Old 07-15-2015, 08:02 PM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Tongue weight?
I have always thought that tongue weight is your friend when trying to set up a stable towing trailer. I have always been careful to load utility trailers and boat trailers s o they have a good percentage of tongue weight. Yet almost every day I read a post in which people are trying to reduce the tongue weight of their trailer by shifting the load or by other means. How does this reduction help make a stable tow. One person was going to move stored goods from the Airstream designed storage at the front of the trailer to over the wheels. I would prefer it to be in the front. Or am I just like the captain of the Titanic in that what I know for sure is wrong?
Bill M. is online now   Reply With Quote
Old 07-15-2015, 08:44 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Not enough information. It is possible to have either too much or too little tongue weight. Multiple sources say the Goldilocks range is 10-15% of TT GVW.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-15-2015, 10:07 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Here's what my Airstream Owner's Manual says about it in the Towing section:
"WARNING: The tongue weight should he approximately 10% of the trailer’s total weight, but MUST NOT EXCEED 1,000 lbs. And, under no condition should it exceed the hitch rating. Your hitch installer should provide your hitch rating information."
I believe most of the Owners Manuals for late models have the same statement. Note that that our 2012 FC 25 maximum load is 7300 lbs, 10% for tongue weight is 730 lbs. The maximum load on any current production Airstream is 10,000 lbs, 10% is 1,000 lbs which matches their warning.
I also have loaded trailers (utility) heavy on the front to ensure stability after a particularly wobbly experience bringing home a load of lumber some years ago with a short utility trailer. So what you are saying makes sense to me, but for the Airstream I'll stick with their guideline and warnings.
My goal is 730 - 1000 lbs for our 25' FC, and I move loads around trying to ensure we stay within those parameters. Benefits are less tension needed on the w.d. bars, smoother ride, and more effective payload available with our truck. Without loss of stability demonstrated to us during many cross-country trips in all weather and traffic conditions, including dodging deer and quick-lane-change artists on the interstate.
Doug and Cheryl
Old 07-17-2015, 09:26 PM   #4
2011 27' FB Classic
Camp Hill , Pennsylvania
How does one measure tongue weight?
LyleRussell is offline   Reply With Quote
Old 07-17-2015, 09:50 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
google Cat Scale. Look at the how to drawings.
Search this forum for how to calculate different weights. You also should know the loads on tires, axles, hitch load (not the same as tongue weight), gross trailer weight, tow vehicle payload capacity, tow vehicle gross weight, load transferred by weight distribution, etc. Each component of the rig has its own load limits.
First weigh with the tow vehicle with trailer connected, with load distribution tensioned.
Second weigh with the tow vehicle with trailer connected, with load distribution loose.
Third weigh tow vehicle only.
This will give you information needed to calculate.
Cost $10 for the first weigh, then $2 for each additional during the same day.
Alan
Old 07-18-2015, 05:08 AM   #6
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Question?
Has anyone confirmed that what AS recommends in the OM is 'tongue weight', (unhitched) or receiver load with WD set.
...I have never been below 900-1000lbs TW, but carry 800-840lbs with WD set.
Is AS worried about the TV receiver or the Airstream tongue construction/limit?...or both. Obvious you need to stay within the limits of the receiver, but are they saying the AS's tongue can't support more than 1000lbs?
Old 07-18-2015, 05:17 AM   #7
Road Ruler's Avatar
Images: 38
We have a heavy tongue at near 15%. We try to load a lot of our stuff over the rear axles. Works good for us. The 23' handles and tows fine with our car.
Old 07-18-2015, 05:35 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
What did your tw weigh in as?
I know this model (73 23') is nose heavy, but I've never actually weighed mine.
The nose-heavy tendency is why I'm not too concerned about adding 2 grey tanks and a bigger black tank in my renovation. Its not that much static weight added to the structure (tanks themselves, and the hardware to attach them), and I'll also probably never drive around with full tanks, either.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-18-2015, 06:06 AM   #9
Road Ruler's Avatar
Images: 38
He there Chuck.... I believe our era of 23' has a listed tongue weight of 590lbs and road ready we are at about 4,500lb on the axles. For our car we don't want it to go much heavier. Keeping our bikes and other heavier items loaded on the rear axle area seems to work well.
