Old 07-24-2015, 09:26 AM   #43
KYAirstream's Avatar
Northeastern , Kentucky
Originally Posted by Inland RV Center, In View Post
To be safe the maximum difference of weights between the front and rear axle, should be no more than 10 percent.
I was digging through threads about cat scale weights, and was hoping some clarification could be provided about this 10% rule? Does it mean that there should be no more than a 10% weight difference between the weights of front and rear TV axles? That is, when hitched with weight distribution, if the front TV axle weighs in at 3000lbs, then the rear TV axle shouldn't weigh more than 3300lbs?
Or is it that the unhitched front and rear TV weights shouldn't differ by more than 10% from the hitched front and rear TV weights? That is, if unhitched the front axle TV weight is 3000 lbs, then hitched it shouldn't be less than 2700 lbs nor more than 3300lbs? And likewise for the rear TV axle...
KYAirstream is offline   Reply With Quote
Old 07-24-2015, 10:02 AM   #44
bwpaint's Avatar
2015 25' FB International
my , house
following --good info on thread
bwpaint is offline   Reply With Quote
Old 07-24-2015, 11:14 AM   #45
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Took a trip to the CAT scales
The spread of WD weight between FF and RR axle on the tow vehicle is ideally no more than ten percent, with the bias toward the RR.
This in achieving a spread of the TW equally across the three axle sets.
Old 07-24-2015, 11:46 AM   #46
Just so there is no confusion, would you mind providing an example using numbers?
Old 07-24-2015, 11:54 AM   #47
Also, I assume FF refers to front of TV and RR to rear?
Old 07-24-2015, 01:08 PM   #48
2016 30' Classic
Erie , Colorado
Here's the weight calcs in an excel file. Formulas based on the Ron Gratz methods.
Cat Calc Sierra 2500 5-3-14.xlsx
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 07-26-2015, 06:50 PM   #49
Thanks for the spreadsheet. I look forward to plugging in some numbers.
Bathroom walls have some damage to the bottoms, can't think of good repair. mikeandnora General Interior Topics 5 04-10-2012 06:36 AM
Does anyone know where to get Parbond in Canada? TPickerl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 04-09-2012 10:17 AM
Chevy Avalanche & '71 Sovereign LY 31' Road Trip africaroots Towing, Tow Vehicles & Hitches 5 04-08-2012 12:14 AM
Is there a way to test the power converter? Taylormade Batteries, Univolts, Converters & Inverters 8 04-07-2012 09:36 PM
Airstream Overlander 26' ready to customize or restore. No Reserve Auction!!! eBay Watch Airstreams on eBay 0 04-07-2012 07:40 PM
