Old 08-27-2013, 02:04 PM   #1
retrocar66's Avatar
1967 24' Tradewind
Greenville , North Carolina
tongue jack is too short?
The tongue jack on my 67 Tradewind doesn't reach the ground when the trailer is level -- it comes within maybe 6 inches, then I get a hard stop.
Is this just a malfunction of some kind? I can't believe the original design included a jack that didn't reach the ground.
The previous owner was lowering the jack onto an 8x8 block of wood. I thought it was just to save time cranking on the jack handle, but...
Can these jacks be readily disassembled to inspect or repair? Or are they closed devices that must be replaced in such a situation? I'd rather not carry an 8x8 with me all the time.
retrocar66 is offline   Reply With Quote
Old 08-27-2013, 02:14 PM   #2
dznf0g's Avatar
Oswego , Illinois
Barker electric jack? They have upper and lower limit switches which can be adjusted/replaced. Somewhere I have a pdf of the procedure.
http://www.barkermfg.com/hi_power_jacks.html
Click on the owner manual for superjack and scroll to retiming. IF you have a barker.
-Rich-
Old 08-27-2013, 02:22 PM   #3
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I would go with the 8 X 8, keeps the foot out of the mud. I use a 4X4 just toss it in the bed and tow on.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-27-2013, 02:26 PM   #4
Gainesville , Florida
The jacks usually have an extension to add on. They are two part units. Jim
Old 08-27-2013, 05:38 PM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Mine came with an extension base, more basic but functionally like the silver one below. There are a couple of new ones on the market like the red one pictured that remain attached to the post and pivot 90 to be out of harms way for travel.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 08-27-2013, 06:42 PM   #6
2005 19' Safari
GLENDALE , AZ
Some jacks have an extended-travel long shaft, like the one below, which extends 19-inches (most have 12-14 inches of travel):
Atwood 80718 White Deluxe Heavy Duty Power Jack - 3500 lb. Capacity : Amazon.com : Automotive
Note: This link is for example purposes only. Jack capacity, shaft length, etc. may be incorrect for your specific application; and other sources may have better pricing.
