Old 06-16-2013, 06:23 AM   #1
1969 27' Overlander
St. Louis , Missouri
Tire monitoring system?
I've got a 1969 overlander, I'm towing with an f250 diesel. I'm in the market for new tires on both tv and tt and I am seriously considering adding a tire monitoring system. Just want to know what you guys feel is the best brand and what I should look for.
Noco is offline   Reply With Quote
Old 06-16-2013, 06:39 AM   #2
1985 31' Limited
Nellysford , Virginia
Tire Monitoring Systemk
I use Pressure Pro and like the system. I have two trailers (travel and car hauler) and can move the monitors from trailer to trailer. Kinda pricey but good quality. You will get a bunch of different opinions;check the literature yourself and make your own decision.
Ron
RTurnConn is offline   Reply With Quote
Old 06-16-2013, 08:58 AM   #3
SteveH's Avatar
Common Sense , Texas
Good info on Tire Pressure Monitoring Systems here:
http://www.airforums.com/forums/f438...ms-102451.html
Regards,
Steve
Old 06-18-2013, 04:41 PM   #4
Airstreamer67's Avatar
PressurePro has been working for me since 2006 and has saved me several times from ruining a tire and potentially damaging my trailer. My batteries are the original ones, but I suspect I'll be getting some low-voltage signals any day now.
Airstreamer67 is offline   Reply With Quote
Old 06-24-2013, 10:03 PM   #5
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Hawkshead for me, saved my bacon back when I was running ST tires. No more ST's, now have LT's. Still using the Hawkshead system, but sure not as worried as with the ST's.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 06-24-2013, 10:12 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
I'm the system.
Hi, I visually inspect all of my tires at every rest stop, every gas stop, and every camp ground. [works for me] I don't need or want another gadget dangling front of me while driving.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-24-2013, 10:24 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I bought 16" Michelin LT tires and scrapped the clunky TPMS. Like Bob, I check the tires at every stop, and don't like gadgets.
doug k
Old 06-25-2013, 05:40 AM   #8
2012 27' Flying Cloud
San Angelo , Texas
Tire pressure sensor value
I've been running a Pressure Pro system on one of our trailers since 07. I've gotten early warning of pressure drops while rolling on two occasions. The last one, a tread separation issue, occurred on a cool spring day about 60 miles after trip start. Tire (2 1/2 year old tire) had been inflated to spec pressure and inspected closely for any sign of problem prior to departure with no, repeat no, indication of a potential problem. As it was, the tire alarm went off when the tire pressure had dropped 10% from inflation value and I had the rig stopped on the side of the road at 30lbs and going down. As far as I'm concerned, visual inspection won't save you all the time. Gadget or not, they work. No different than a fuel gauge or engine/transmission temperature. But, each to their own.
Jim A is offline   Reply With Quote
Old 06-25-2013, 06:25 AM   #9
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We have a Hawkshead, too. We bought a TPMS after having a flat on our brand new trailer. It wasn't the tire's fault. We somehow got a large bolt in the tire. We didn't know we had a seriously low tire until someone pulled up next to us and started gesturing madly. When we got home we ordered the Hawkshead based on comments here in Airforums.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
