Old 08-19-2012, 09:34 AM   #29
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
We had a bias tread Carlisle tire with only a few thousand miles on it.... it was actually defective and just came apart while driving the Interstate... bent part of our Airstream in the wheel well and trim area... We went to the tire dealer and they tried to get Carlisle to replace it for us at least.... no joy, they wouldn't accept any responsibility. We changed our tires as soon as we returned home.
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson!
My blogs: http://yrekahistory.blogspot.com
http://siskiyoucountycamping.blogspot.com
http://campingalongi-5.blogspot.com/
CaddyGrn is offline   Reply With Quote
Old 08-19-2012, 09:39 AM   #30
2008 23' Safari FB SE
Boulder , Colorado
Originally Posted by perryg114 View Post
Fortunately the safety margins on car tires are better than on trailer tires so if you are right at the max load you should be ok. I would keep track of tire temps and if they start running hot slow down. Mine are always cooler than the tow vehicle tires. You can use that as a guide. If they start getting hotter than the tow vehicle tires slow down or pull over till they cool off. If the tow vehicle tires get around 200 F I would let them cool as well.
Perry
Perry - what device do you use to monitor tire temps? Can you provide an Internet link?
Great thread - we are due to replace our tires so appreciate this one!
bonginator is offline   Reply With Quote
Old 08-19-2012, 10:03 AM   #31
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
You can get the 235 in a XL rating that is higher than a standard car tire. It is also wider so it can carry more load at lower pressures. I think the Michelins in 235 XL would be a great tire for your trailer. Getting an IR thermometer can make measuring tire temps easy. When the tire starts getting near 200F you need to back off and slow down. You can also use it to adjust pressures. When the temp in the center and sides is the same you are good. When it is hotter in the center too much pressure and hotter on edges means too low pressure or overloaded tire.
Perry
Checking tire temps with a IR thermometer is a great idea. However, if you don't stop that often, it might not be checked in time to save a problem. Although the expense is greater, I believe that a TPMS that also measures temperature is by far a surer way to stay out of trouble. It certainly gives me piece of mind while driving.
Ken
Old 08-19-2012, 10:18 AM   #32
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
I absolutely believe carlisle ST (trailer) tires should be considered a defective product. We are just 2 months out of warranty. I hope anyone who googles carlisle tires find this thread and doesn't buy them.
The blowout caused the same damage on our trailer. I'm going to take a pic and post it. I'm thinking im going to have to file an insurance claim for this. thoughts?
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 08-19-2012, 10:33 AM   #33
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
[QUOTE=bonginator;1190582]Perry - what device do you use to monitor tire temps? Can you provide an Internet link?
I'm a fan of carrying an IR thermometer and find many uses for one, but my Dill TPMS monitors PSI and internal tire temps reporting to a display on the dash or windshield pod mount. PSI is displayed on a continuous rotation to see temp you push and hold a button. Hi temp will sound alarm. I have had tire issues too and not looking forward to any more.
IR thermometer uses:
AC Check
Cooling system on truck check
Tires, brakes, hubs
Last trip I even used it to find a hot 120V 30A pedestal connection. Their plug was toasted. I even used it to check my 120V circuit breaker temps looking for trouble.
Check temp on a closed charcoal or gas grill
List goes on and on
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-19-2012, 10:34 AM   #34
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
this was the damage the blowout caused.
yes, thats a chicken butt in the background. my apologies.
Old 08-19-2012, 10:54 AM   #35
Ag&Au's Avatar
That's Nasty.
The damage, not the chicken butt. The chicken butt's kinda cute.
Ken
Old 08-19-2012, 11:23 AM   #36
Ag&Au's Avatar
There are about a gazillion tire threads on Airforums. I think I've read more than half of them. There are even threads extolling the virtues of Carlisle tires. After digesting as much of those threads as I could, I have come to one conclusion. Some brands are better than others,and some batches of the same brand are better than others, but, to put it in technical terms, ST tires suck.
Ken
Old 08-19-2012, 11:30 AM   #37
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I use tire minder. And it worked great. All wireless, and you don't have to replace stems..TireMinder Tire Pressure Monitoring System - Product - Camping World
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-19-2012, 11:34 AM   #38
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
To the use of IR thermometers and such... the tire pressure and tire temperature are a linear relationship... so simply measuring your tire pressure will tell you if something is overheating. Any more than a 10% rise and you've got something going on... under inflation to begin with, tire defect...
As for blow outs... I've read and read and read... I'm not convinced it is always a 'bad tire'... there seems to be a lot of failures after curb-strikes (if people recognize this happened, or will admit it). This makes sense to me, because you have maybe 4 tires that are at 80 to 90% shared load on a larger trailer, then you whack one of them into a curb and suddenly deform the sidewall with 200 to 300% of it's rated load. This would make a lot more sense to me than a tire just delaminating or belts breaking for no reason.
Take one of your old ST tires and TRY to destroy it. Pretty tough...
I'm sure there are some manufacturer defects... but after looking at lots of pictures of deformed tires, and noting the obvious curb rubbing damage to the sidewalls... I'm wondering if there isn't more to it.
Friday is offline   Reply With Quote
Old 08-19-2012, 11:42 AM   #39
Baltimore , Maryland
I am going to catch it for this, but I FRICKIN LOVE CARLISLE TIRES! It is what I have run my own trailer with for over 45k miles with out ever adding a single pound of air and they still look brand new(I do respect the 5 year rule). I replaced them this season with the exact same tire and look forward to another long life with the new set. I put them on every single clients trailer who asks me to put new rubber on. Some people swear by Michelin, some by Goodyear, I swear by Carlisle. A blow out can happen for a hundred different reasons and often it is the brand that is blamed. Carlisle tires were American made and then went to China. They now are back to being American made.
I have repaired damage just like in those photos a dozen times now. It has been caused by every tire brand you can name.
Now bring it on. Tell me how wrong I am...
PS. I just placed an order for a client Friday. He needs all four and wants a spare too. Yep, Carlisle...
Old 08-19-2012, 11:54 AM   #40
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
We went the insurance route... but the cost of the repair and our deductible... bottom line didn't get too far, still have a dent... We still think Carlisle should have replaced our tire because it was defective... but the tire dealer had the tire on the shelf for quite a while so Carlisle passed the buck, we didn't get any cooperation from anyone. But, won't buy Carlisle tires again....
Old 08-19-2012, 11:55 AM   #41
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
Originally Posted by 62overlander View Post
I am going to catch it for this, but I FRICKIN LOVE CARLISLE TIRES!......
ahh! now i see why you love carlisle! keep's the clients coming back!
::wink::
Old 08-19-2012, 12:22 PM   #42
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
I have run Carlisle ST tires for four years on our little Scotty. This included a trip around the entire perimeter of Florida in July (from Pennsylvania and back) and I have never had a problem, and like you, have checked but never added air.
I need someone to explain to me their disdain for ST tires as they are recommended (especially for single axle trailers which my Scotty and AS Bambi are) for sidewall stiffness to keep the trailer behind you and in a straight line. What is the deal with ST hatred?
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
