Old 05-03-2016, 08:24 AM   #1
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Tongue weight anomaly?
About a month ago, I posted saying we were selling the diesel pusher and going back to aluminum. The bus now has new owners so the hunt is on for a trailer. While reviewing the weight chart published by Airstream, I noticed the 30' Classic for years 2005 through 2009 have unusually light tongue weights, or it least they appear that way to me. If correct, this fits perfectly with what we are looking for. So, I'd like to hear some real world weights from those of you that have that model and year range. I live by the adage "trust but verify", it helps keep me out of the ditch. Appreciate any input about the trailer as well.
https://www.airstream.com/wp-content...me-Weights.pdf
Greg
Roadtoaster is offline   Reply With Quote
Old 05-03-2016, 08:55 AM   #2
dznf0g's Avatar
Oswego , Illinois
They are much lighter, as a percentage of total weight, than many other models. I have a 30' classic (non-slide....the slides are heavy on the tongue) and just completed (along with another forum member) a very anal-retentive spreadsheet which accounts for various loading scenarios. I actually have difficulty in a couple of trip loading scenarios getting 10% tongue weight. I am usually between 9% and 10% and intentionally move some stuff from the truck to the Lounge floor to get my 10 - 11%.
My baseline weight (before any clothes, food, etc...but all "permanent" gear loaded) is 8568# with 853# TW.
Fully loaded with all toys, including the tongue mounted bikes (but no food and clothes etc.) is 9298#, with 1014# on the tongue.
-Rich-
Old 05-03-2016, 03:00 PM   #3
Rich, thanks for the numbers.
Greg
Old 05-20-2016, 10:15 AM   #4
Ayr , Ontario
My Tongue weight is 750lbs on a fully loaded trailer. Water tank full. 2 - 40lb propane tanks full and 2 batteries as came standard from the factory.
As a result of the light tongue weight I ended up using a Hensley. Just was unable to get the EZ lift to work properly.
gator.bigfoot is offline   Reply With Quote
Old 05-20-2016, 10:24 AM   #5
Thanks Gator. I tried to push the boss to this model but I failed! Wound up with a 2015 30' with more tongue weight than I wanted, but still ok. Always best to keep the boss happy!
Greg
Old 05-21-2016, 09:24 AM   #6
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
With our 2005 CCD 25Ft RB printed 5300lb dry placard. (CCDs seem to be less weight per inner trim), With 1/3 fresh water, 90% full dual 40lb propanes, new dual batteries, basic stock to camp with no food or clothes was digitally clocked at 750lbs. Adding the Eze-Lift WD w 1000lb rated bars/gear, adds another 60lbs on hitch = 810lbs. So in theory, WD properly adjusted should offload @ 30% (-243lbs) of combined HW to the far axels. Hitched up ready to roll adjusted should also then be @ 567lbs ?
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2014 GMC Sierra Denali 1500 4X4 int. 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is offline   Reply With Quote
Old 05-21-2016, 09:45 AM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Our FC 25 has a published hitch weight of 835 lbs and our ProPride hitch and stinger weighs 180, bikes and rack on rear bumper 85 lbs. Our Airstream loads are not always consistent before/after months' long trips, and we have modified the interior for two recliner chairs, which we can move around.
We can also adjust interior loads, heavy to middle or somewhat aft, light in front. Our last trip to the truck scale with truck and then truck/tailer showed our Airstream added 820 lbs to the truck with weight distribution set, and the truck axles near equal load. Rides and handles very well.
Doug and Cheryl
Old 06-25-2016, 06:02 PM   #8
2014 25' FB Flying Cloud
Micanopy , Florida
Just curious, what size distribution bars are you using on your 25FC? Sounds like we have close to same set-up.
Offack is offline   Reply With Quote
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
Head light anomaly beerob63 Mechanics Corner - Engines, Transmission & More... 8 11-28-2013 11:49 AM
Vintage Anomaly on eBay 66Overlander Vintage Kin 89 12-15-2007 05:09 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
