Old 09-25-2018, 10:37 AM   #1
Palmetto , Florida
Tongue Weight
Does anyone know what Airstream's published tongue weight includes?
The published tongue weight ( TW ) I've seen for my 1989 34 Limited ranges from 800 to 850 lbs.
Does that include two full propane tanks? (appx 70 lbs)
Does the TW include my two Zip Dee awnings? Heavy things.
Based on a recent CAT scale weigh, I see a tongue weight of 1160 lbs, total trailer weight of 8860.
I'm having difficulty with weight distribution seeing my forward truck axle lightened by about 100 lbs, and the drive axle carrying most of the tongue weight. After a first weigh I moved a few things from the forward end of the trailer to the cab of the truck -about 40 lbs, and made an adjustment to the WD trunnion bar positions.
My heavy truck is handling the rig well including several panic stops and manuevers, but I want to improve the weight distribution, starting with minimizing the tongue weight as best I can.
Any input or information will be greatly appreciated.
Captnsteve is offline   Reply With Quote
Old 09-25-2018, 10:51 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think you would be going the wrong way by lowering the tongue weight by redistribution in the trailer. My bias is that a little extra tongue wt is better than less. Use the WD. Moving heavy stuff towards the back is not good in my opinion. I must state that I have not pulled a 3 axle trailer. My experience is with 2 axle rigs. Is rhe trailer set level?
Old 09-25-2018, 12:50 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
We have never returned 100%, our TV steering axle has always been 100-150lbs less, depending on our load. 8.1L 2500 Suburban.
As noted a LEVEL rig, (TV & AS) is more important than returning 100%.
If your towing without white knuckles...go for it.
Big pic, Truck alone weight then with out WD and the last with WD
ID:	323707   Click image for larger version
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 09-26-2018, 05:30 AM   #4
Palmetto , Florida
More on the tongu
Thanks Bob and Bill
My truck weights with and without trailer attached are very similar to Bob's, within just a few pounds.
An important note is that I did not move any weight to the rear of the trailer; just moved a couple easy carry items from the forward end of the trailer to the truck cab. that would have added a few pounds to my steering axle. I am at the max GVW on the trailer right now, so losing a few pounds won't' hurt.
Truck and trailer are fairly level, but not perfect. I've called the hitch maker once, and plan to call again after I take a couple measurements they have asked for.
Hopefully, I'll sort it out.
Tow vehicle Tongue Weight vs. Trailer Tongue Weight KeepPedaling Hitches, Couplers & Balls 10 03-23-2016 12:33 PM
1980 Excella (31 Ft) Gross Weight/Tongue weight? jnichols 1981 - 1983 Excella 9 07-23-2011 01:54 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
