Old 04-11-2012, 05:55 AM   #29
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by REDNAX View Post
Bob, a Yankee needs always be more concerned by dead weight when its' neck/shoulder supported.
Adjusted empty weight is part of hitch rigging -- solo/unladen -- inasmuch as tire pressure needs also be established.
Solo/unladen and Towing/laden are the two distinct operating parameters for the TV where an established tire pressure number is required.
Just as height adjustments for the WDH are a good start, so also is the vehicle manufacturers "range" of tire pressure numbers. A FF/RR bias to always respect, but within the range the ideal tire pressure number to be found for either of the above conditions.
The TV is unlikely to ever be heavier or lighter. So best tire numbers for handling & braking per test, just as with scale values for WD fine-tuning.
There can be a situation where the conditions have changed. We now know where to start on adjustments.
Red,
An optimist will tell you the glass is half-full; the pessimist, half-empty; and the engineer will tell you the glass is twice the size it needs to be.
Your verbosity rocks. KISS
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-11-2012, 08:39 AM   #30
casa3805's Avatar
Corpus Christi , Texas
Images: 41
bottom or top
Originally Posted by Inland RV Center, In View Post
With a Reese full sway control hitch, 5 links under stress is the ideal.
However, 4 links works ok just as well, but at some point, the ball mount needs to be tilted a little more downward.
So...am I counting links on my Reese up from the trunion bar and does the link that goes thru the bar get included? I know, rookie question but, I'm a rookie so....
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 04-11-2012, 09:18 AM   #31
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
All links under tension.
Old 04-11-2012, 09:28 AM   #32
casa3805's Avatar
Images: 41
Dang....that would seem self evident, right? This being a rookie sure makes a person feel silly now and then.
Thanks!
Chuck & Skye
WBCCI 3805
Old 04-11-2012, 01:24 PM   #33
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
"It" is not always obvious to me either; i.e., there's a reason some/most of us wound up on here.
Old 04-11-2012, 11:01 PM   #34
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
Yeah, and half the time it's "obvious" to me that means I've done it wrong.
phbarnhart is offline   Reply With Quote
Old 04-12-2012, 01:29 AM   #35
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The "right" TT and a nice TV cancel that out. Especially now that the best hitch is to be applied. Tires, same way. Etc.
Old 04-12-2012, 10:14 AM   #36
Zia
2011 23' FB International
2007 20' Safari
Irvine , California
Thanks for the response, I will tilt the ball and reduce the links to 4 under tension.
After this adjustmustment I will take it to scale to see how the weight is distributed among the TV front and rear axle as well as the trailer
I do not what we will do without Andy.
May God bless you with good health and long life
Zia is offline   Reply With Quote
Old 07-28-2012, 04:27 PM   #37
nilesrob's Avatar
Marietta , Georgia
Images: 12
Totally get the headache thing. Here are my results. Any thoughts appreciated!
The trailer tows great, although the tail end of my TV seems to hang a little low when hooked up...
ID:	164036   Click image for larger version
ID:	164038   Click image for larger version
ID:	164040   Click image for larger version
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 07-28-2012, 06:26 PM   #38
Bandits's Avatar
2008 30' Classic
Brad: your numbers look good. On my Hensley I move about 400# to the steer axle when everything is level. Looking forward to seeing you at the Canopener if not before. We may drive over to Falluminium since it's in the neighborhood but we have a rally at the Top of Georgia that we will be at. Hopefully next year the rally schedules won't conflict. Bandits.
Jerry, Irene & Clancy
Bandits is offline   Reply With Quote
Old 07-28-2012, 06:36 PM   #39
Bandits's Avatar
2008 30' Classic
Brad. If you go to one of the weigh scales along the interstate there is no charge. Just follow the trucks in and when you get on the scales tell them you want a weigh ticket otherwise you will just get a green arrow indicating you are good to go. Also when you first pull off the interstate to go to the weigh station you may come to a green arrow and a red x. When I followed the green arrow I ended up back on the interstate and missed the weigh station. All the red x meant was that I was not required for come in for weighing not that I couldn't come in. I proceeded through the red arrow, slowly at first, and proceeded to the scales. They know what you are before the turn off to the scales so basically the red arrow just means that you are not required to come in and. E weighed. Bandits.
Old 07-28-2012, 06:53 PM   #40
nilesrob's Avatar
Marietta , Georgia
Images: 12
Thanks Jerry - see you soon - somewhere!
The Slowsky's
WBCCI #1271
Old 07-28-2012, 10:39 PM   #41
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Good job on acquiring scale tickets.
