Old 06-22-2016, 05:10 PM   #1
2009 27' FB Classic
Lincoln , Nebraska
tongue weight classic 27FB
It would appear that our 27FB classics tongue weight is more than advertised by the airstream specs. Specs say 750lbs but the cat scale says 1250lbs loaded ready to go streaming. No liquids in tanks, propane bottles 3/4. Any one have any thoughts on this I would appreciate any input. Thanks
Freedom is not FREE unlike what our leaders in gov,t say to the undocumented???????
79fasteddie is offline   Reply With Quote
Old 06-22-2016, 06:08 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Curious about the weighing procedure, connected to truck, weight distribution set, trailer level, disconnected, tongue jack resting on scale, type of w.d. hitch, or . . .
Doug and Cheryl
Old 06-22-2016, 07:29 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It does not surprise me that the figures don't match. Much depends on add on's at the factory and how you load the coach. Regardless of the tank levels.
If you want to weigh the coach tongue you can do it with a couple of boards and a bathroom scale.
Look it up on the Internet. "How to measure tongue weight with a bathroom scale".
Old 06-23-2016, 01:38 AM   #4
1991 25' Excella
Stanfield , Oregon
Quit wasting your money with cat scales. Get something like this for the exact tongue weight and use dot scales for free. https://www.amazon.com/dp/B007REK28M...=I7EPXXHK8DII1
SpletKay06 is offline   Reply With Quote
Old 06-23-2016, 06:42 AM   #5
dkottum's Avatar
Trouble is, only the CAT or truck scale can tell you how much weight the trailer tongue adds to the truck after weight distribution is applied.
The tongue weight scale has less value.
Doug and Cheryl
Old 06-23-2016, 06:49 AM   #6
Rich and Kat
AIRHEDS's Avatar
Virginia near , Washington, D.C.
Originally Posted by dkottum View Post
Trouble is, only the CAT or truck scale can tell you how much weight...
Doug, sorry about the dumb question, but what's the CAT? Thanks, Rich
AIRHEDS is offline   Reply With Quote
Old 06-23-2016, 08:19 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
CAT....Certified Automated Truck....scale.
ID:	265000   Click image for larger version
Name:	CAT Weights.jpg
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel its supposed to be done"..
Amanamus
"Tahawus"
Old 06-23-2016, 08:44 AM   #8
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Welcome to the heavy tongue weighted Classics. My 2008 25fb Classic is 1100 to 1200lbs. Nature of the beast.
Kelvin
Old 06-23-2016, 09:40 AM   #9
Ambot's Avatar
2016 28' Pendleton
Cybertron , Illinois
It's a great mix to have airstream under value the tounge weight and truck manufacturers over value the payload!
Ambot is offline   Reply With Quote
Old 06-23-2016, 09:59 AM   #10
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Kelvin
For Kelvin and OP:
Is that just tongue weight? Or does it include the hitch? WD on or off? Airstream's tongue weights are typically low. I had heard that attributed to them being specified when the trailer was unloaded, but a 500# difference seems extreme.
My 2002 Classic 30 Slideout has about 950# as we camp, measured on a Sherline scale. I know the FBs are heavier, but that seems like a lot. I haven't weighed it on a scale yet, so I know the WD off weight will be 150# heavier due to the hitch but the WD when applied should shift some of that back to the trailer.
Al
Al, K5TAN and Missy, N4RGO
S/OS #004
Old 06-23-2016, 10:49 AM   #11
Kelvin
Kelvin,
Where did you get such an outrageous number....
Oh.... it's a Classic.
Originally Posted by Al and Missy View Post
For Kelvin and OP:
Al
My understanding....
....TW is what the tongue weighs, level, loaded for camping and un-hitched, no WD involved.
WD's job is to re-distribute the weight to maintain stability.
Hitched, loaded & level, w/WD set, I have 1080lb added to the TV rear axle.
W. H. Auden
Amanamus
"Tahawus"
Old 06-23-2016, 11:11 AM   #12
dkottum's Avatar
Tongue weights vary by procedure. A forum member with a ProPride hitch placed a tongue weight scale under the tongue jack post, and then again under under the ProPride stinger where it goes into the truck receiver. The difference was 200 lbs.
Does the tongue weight tell you how much weight will be added to the tow vehicle when hitched with a weight distribution hitch? No. The weight distribution hitch will cause most, but not all, of the tongue weight to be carried by the truck's axles, and some of it by the trailer's axle(s).
More importantly, it will cause some of the tongue weight (as well as some of the truck bed weight) to be carried by the tow vehicles front axle, an important safety factor for steering and braking, and to help ensure the tow vehicle's axle are not overloaded.
So go ahead and weigh your trailer tongue, but only a CAT scale can give you these important axle weights.
Doug and Cheryl
Old 06-23-2016, 12:17 PM   #13
1991 25' Excella
Stanfield , Oregon
There are Dot scales all over the country that are free. They dont give the fancy print out but that dosent matter to me. The cat scales are about $8 per weight, that adds up in a hurry.
Old 06-23-2016, 12:24 PM   #14
N/A , N/A
It's important to weight the dead tongue weight (before weight distribution kicks in) to make sure you are not exceeding the receiver ratings.
rostam is offline   Reply With Quote
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
1980 Excella (31 Ft) Gross Weight/Tongue weight? jnichols 1981 - 1983 Excella 9 07-23-2011 01:54 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
