Old 04-22-2019, 11:41 AM   #1
2016 25' Flying Cloud
Cedar Park , Texas
Tire pressure for Goodyear endurance
I just replaced the OEM tires on my 2016 25’ fb flying cloud with Goodyear endurance. The max PSI is 80. The Manual with OEM states 65 psi. What is the best tire pressure for the new tires? Assume I am traveling in Texas heat normal row weight.
brendakerry is offline   Reply With Quote
Old 04-22-2019, 02:45 PM   #2
Long Island , New York
Welcome to the forum!
There is a variety of existing threads on the GYE and tire pressures.
https://www.google.com/search?q=GYE&...com&gws_rd=ssl
http://www.airforums.com/forums/f438...sa-157249.html
http://www.airforums.com/forums/f438...ce-166511.html
A few tire experts have commented in those threads about GYE tire pressures, and it would provide excellent continuity if you would Quote those posts, and ask questions of the experts and other posters IMO.
Happy Trails,
Peter
Old 04-22-2019, 03:10 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
^^^^^^ x2.
wulfraat is offline   Reply With Quote
Old 04-22-2019, 04:11 PM   #4
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Best to know your weights of your tow vehicle connected/loaded up with the AS. Then also get the AS trailer unhooked, with both wheels on one scale and the tongue jack on the other scale. That will give you the info you need for your TW and your weight on the wheels. Short of weighing each wheel independently, you can just dived the weight by 4 and look at the chart from Goodyear Endurance. Many of us found that running at "Max Pressure" can cause popped rivets, so I choose to use the chart which sets my tires at 50-55PSI. No more popped rivets or broken hinges when I arrive. Enclosed are my scale weights and the attachment below has the GYE scale recommendations.
Name:	scale weights.jpg
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
gypsydad is online now   Reply With Quote
Old 04-23-2019, 08:33 AM   #5
gypsydad's Avatar
Correction above; I meant to say, all 4 wheels/tires on one scale and tongue jack on the other.
Old 04-23-2019, 08:53 AM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Looking at your scale ticket, I assumed that’s what you did - disconnected the TV and put the jack on the “steer” scale and all trailer tires on the “drive” scale. That’s cool - I never thought about doing that to get the tongue weight (I calculate based on other measures). So you have to unhitch, Drive the TV away, and then rehitch to take it off the scales yes? So long as there isn’t a line behind you I think that’s a cool idea I might try sometime!
SteveSueMac is online now   Reply With Quote
Old 04-23-2019, 10:34 AM   #7
Castiniron's Avatar
2017 25' Flying Cloud
1964 22' Safari
Houston , Texas
You will receive many answers to this. For me it was trial and error. We have a '17 25' fc fbq. We started out with 80 psi per the sticker on the TV. However, found it had way too much bounce. After reading NUMEROUS threads it became apparent the pressure could be lowered - we dropped to 73 - much better, but still bounce once the outside temps increased. I'm at 70 PSI cold and it seems to ride much better but will monitor through the summer, as we have several trips planned. IMHO I would say drop to 72 and monitor especially if you have the FB - it's easy to tell what happens around the seating area in the back.
Castiniron is offline   Reply With Quote
Old 04-23-2019, 10:43 AM   #8
Mollysdad's Avatar
I tried to nail this down a while back and gave up.
You can read Goodyear's chart (which is the same as GY's chart for Marathons) and when you plug in your weight, you'll say "No way".
Or you can run the maximum shown on the sidewall.
Or you can listen to the so called experts.
I listened to all the advice and decided that 65 psi was right for me.
Old 04-25-2019, 11:54 PM   #9
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I run whatever the tire states. Mine states 80. Tire manufacture writes the psi based on the tire, not based on what it is connected to.
This is one of those threads that will have too much information to be useful to you.
Good luck.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 04-26-2019, 02:51 AM   #10
A reminder from Post #2 . . .
Happy Trails,
Peter
Old 04-26-2019, 11:33 AM   #11
1986 31' Sovereign
Miami , Florida
I run 70 psi on my Sovereign which is usually at about 8000# gvw. Seems fine. At 80 psi, it was pretty bouncy (we'd find pillows on the floor...)
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 04-29-2019, 09:30 AM   #12
gypsydad's Avatar
Yes; weighed TV on one scale and AS on the other while hitched; then disconnected with hitch on steer scale and AS on the other...they had 2 scales and there was no line...in MT.
Goodyear Endurance ST Tires Made in USA subfan1 Tires 245 05-06-2019 05:26 AM
Endurance Tire pressure on 27FB Int'l LAWBC Tires 155 04-13-2019 10:16 AM
Goodyear Endurance Tire / Pressure dlkershaw Tires 34 06-18-2018 05:54 PM