Old 07-18-2015, 07:19 AM   #10
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
This is what I use:
Sherline Trailer Tongue Weight Scale - 2,000-lb Capacity Sherline Tools 5780
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 09-11-2015, 07:34 PM   #11
Mission , Texas
I find the attached article useful for describing the effect of where the weight is in a trailer and hopefully it will answer your question.
Some of the other information might be troublesome for some, but that is not my intention.
The link was previously in a deleted thread that had a horrible title and possibly caused some upset.
Again, just hoping more information about our trailers won't hurt.
http://oppositelock.kinja.com/tow-me...qnbJxnyozIeA.2
nrgtrakr is offline   Reply With Quote
Old 09-11-2015, 08:54 PM   #12
Livingston , Texas
The location of the center of gravity, relative to the location of the axle(s), is a primary factor in establishing the yaw stability of a TV/TT combination.
"Tongue weight percentage" simply is a shortcut to expressing the ratio of distance from TT axle(s) to center of gravity divided by the distance from axle(s) to the ball coupler. Instead of saying the distance from axle(s) to CG is 30" and the distance from axle(s) to coupler is 200", we say the tongue weight percentage is 15%. Unfortunately, we then tend to focus on how much vertical load is applied to the ball rather than on how the TT exerts lateral forces on the ball.
A fundamental objective in designing a trailer is to minimize the lateral force which can be exerted on the TV by the TT when the TT is subjected to lateral force due to wind loading, lateral road force on tires, etc. The force imposed on the TV is a function of:
a = distance from axle to CG
b= distance from CG to coupler
M = mass of the trailer
I = polar moment of inertia of the trailer.
Without providing the derivation, the relationship among these four variables is given by:
a*b = I/M
From this equation, if you knew the values for M and I, you could calculate an "optimum" value for a/(a+b) which is numerically equal to TW%.
Unfortunately, a TT's polar moment of inertia hardly ever is known, so the equation is not of much use. However, we can use a special case to demonstrate where the "rule of thumb" values for TW% might come from.
Let's assume the mass of the TT is uniformly distributed front to rear. Then, given that a typical TT is relatively narrow compared to its body length (L), we can approximate its polar moment of inertia as:
I = M*L*L/12
If we put this special value of I into the equation for a*b and assume the TT has an A-frame length of 4' and L = 20',
a little algebra would give a = 14', b = 2.38' and TW% = 2.38/(14+2.38) = 14.5%.
However, we know that most real trailers do not have their mass uniformly distributed front to rear. Instead, they tend to have more of the mass located closer to the center near the CG and axles. This reduces the polar moment of inertia. If the value of I for the above example were reduced by 30%, the corresponding "optimum" TW% would be reduced to 10.6%.
Since each element of mass in the trailer contributes to the polar moment of inertia in proportion to the square of its distance from the CG, it's not hard to see that concentrating the mass near the longitudinal center can significantly reduce the inertia value. If you compare the layout of a typical European caravan with a typical US trailer, it should be easy to see why the Europeans can get by with a TW% as low as 7% in most cases and as low as 4% in some.
Unless you have some way of estimating the polar moment of inertia for your trailer, there is no good way of knowing the "optimum" TW%. Some people resort to seat-of-the-pants experimentation with varying TW to try to achieve "optimum" yaw stability.
Ron
Ron Gratz is offline   Reply With Quote
Old 09-11-2015, 09:38 PM   #13
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
a little algebra would give a = 14', b = 2.38' and TW% = 2.38/(14+2.38) = 14.5%. Ron
Dammit! I should have paid attention in Mr. Hertzog’s Algebra class... he said I’d need it one day.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 09-11-2015, 09:56 PM   #14
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I have to agree with what Ron says, but I had to learn it all by trial and errors. What I learned was to not put a "wad" of weight ( like a 26 gallon water tank) clear at the back of the trailer behind the axles even with 15% tongue weight. I did get sway! I learned it was not all just tongue weight. Mass distribution plays a large part of smooth towing.
Sam
samb is offline   Reply With Quote
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
1980 Excella (31 Ft) Gross Weight/Tongue weight? jnichols 1981 - 1983 Excella 9 07-23-2011 01:54 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
