06-12-2014, 07:16 PM
1961 24' Tradewind
1967 26' Overlander
Savannah
, Georgia
Tips for towing a barn find
I am picking up our new project on Monday, a 1961 Tradewind. It has been sitting for pretty much the last 15 years on a farm as the office, guest house, playhouse. Fairly solid and nicely original. I am taking a set of brand new rims and tires with me, have an appointment to have the bearings packed and will be pulling it with my Mercedes ML320 diesel with an Equalizer 6000 hitch. Also have my temp towing lights ready. What kind of tips do people who have pulled a barn/yard find have? We are moving 300 miles across Illinois - long and flat. I know not to go above 80 mph (kidding), but have never pulled something this old, having sat this long, this far.
06-12-2014, 08:26 PM
1967 22' Safari
MILAN
bearings/axle
Stopping a few times to check the axle spindles for heat would be indicated here. You sure don't want to shear off a spindle/wheel while towing at highway speeds. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
06-12-2014, 08:29 PM
Dazed and Confused
Hillsburgh
, Ontario
Go slowly at first with frequent stops to double check hitch on trailer for structural integrity and lights, as wiring may start to short out as vibration and rubbing damage it.
It's a good idea to have the separate light kit just in case, that you could mount to the back of the trailer and run the harness up to your Merc. I would probably run with them anyway instead of the trailer ones for peace of mind until you could look over the wiring condition.
It certainly looks like you have this well under control, kudos to you for using your God given common sense.
Goodluck and remember she may need some time to get use to moving again, so take easy and arrive alive.
Cheers
Tony
06-12-2014, 08:43 PM
1965 17' Caravel
San Antonio
Agreed, do the first few miles below 40 mph. Stop, check spindles, tires and hitch (everything actually, my last trailer the blackwater tank fell out a hundred miles from home on its maiden voyage). Have a chase vehicle if possible, with walkie talkies. Be patient, take your time, drive in low traffic hours and roads etc.
06-13-2014, 07:55 AM
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland
, Maine
Also:
- Top vents and astrodome should be fully closed and either zip tied and/or wired to fixed brackets. Do not trust that lifters will work.
- Bring cord or rope to tie door knob to entrance door handle in case latch is worn of faulty. This also goes for the refrigerator and all interior cabinets and drawers.
- Remove any contents from above compartments and place on the floor.
- Remove all snakes, four and eight legged creatures either alive or dead.
Good Luck!
Gary
wbcci #3363
VAC - Region 1 vintage Club rep
New England unit
06-13-2014, 08:11 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Rescues are fun. Just use common sense. Tow it like its a 1961 sitting for decades.
Take photos or it never happened!
Best of luck
06-13-2014, 08:56 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Be nice if the brakes and breakaway switch are hooked up. You will need a good battery in the trailer for the brakes. Should check them for function when the bearings are done. The wire connections corrode.
1966 17' Caravel
Newport
, North Carolina
A sign for the back window that reads "towing a 53 year old trailer that has sat for 15 years so back off!" And check the hubs for heat and the front frame for cracks or damage!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
06-13-2014, 09:21 AM
Overland Adventurer
2009 34' Panamerica
Telluride
Another sigh in the window requesting any parts that fall off please be returned to me when you next see me pulled over on the side of the road. (Yes you laugh)
06-13-2014, 10:01 AM
1967 26' Overlander
Bugtussle
, Oklahoma
Check the top
Make sure the AC shroud and everything else on top is secure. Towed my "out in the field by the edge of the woods find" home about a month ago. It's a '67 Overlander that I'm now in the process of gutting and fully renovating. Anyway, about a half mile into my journey on a two lane country road, I went over a small bridge with a rough transition from the road. The trailer bounced hard and exploded rust and rodent debris everywhere! Watched my AC shroud disintegrate as it bounced down the road. Thank goodness I was the only vehicle on the road at the time. The next bump was not so bad.
06-13-2014, 10:39 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Carry tools for small problems. I always carry a hand drill a hand riveter and rivets. Belly pans are a problem on these recoveries. I carry wire and zip ties too. Don't forget the duct tape.
06-13-2014, 10:28 PM
1965 17' Caravel
San Antonio
Rolls of Gorilla Tape.
06-14-2014, 04:24 AM
Overland Adventurer
2009 34' Panamerica
Telluride
I just watched a YouTube bit on a Guy who discovered you can heat layers of Gorilla tape with a torch, then tap and die or machine the stuff. Its up there with JB Weld on the side of the road!
06-15-2014, 05:51 AM
Dazed and Confused
Hillsburgh
, Ontario
One of the mods should make this thread a must read sticky at the top of the portal for people pulling God knows what, out of God knows where.
06-15-2014, 10:29 AM
1961 24' Tradewind
1967 26' Overlander
Savannah
, Georgia
Great, great tips. Leaving in about two hours for the drive over. Will pick up the trailer in the morning. Will take pictures and report!
06-15-2014, 10:45 AM
1967 22' Safari
MILAN
Where?
beatrix, I know you have stated that you will be moving this trailer across a distance in Illinois. Would it be revealing a secret to know where from and where to? Are you towing it to Georgia? Inquiring minds want to know!!!! Ed
06-15-2014, 08:26 PM
1961 24' Tradewind
1967 26' Overlander
Savannah
, Georgia
Sorry for the confusion! Savannah in the winter, Indianapolis in the summer - or at least that is how it is supposed to work if my clients/work would cooperate! The trailer is coming to Indy. My Overlander is in Georgia (waiting to be finished). Spent half of Friday clearing it with Zoning and the historic review board that I can put the Tradewind in the back yard to work on it. A couple of neighbors will not be happy. Will report back tomorrow, fingers crossed!
06-15-2014, 08:53 PM
Dazed and Confused
Hillsburgh
, Ontario
Goodluck, and remember to keep the rubber side down, shiny side up and the car ahead of the trailer……
06-16-2014, 08:55 PM
1961 24' Tradewind
1967 26' Overlander
Savannah
, Georgia
Made it home to Indy with the trailer. Hauled like a dream! Really rocky start to the day, but it all worked out. Will post more under the early Tradewind group tomorrow! Really appreciate everyone's tips - they actually came in very useful!
06-16-2014, 09:16 PM
1967 22' Safari
MILAN
Glad you made it with no real issues. Ed
