Old 07-01-2019, 08:52 PM   #1
Raminc's Avatar
Wasilla , Alaska
To weld or not to weld
The receiver on my tv is larger than the hitch so I was given a sleeve to make up the size difference. Now trying to line up the hole in the sleeve to the hole in the receiver to get the pin in is such a pain in the arse. I've been thinking about welding the sleeve to the hitch but not sure that's a good idea. Can someone please advise?
Man plans ... The Gods laugh
Raminc is offline   Reply With Quote
Old 07-01-2019, 09:43 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I can't see anything wrong with welding the reducer to the shank.
CRH is offline   Reply With Quote
Old 07-01-2019, 09:43 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Itís a pain but you get used to it. Helps to use a pin that has a beveled end. I would not weld.
wulfraat is offline   Reply With Quote
Old 07-01-2019, 11:17 PM   #4
Raminc's Avatar
Wasilla , Alaska
My concern is weakening the shank when it's heated during welding. Are you an experienced welder?
Old 07-01-2019, 11:22 PM   #5
Raminc's Avatar
Wasilla , Alaska
The pin I'm using is beveled it's just that the sleeve slides in when I put hitch in. Can you explain why you think it's a bad idea to weld. I'm just trying to weight the pros and cons and so far there is only 1 pro and 1 con.
Old 07-01-2019, 11:51 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
Yes, I can weld. No, I am not a certified welder....lol.
My shank is solid steel. I can't see welding on it causing it to weaken...I suppose to keep from worrying, one could only weld forward of the pin hole.
I contemplated welding my reducer to the shank. I decided against it because I wouldn't be able to use it in a 2" truck if something happened to my truck while I was traveling.
Old 07-02-2019, 01:59 AM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Why not spot weld two nipples on the reducer which would stop its movement right at the perfect depth?
Old 07-02-2019, 04:21 AM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
Good idea, except wouldn't you weld the two nipples on the shank? With my aftermarket reducer you would. It slides inside the receiver about an inch. Of course, if you did that the 2" shank wouldn't fit a 2" receiver any longer.
The factory Ford reducer is flared on the end. It stops at the perfect depth.
I really wasn't considering welding the reducer on the shank due to having trouble putting the pin in, though. I was considering welding to take the extra play out of the hitch shank.
Old 07-02-2019, 04:48 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yes, weld...done by Reese when I bought the receiver.👍
One nice benefit...it doubles the thickness, less chance of an egg shaped pin hole.🤔 15 Seasons. SFSG
CRH...I had the shank welded. Three thin wide beads, top and both sides ground down to fit snugly.
ID:	345144   Click image for larger version
ID:	345146   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 07-02-2019, 04:58 AM   #10
Kevin245's Avatar
I would weld the sleeve into the hitch receiver box. This is a common adaptation method, and the metals in question are not exotic.
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Old 07-02-2019, 05:36 AM   #11
Charlotte , North Carolina
My snarky comment is why not just buy the correct sized shank?
The weld/don't weld question...I agree with the poster above is you lose your option to remove the reducer in the case of a different size shank.
If you are just aligning the pin hole, spot weld it so it can be easily removed. Or weld a bead to stop it where holes are aligned. Or buy one flanged correctly.
These are mild steel parts and can be welded, but I would not. I am a weldor, not certified.
Al U. Minium is offline   Reply With Quote
Old 07-02-2019, 05:48 AM   #12
CRH
1995 25' Excella
xxxxx , xxxxxx
The reason I did not buy the correct sized shank is because I couldn't find a 2.5" that had the length and drop that I wanted that would work with my chosen hitch head.
Old 07-02-2019, 06:04 AM   #13
My reason for not getting a 2.5" shank is I am getting old and lifting a 2" is already a strain. Buh!
Old 07-02-2019, 07:37 AM   #14
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
It's low carbon steel. You're not going to weaken it by welding.
out of sight is offline   Reply With Quote
Scotch Weld DP8005 ? toga Waste Systems, Tanks & Totes 1 03-25-2009 02:05 AM
Body filler? J-B Weld or US Chem All-Metal Zstream Ribs, Skins & Rivets 5 08-31-2008 10:28 PM
water heater tank cracked. JB weld? Curtis-79MH Classic Motorhomes 12 06-09-2007 04:07 PM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 06:44 AM
Floor Replacement - Frame Weld pinkflamingoes Repairing/Replacing Floor &/or Frame 9 01-04-2006 07:54 PM
