Join Airstream Forums Today
Old 02-15-2012, 05:41 PM   #1
snkrichards's Avatar
1978 23' Safari
eugene , Oregon
Tongue jack replacement
My 78 safari 23' had an electric tongue jack. It broke. I took it apart to see who made it but couldn't find a manufacturers name. What should I replace it with?
snkrichards is offline   Reply With Quote
Old 02-15-2012, 06:43 PM   #2
Kevin245's Avatar
1976 31' Sovereign
Rock Hill , South Carolina
We recently purchased a Barker. Very satisfied.
Airstream Power Jack .. worth the $$? - Airstream Forums
"...the most confident critics are generally those who know the least about the matter criticised."
Ulysses S. Grant
Old 02-18-2012, 07:21 PM   #3
1975 27' Overlander
Lethbridge , Alberta
I bought a manual jack with a side crank. It fit perfectly in the triangle, and I don't miss the electric at all.
AlbertF is offline   Reply With Quote
Old 02-18-2012, 07:46 PM   #4
sandlapper's Avatar
1993 34' Excella
york , South Carolina
Ditto on the Barker. They have been making them for a long time.
If I'm not here, I'll be somewhere else.
2007 Dodge Crew Cab 6.7 Cummins 6 speed manual DRW factory installed optional exhaust brake Leer Cap
12 Tires on the ground
Are you kind?
WBCCI # 3892
AIR # 43788
John & Susan
sandlapper is offline   Reply With Quote
Old 02-19-2012, 02:17 PM   #5
1978 23' Safari
eugene , Oregon
thanks for responding you guys. I couldn't decide so I went to harbor frieght. I figure when this one wears out I'll consider it all again. I do think the manual crank might be the way I go. This little trailer isn't that much of a chore.
Old 02-19-2012, 06:04 PM   #6
Splitrock's Avatar
1976 31' Sovereign
Sioux Falls , South Dakota
Side crank +1
http://img.photobucket.com/albums/v1...g?t=1278182564
'65 Safari Toilet Replacement StPierre Sinks, Showers & Toilets 10 03-01-2012 10:11 AM
Black water tank replacement '74 Land Yacht rear bath bhutch74ly Plumbing - Systems & Fixtures 18 02-18-2012 05:49 PM
Replacement mattress for my serenity Bjleci Airstream Trailer Forums 15 02-12-2012 05:57 PM
Axle Replacement Cost lpgasguy Axles 2 02-12-2012 10:13 AM
Belly Pan replacement canoeman Repairing/Replacing Floor &/or Frame 2 02-10-2012 02:37 PM
