Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 04-14-2015, 11:07 AM   #21
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have left the umbilical connected for weeks at a time without the tow vehicle battery draining.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-14-2015, 12:00 PM   #22
gecko's Avatar
2009 28' International
Pacific Palisades , California
Minno has it just right. If you don't need the tow vehicle to go elsewhere and you are level enough with it attached, it's so nice to have one less thing to do upon arrival and departure.
And DO unfasten the umbilical. Before heading to Texas from Southern California in our new 2009 28' International, we did a shakedown cruise to dry camp on the beach at Lake Isabella outside of Bakersfield. In February, it was chilly at 2600 ft--about 25 degrees--so we ran the furnace cycling on and off all night. We woke to a beautiful light frosting--and a completely dead battery on the Suburban. We couldn't believe that there wasn't an automatic shutoff of flow from the TV's battery--but there wasn't!
We've upgraded out battery bank from the two factory supplied 12v's to four 6v for a total of 440 amps (of which we don't use more than 50%), added more solar panels and a proper converter, and haven't had a problem since. But every time we stop for the night, the first thing we do is manually disconnect the umbilical! We've only forgotten to re-attach once, fortunately. Unfortunately, that was while climbing from Santa Fe to Telluride--I'm very glad that the Sprinter oversized brakes combined with low gears were able to handle our entire rig on some of those very steep, very long downslopes. I pulled over after one particularly long one and discovered the unattached umbilical--so no brake lights, but more importantly, no trailer brakes either!
Checklists are good.... :-)
gecko is offline   Reply With Quote
Old 04-14-2015, 01:49 PM   #23
m.hony's Avatar
2013 30' Classic
I'm thinking there is no draw on my Toyota's battery unless the switch is on-
If the coach batteries are dead, the tongue jack will not work until I start the truck.
It's like the cigarette lighters. Domestic makes- the cigarette lighter will work even if the key is not in the switch-
Asian makes- you have to turn the switch on to use the cigarette lighter-
I have left the umbilical plugged in for weeks at a time- truck still starts right away-
TAC #MS-10
Airforums #70955
Old 04-14-2015, 02:01 PM   #24
dznf0g's Avatar
Oswego , Illinois
Cigarette lighter....? We don't have those anymore, unless you ORDER a "smokers' package!
They're all "power ports" and won't accept the pop-out lighter. We have some of the ports ignition controlled and some not. There's 4 in my truck and 1 is hot all the time.
-Rich-
Old 04-14-2015, 08:23 PM   #25
m.hony's Avatar
2013 30' Classic
OK-
12 volt power port-
Same difference-
TAC #MS-10
Airforums #70955
Old 04-14-2015, 08:26 PM   #26
m.hony's Avatar
2013 30' Classic
Point is-
No power is going through my umbilical unless the ignition switch is on-
I have the "smoker's package". It is a pop-out lighter and an ash tray that fits in one of the cupholders.
TAC #MS-10
Airforums #70955
Old 04-17-2015, 06:37 PM   #27
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
I always unplug from my truck, why gamble on a discharged battery & their is no upside to staying connected. In the morning you attach the umbilical & go.
Mrjkq is offline   Reply With Quote
Old 04-18-2015, 10:55 AM   #28
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I'm with you. I always unplug when I stay hooked up. I've always been afraid that when the trailer is powered by 110, some freak situation could put 110 into the tow vehicle and do some damage.
Even if it is not really possible, it just makes me feel better.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 02-20-2017, 08:23 PM   #29
Turtle's Avatar
2004 16' International CCD
Arcata , California
What about the weight distribution bars? Any issue leaving them hooked up? I leave them on. Jamie
Turtle is offline   Reply With Quote
Old 02-21-2017, 06:49 AM   #30
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I am not aware of any downside of leaving them on. I leave my weight distribution bars hooked up if I am not unhooking
urnmor is offline   Reply With Quote
Old 02-21-2017, 03:10 PM   #31
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I run very heavy bars (1400 pound rating), and pull them pretty tight when hooking up. My trailer (25FB twin) has a front outside compartment. When the bars are hooked up, the compartment door is jammed shut. So the bars are flexing the body a bit. For that reason, I remove the bars every time I stop for the night.
SSquared is offline   Reply With Quote
Old 02-21-2017, 07:39 PM   #32
2014 25' FB Eddie Bauer
Glen Arbor , Michigan
That your compartment door is jammed shut is interesting. I have a 25 Eddie Bauer and 1400 pound bard and have never experienced any binding of the starboard side compartment.
Wanna EB is offline   Reply With Quote
Old 02-21-2017, 11:26 PM   #33
SSquared's Avatar
Longmont , Colorado
We have no problem with the compartment doors on the sides. It's just the one on the front.
Old 02-22-2017, 05:34 AM   #34
m.hony's Avatar
2013 30' Classic
No issues with leaving truck and trailer coupled indefinitely, weight bars in place with tension on, but I don't have a front storage compartment.
Even when I uncouple the truck and trailer I don't remove them, but slide them back out of the hitch head toward the front of the trailer and leave them sitting on the L-brackets.
I use the electric tongue jack to lift the truck and trailer high enough to remove the weight bars from the hitch head easily by hand with very little effort. I never use the provided lever. This only works with the jack foot in place to get the truck and trailer high enough.
TAC #MS-10
Airforums #70955
Old 02-22-2017, 07:44 AM   #35
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Originally Posted by Wayne&Sam View Post
I'm another who leaves it hitched for a one night stop. I may put down the tongue jack because that seems to take out a lot of the movement when you move about the trailer.
Same here. I also feel that it unloads the suspension on the truck a bit, depending on the angle you are parked at. Can't hurt (unless you drive off forgetting it's down...)
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 02-22-2017, 10:18 AM   #36
Mollysdad's Avatar
That's interesting. It make me think the chassis is being twisted, not just pulled down. Is one bar pulling harder than the other? Does it happen all the time, or just when using the jacks? It must be the bars, since you say it stops when you remove the bars.
Old 02-22-2017, 10:24 AM   #37
Mollysdad's Avatar
Okay, I'll rat myself out. I had two small utility trailers at home. I'd chain them together to prevent theft. Since they sat for a while the chain would get invisible in the grass.
You see where this is going? I hooked up one and drove away, noticed it acted a bit sluggish, so I looked in the mirrors and YIKES! I was dragging a second trailer alongside the first! I only got about 20' but it was enough.
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 10 06-26-2020 02:35 PM
Battery Disconnect not turning on... ATE123 Sprinter and B-van Forum 13 04-06-2015 07:38 PM
LP Detector & Batt Disconnect not work J Goertzen Batteries, Univolts, Converters & Inverters 2 04-08-2008 06:14 PM
Disconnect Drive Shaft smily Airstream Motorhome Forums 2 02-23-2004 05:51 AM
