Old 05-16-2016, 11:31 AM   #15
HowieE's Avatar
Princeton , New Jersey
Images: 12
Do not rely on an in dashboard OEM gauge. They fall under the category of Lie-o-Meters.
Any auto store will have after market gauges that are accurate.
Yes you can used the OBD2 port but the equipment will be quite expensive.
2004 Excursion 4x4
Old 05-16-2016, 11:48 AM   #16
dznf0g's Avatar
Oswego , Illinois
Not so much, Scangauge II is about a buck and a half. Also note that many of the newer (post 2000 model year) vehicles have the trans temp readout as a function of a "driver information center". This type of readout is taken directly out of the datastream of the vehicle computer....same as an OBD port plug-in.
Also, be aware that some OBD port plugins can cause "noise" in the dataline and cause driveability, or other performance issues...and set codes. Happens a lot with various devices.
-Rich-
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
2010 Suburban 1/2 ton w/tranny cooler... phbarnhart Tow Vehicles 53 09-23-2011 12:05 AM
Aux lights do not work myfirstrv Land Yacht/Legacy Motorhomes 3 11-05-2007 12:03 PM
aux transmission cooler? nickglase Mechanics Corner - Engines, Transmission & More... 10 04-08-2007 10:37 AM
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 08:22 PM
