Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 06-20-2016, 08:53 AM   #1
Peterborough , New Hampshire
tongue weight scale
While shopping for a tongue weight scale, I noticed that several manufacturers offer different total weight options. Is their any reason for this? If not, why not order the 5000# model and be able to use it on several trailers, just asking?
terrylarock is offline   Reply With Quote
Old 06-20-2016, 09:37 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
A simple bathroom scale and a 4x4 will do the job to the degree of accuracy you should need.
2004 Excursion 4x4
Old 06-20-2016, 10:23 AM   #3
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
The graduation on the scale is finer on the lower reading gauges, thus making it easier to read your tongue weight. I would go with the lowest range possible to make it easiest to read.
However, as HowieE has said some bathroom scales read high enough to measure. For my trailer tongue weight of 350# I would need a bathroom scale that reads up to 500#. YMMV
Ray B.
Adventure.AS is offline   Reply With Quote
Old 06-20-2016, 10:30 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
No, I think he was referring to this method.
2019 Ford Expedition Platinum
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Using a Sherline tongue weight scale ? Storis Towing, Tow Vehicles & Hitches 5 08-04-2015 03:06 PM
Sherline LM 2000 tongue weight scale and ProPride WD Hitch DeltaRon Towing, Tow Vehicles & Hitches 12 07-29-2015 04:39 AM
Tongue weight scale for loan? cwf Towing, Tow Vehicles & Hitches 0 08-03-2013 09:48 PM
