I just replaced the OEM tires on my 2016 25’ fb flying cloud with Goodyear endurance. The max PSI is 80. The Manual with OEM states 65 psi. What is the best tire pressure for the new tires? Assume I am traveling in Texas heat normal row weight.
A few tire experts have commented in those threads about GYE tire pressures, and it would provide excellent continuity if you would Quote those posts, and ask questions of the experts and other posters IMO.
Best to know your weights of your tow vehicle connected/loaded up with the AS. Then also get the AS trailer unhooked, with both wheels on one scale and the tongue jack on the other scale. That will give you the info you need for your TW and your weight on the wheels. Short of weighing each wheel independently, you can just dived the weight by 4 and look at the chart from Goodyear Endurance. Many of us found that running at "Max Pressure" can cause popped rivets, so I choose to use the chart which sets my tires at 50-55PSI. No more popped rivets or broken hinges when I arrive. Enclosed are my scale weights and the attachment below has the GYE scale recommendations.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, 6.7L, Blue-Ox WDH Summer-Star Valley Ranch RV Resort (Thayne, WY); Winter-Sun City (Georgetown,TX)
Correction above; I meant to say, all 4 wheels/tires on one scale and tongue jack on the other.
Looking at your scale ticket, I assumed that’s what you did - disconnected the TV and put the jack on the “steer” scale and all trailer tires on the “drive” scale. That’s cool - I never thought about doing that to get the tongue weight (I calculate based on other measures). So you have to unhitch, Drive the TV away, and then rehitch to take it off the scales yes? So long as there isn’t a line behind you I think that’s a cool idea I might try sometime!
You will receive many answers to this. For me it was trial and error. We have a '17 25' fc fbq. We started out with 80 psi per the sticker on the TV. However, found it had way too much bounce. After reading NUMEROUS threads it became apparent the pressure could be lowered - we dropped to 73 - much better, but still bounce once the outside temps increased. I'm at 70 PSI cold and it seems to ride much better but will monitor through the summer, as we have several trips planned. IMHO I would say drop to 72 and monitor especially if you have the FB - it's easy to tell what happens around the seating area in the back.
I tried to nail this down a while back and gave up.
You can read Goodyear's chart (which is the same as GY's chart for Marathons) and when you plug in your weight, you'll say "No way".
Or you can run the maximum shown on the sidewall.
Or you can listen to the so called experts.
I listened to all the advice and decided that 65 psi was right for me.
I run whatever the tire states. Mine states 80. Tire manufacture writes the psi based on the tire, not based on what it is connected to.
This is one of those threads that will have too much information to be useful to you.
Good luck.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
Yes; weighed TV on one scale and AS on the other while hitched; then disconnected with hitch on steer scale and AS on the other...they had 2 scales and there was no line...in MT.
2020 16' Nest
Saint Augustine
I run the endurance tires at 62 psi for my 25’ forward bed.The right front tire was running about 6to7 degrees hotter so I added 3to 4 psi and now the temperatures are similar.
My tires say 80psi cold. That’s what I fill them to. Running too low can cause the tire to heat up and blow. I talked to a camper that had a tire blow and it messed up his camper real bad.
Not only that but the trailer is going to pull harder, plus the tires aren’t going to wear properly.
I figure the manufacturers that engineered the tire know more about the correct tire pressure than I do.
Well, you certainly can run the pressure "you" think you want! What's wrong with following the Goodyear recommended pressure guide on PSI for weight of your AS?? Seems folks do what they want anyway, so hope you don't have too many popped rivets, broken hinges, etc... your assumption on issues with running lower pressure are not accurate, by the way..may want to read a few of the past threads on this.
...Better over than under.
What assumptions are you discussing? Under inflation is much more problematic, and tires will run hotter increasing the chance of failure.
I do what I think I should do...not what you think I should do...see my signature. TETO
"You don't know where you've been until you leave, enjoy life" RLC
Yes that’s right. And that’s what I fill them to. Messing around with the tire pressure is tricky.
If you have it too low for the weight of the trailer, it can cause stress on suspension components, break failure, handling and steering problems, possible tire failure and irregular wear and tear.
Since I know what the max is then I have a number to go by.
By the way there is a label on the outside of each trailer that states the recommended tire pressure. Mine says 80psi cold.
Not advocating running "under inflation"; just saying the "recommended pressure" for the weight/load per the mfg works for me...you can surely do what you want. Glad your having no issues; hope your "rivets and hinges" survive...Just saying on the roads/highways I travel, over-inflation from recommended pressure have produced problems mentioned...if your not having this issue, great; "keep on trucking". And of course, we all see your signature...
Still curious about those under inflation assumptions you referenced...what were they?
