Old 12-02-2017, 01:04 PM   #1
2016 16' Sport
Charlotte , Iowa
Tongue weight question
I recently bought a 16 foot Sport. When it is filled with water and packed to go camping my tongue weight is 511 lbs. This includes the weight of the equalizer hitch, propane tanks, and batteries. My tow vehicle is a 2015 Santa Fe that is rated for 5000 lbs towing capacityand 500 lbs tongue weight. My question is if my car can handle this tongue weight. Does the hitch transfer enough weight from the tongue to make this a safe setup.
Thanks - Bill
boocanoe is offline   Reply With Quote
Old 12-02-2017, 01:11 PM   #2
Frederica , Delaware
Being a 11 lbs over is not a big deal. However that 511 lbs must be include in the vehicle's payload rating. Which may be putting the payload at or over that threshold. Also may put you over the rear axle rating.
Overloaded is offline   Reply With Quote
Old 12-02-2017, 06:32 PM   #3
2016 30' International
Florence , Alabama
Echoing Overloaded - if your equalizer is set up properly your tongue weight should be ok; but you should check the total weight of the vehicle and loaded trailer against the vehicles’ maximums.
joshjack is online now   Reply With Quote
Old 12-02-2017, 09:08 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If it worries you, the rating is mostly related to the numbers on the receiver. Swapping one of those out is *not* a big deal ....
Old 12-02-2017, 09:48 PM   #5
CruizinDux's Avatar
Tracktown USA , Oregon
I would add know your loading and how more or less weight (inc water & propane) can easily affect TW. I'm learning a new device but read my post on the 20 footers thread.
Loading ~ plaement & hitch setup....critical
Getting back to to the ? 511 IMO you're good to go.
Happy trails.
CruizinDux is offline   Reply With Quote
Old 12-03-2017, 05:29 AM   #6
Vintage Kin
Fort Worth , Texas
Thanks - Bill
A WDH will transfer 20-25% or more to TT. About 400# to divide on the TV afterwards.
Did you measure TW at the ball receiver? Weighing at the tongue jack will be heavier. Take total length of trailer and adjust as percentage.
Old 12-03-2017, 05:54 AM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The WD system doesn't change the tongue weight, it simply distributes that weight. If the 11 pounds is a big concern for you, wrap a standard concrete building block in a blanket, and place it in the rear storage compartment. If you don't want to do that, and are still worried about it, you can keep one of the two 20# LP tanks half full.
Just be aware you may have other things in your tow vehicle that will change what weight you can tow and carry much more than 11#.
Old 12-03-2017, 05:57 AM   #8
Hi
This is not sound advice. The tow vehicle is a unibody construction which is formed using sheet steel. Not to mention you will not likely find a higher rating receiver hitch for that model because of this. It is only as strong as your weakest link. In the full framed truck realm this would more plausible.
Old 12-03-2017, 06:11 AM   #9
Vintage Kin
Fort Worth , Texas
Unibody is a stronger vehicle than a comparable BOF. (And if one believes frame rails don’t twist, they do).
To “strengthen” a hitch receiver one adds bracing that extends forward in the ancient method. Andy Thomson at Can Am RV could provide info a local certified welder could use. Most pickups could also use this.
Old 12-03-2017, 06:30 AM   #10
And would this "local certified welder" know how to identify high carbon steels used in unibodied construction and how they are to be welded as not affect their molecular grain structure? All steel bend, flex, and twist under load regardless. Unibodied vehicles could be said to be stronger and they are, but mostly from impact forces not from towing stresses. Not trying to be argumentative but I am certified I-Car utilized frame repair and 6G certified gmaw/gtaw vessel pipe welder.
Old 12-03-2017, 06:31 AM   #11
Baltimore , Maryland
“Unibody is a stronger vehicle than a comparable BOF. (And if one believes frame rails don’t twist, they do). “
Frame rails twist and so do Unibody vehicles. Such a blanket statement in utterly nonsense.
Profxd is offline   Reply With Quote
Old 12-03-2017, 07:04 AM   #12
dznf0g's Avatar
Oswego , Illinois
10/4, I read this nonsense here all the time. Torsional rigidity has nothing to do with strength. BOF vehicles are, by necessity, designed to have some flex under heavy loads. Otherwise, they crack, as woulds a BOF under similar loads. That said, due to frame material advancements they are much more torsionally rigid than even 5 years ago.
-Rich-
Old 12-03-2017, 07:50 AM   #13
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
"They" refers to BOF twice. Which BOF supposed to be unibody? Thx.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 12-03-2017, 07:53 AM   #14
Obviously-NOT
Kalispell , Montana
Torsional rigidity tidbit;
My first SeaDad from the USS Enterprise said the 300' main shaft from #4 Engine Room had a 1.25 full revolution twist at a Flank bell. Hollow shaft for flexibility and packed with sand for vibration.
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
1980 Excella (31 Ft) Gross Weight/Tongue weight? jnichols 1981 - 1983 Excella 9 07-23-2011 01:54 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
