Old 07-09-2019, 12:23 PM   #57
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by Thiss View Post
Weight lifting keeps you young
The 2.5 shank is the best fix.
Someone once told me I looked like a weightlifter and asked me if I lifted weights. I replied - yes, every time I stand up (ba DUM dum!). Im here all week....
Yeah - it keeps me young while reminding me how old my back feels
It is a good fit though. I had read several threads about the pros and cons of the reducer sleeve and went with the larger stinger. Had I thought about the caulking solution then...... oh well. I think its also good advice. Lots of options!
Old 07-09-2019, 01:14 PM   #58
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Originally Posted by franklyfrank View Post
The over size shank adds $ 2,000.00 to the price.
According to the PP website there should be ~$50 difference, with tax etc.
The entire 2.5" adjustable stinger assembly purchased separately is $325.
https://store.propridehitch.com/prop...-2-5-receiver/
The 2" is $285.
https://store.propridehitch.com/prop...ble-hitch-bar/
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
A W Warn is online now   Reply With Quote
Old 07-09-2019, 03:09 PM   #59
Bompagene
Bompagene's Avatar
Las Vegas , Nevada
J B Weld
Just 4 drops to spot weld! Easy to remove, but holds tight.
Bompagene is offline   Reply With Quote
Old 07-10-2019, 09:47 AM   #60
Anna Maria , Florida
I lift my 80 lbs Generator for that .
Puny weight 2.5" shank wouldn't work for me. I would need one for each arm :-)..
franklyfrank is offline   Reply With Quote
Old 07-10-2019, 09:52 AM   #61
That's to simple for the " lets see how complicated we can make this " just to sound smart and sophisticated.
In 20 years I never needed a 2.5" receiver so at 75 I highly doubt I will ever need one.
Old 07-10-2019, 05:10 PM   #62
Bbelk's Avatar
2010 27' FB Classic
My pin hole was wallowing out a little so I bought a new adapter sleeve. The one that came with the truck was only 4 inches long so I got a longer one. I am a poor welder, but I welded the sleeve in and it has held for two years now. I tow a lot of things and have bike racks. They are all 2 inch.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 07-10-2019, 05:55 PM   #63
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
As suggested by others I would also buy a properly sized 2.5" stinger rather than try to jury rig something. Yes it's heavier, but I think it's a better solution than welding a sleeve in place. Just my $.02. As an aside, I do use a sleeve because the largest shank I could get with the Equalizer hitch was 2.5" and my diesel F250 has a 3" receiver. Fortunately the Ford 2.5" adaptor is flanged so it slides into place snugly at the perfect depth for easy alignment of the hitch pin.
The good thing about science is that it's true whether or not you believe in it.
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is online now   Reply With Quote
Old 07-11-2019, 02:56 PM   #64
CWSWine's Avatar
2019 33' Classic
Manhattan , Kansas
When I picked up the AS from the dealer he only had 2" shank for the Blue Ox and had to order the 2.5-inch shank. With the sleeve and the 2" there was way more slop then I wanted to deal with. I used it twice to get to a local campground and to tow back to get the 2.5 inches installed. I do agree that using the sleeve in 2.5-inch hitch will allow it to wallowed out not only the pin but the hitch also.
Do not weld. Even a spot or tack.
Do not use the sleeve for long. It will make our pin hole get wallowed out. You will also Bend the hitch pin and get it stuck.
Buy a new stinger that is the right size. 2 1/2 stingers are becoming very common.
Dennis & Ellie
2019 Ram 2500 Longhorn 6.4 Hemi w/2868 payload on the Yellow Tag.
2019 Airstream Classic 33FB Dry Weight 8595 Tongue 1230
CWSWine is offline   Reply With Quote
Old 07-12-2019, 06:58 AM   #65
Bbelk's Avatar
2010 27' FB Classic
Something I forgot to mention in my earlier post, and this is in response to some folks that have said they liked the glue idea and could alter it in the field.
I towed for a couple years with the factory adapter sleeve. When I decided to replace and weld the adapter, the old one would move in and out only the distance of the slop in the pin hole.
It was an hour long job under the truck with wrecking bars, steel pins and sledge hammer to get the sleeve all the way out. The wear around the pin had produced a lip that would not easily slide out.
If I had welded the sleeve in when the truck was new, the double thickness wall may have prevented the pin from wallowing out the pin hole, I don't know.
2010 27FB Classic
Old 07-13-2019, 08:11 AM   #66
One reason I did weld mine. That was 2 years ago it is solid without any issues no slop in the pinhole and what I like the best there is a lot less slop between the shank as well with the sleeve .
Old 07-13-2019, 04:19 PM   #67
Jim J's Avatar
2014 30' Flying Cloud
Austin , jhjohnstone
Images: 117
Depending on your type of hitch, you can get a new 2.5 in. Shank for $ 80 to $120
Jim J is offline   Reply With Quote
Scotch Weld DP8005 ? toga Waste Systems, Tanks & Totes 1 03-25-2009 02:05 AM
Body filler? J-B Weld or US Chem All-Metal Zstream Ribs, Skins & Rivets 5 08-31-2008 10:28 PM
water heater tank cracked. JB weld? Curtis-79MH Classic Motorhomes 12 06-09-2007 04:07 PM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 06:44 AM
Floor Replacement - Frame Weld pinkflamingoes Repairing/Replacing Floor &/or Frame 9 01-04-2006 07:54 PM
