chevy Avalanche & '71 Sovereign LY 31' Road Trip africaroots Towing, Tow Vehicles & Hitches 5 04-08-2012 12:14 AM
Is there a way to test the power converter? Taylormade Batteries, Univolts, Converters & Inverters 8 04-07-2012 09:36 PM
Airstream Overlander 26' ready to customize or restore. No Reserve Auction!!! eBay Watch Airstreams on eBay 0 04-07-2012 07:40 PM