The FA is the crucial first step in establishing a proper baseline.
FA, solo: 5,040-lbs
This is what we also want with the trailer hitched and WD activated.
Trailer hitched, no WD: 4,560-lbs (480-lbs removed)
Trailer hitched, WD active: 4,760-lbs (280-lbs short of best)
Further adjustment needed, IMO.
FORD, IIRC, recommends a 50% "return" when WD activated which you about meet. I'd rather go to 100% (or as close as hitch will do it). Check their guidelines for your model truck as that should be the background to your decisions/adjustments (as with GVWR, GAWR, etc, etc).
More:
RA increased by 1,480-lbs w/o WD activated.
With WD activated, 200-lbs "went" to the FA and only 40-lbs to TT axles.
Just not enough leverage by the WDH, yet.
(The Ron Gratz Chart)
Weighing #1 -- TT attached and Weight Distribution Activated
Let Front Axle Load be "FA1" 4760
Let Rear Axle Load be "RA1" 5160
Let TT Axles Load be "TT1" 5660
Then, while in same position on scales, take
Weighing #2 -- TT attached and Weight Distribution Not Activated
Let Front Axle Load be "FA2" 4560
Let Rear Axle Load be "RA2" 5400
Let TT Axles Load be "TT2" 5620
Then, drive off scales and drop TT. Return to scales and take
Weighing #3 -- TV only -- TT Not Attached
Let Front Axle Load be "FA3" 5040
Let Rear Axle Load be "RA3" 3920
From the above values, you can calculate:
TV weight = FA3 + RA3 8960
Gross Combined Weight = (FA1 + RA1 + TT1)
- should also be equal to (FA2 + RA2 + TT2) if scale weights are correct
15,580
15,580
TT Weight = Gross Combined Weight - TV Weight
15,580 - 8960 = 6,620
Tongue Weight = (FA2 + RA2) - (FA3 + RA3)
9960 - 8960 = 1,000
TW = 15%
Load Transferred to TT Axles
when WD System in Activated = TT1 - TT2
40-lbs
With a 1k TW we'd more likely see around 240-lbs shifted to the trailer axles once the FA weight is "restored" to it's solo value.
While "level" is really only important for the trailer (independent suspension; we want both axles loaded the same as they would not be if the trailer were nose high or low; braking, etc), and slight tail down no big deal for the TV, a better set of adjustments to your hitch will probably pick up the tail a bit.
But there is no doubt that the steering and braking will be improved by further tweaks to the WDH. The more the load on the TT tires, the better will be the combined braking of the rig. Not to mention best anti-sway.
Once done, with new scale tickets, one can also look at TV tire pressures for best performance within vehicle manufacturer guidelines, and check that TT tires still have a 12-15% load reserve against the WD activated scale value divided by four (TT tires are always to be at maximum sidewall pressure, cold).
Perfect is hard to achieve for some rigs . . but the closer one comes the better will the combination rig perform. And this eliminates a lot of guesswork if in the future "something" doesn't seem right anymore (ask BoondockDad about whether it was his worn hitch or his new tires causing a hoochie-koochie dance with his rig on a great thread from a little while back. Eliminating problems because one has solid numbers is a real boon).
Unless you sell either, or greatly change the loading of one or both vehicles, this baseline is good for many years to come. Just check it every so often the same way. A stack of scale tickets -- updated & clipped in your logbook -- is your very good friend. Confidence in a rig is in real time from real numbers . . but confidence itself cannot be measured accurately when it comes to the test. Give it some more work. It'll be the best beer you ever earned (you'll say to yourself someday).
Old 07-29-2012, 05:16 PM   #42
nilesrob's Avatar
Marietta , Georgia
Images: 12
Rednax, awesome advice. I will make some adjustment to the WD, and next time by a scale will give it a whirl. Thx for the thoughts and recommendations.
The Slowsky's
WBCCI #1271
Bathroom walls have some damage to the bottoms, can't think of good repair. mikeandnora General Interior Topics 5 04-10-2012 06:36 AM
Does anyone know where to get Parbond in Canada? TPickerl Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 04-09-2012 10:17 AM
Chevy Avalanche & '71 Sovereign LY 31' Road Trip africaroots Towing, Tow Vehicles & Hitches 5 04-08-2012 12:14 AM
Is there a way to test the power converter? Taylormade Batteries, Univolts, Converters & Inverters 8 04-07-2012 09:36 PM
Airstream Overlander 26' ready to customize or restore. No Reserve Auction!!! eBay Watch Airstreams on eBay 0 04-07-2012 07:40 PM
