Old 12-16-2018, 06:29 PM   #1
1994 34' Excella
2002 25' Classic
Raymore , Missouri
Time for a new TV - Tundra or Sierra?
So we have a 03 F-150 currently with 95k on it. I decided we need a new truck when the brakes went out while towing our 25ft classic. We were coming off the highway when they went out. Only thing that saved us was the brakes on the trailer. That has been the only time that I've really been shook up while pulling. Ended up the hydraulic line running to the rear had been rubbing on the frame all these years and finally broke. Lost all pressure. Peddle went all the way to the floor.
I've really been looking at the 1/2 ton 2018 sierra. I really like the looks of it. And I've towed with my dads 2015 duramax. I fell in love with the built in trailer brake control.
I stopped by the Toyota dealer tonight. The new tundra isn't bad either. And we have had good luck with our Camry.
Anyone tow with both? How does the built in trailer brake compare?
walker77 is offline   Reply With Quote
Old 12-16-2018, 06:33 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I can not say anything about the Sierra, but I am very pleased with my Tundra. It is my 3rd Tundra and they have all been extremely reliable.
Richard
Old 12-16-2018, 07:39 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
you may want one with the new Trailer support
the ford f150 has that option.
may be ram 1500 also
i don't know of others
some have said that the new trucks with built in WD are still not as good as the aftermarket products
that's too bad
waninae39 is offline   Reply With Quote
Old 12-16-2018, 08:00 PM   #4
2017 30' Flying Cloud
Pleasant City , Ohio
Just purchased our first Tundra, a 2019. Only made a few tows, but so far the trailer brake worked as it was supposed to.
KCCO is online now   Reply With Quote
Old 12-16-2018, 08:58 PM   #5
2017 28' International
Baileys Harbor , Wisconsin
Either one would work. My son-in-law has a tundra and loves it. I have an 2017 F150 and love it. Tundra probably not as good on MPG as the Sierra due to the GM technology of shutting down pistons when cruising for every day driving. Not sure how much that is a concern for you.
Daquenzer is offline   Reply With Quote
Old 12-16-2018, 09:11 PM   #6
AirUSN's Avatar
2013 25' FB Eddie Bauer
Bonita Springs , Florida
My vote - Ram Crew Limited, 4x4, 3.92 rear, Hemi - non eTourqe -
Just under 4k miles - 3,500 tow miles and love it.
Warranty appt to check infotainment system for some reason my Apple CarPlay won't initialize other than that - smooth, quite, powerful - and looks good doing it. The interior is top notch in the Limited as well as lower trims as they did a great job.
Now, I'm coming from 10 year relationship with Land Rover/Range Rover and 5 vehicles in that time frame. I also had a '14 Ram EcoDiesel and not one issue in 22k miles (2 year lease)
Any questions just ask!
Good luck with your search!
ID:	329800   Click image for larger version
'13 Eddie Bauer 25'
'19 Ram Crew 4x4 Limited
Realtor w/Keller Williams, Fort Myers, Naples area and beyond, SL3388777
AirUSN is offline   Reply With Quote
Old 12-17-2018, 09:38 AM   #7
1994 34' Excella
2002 25' Classic
Raymore , Missouri
Im not interested in a Chrysler product. I've known too many people that have had major issues with theirs. Out of all of them I do think dodge has the best looking truck.
I think I'm going to check out a tundra some time this week. Its pointless to make a decision until I drive one.
Thanks for all the help!
Old 12-17-2018, 10:00 AM   #8
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Sierra ?
Hi,
We pull a 25ft Intnl CCD with 2014 Sierra crew 5.2 4x4 Denali 1488 payload but may recommend either the 1500 with 6.2 or the 2500 preferring Denali trim.
Having 4 Range rovers over the years as reference point and like the GMC fit/finish and quietness. TT is 5300dry/6300 wet 800 tongue. Your classic is 1000 lbs + more ?
Towing up steep grades we can hold at 60 loaded up at 3000-3200 rpm.
Always wondered how much easier if we had that higher HP corvette engine (that seems to net same mpg as the 5.2).
Our 1500 on left and a 2500 on right.... Lots of choices !
ID:	329830   Click image for larger version
Vantair is offline   Reply With Quote
Old 12-17-2018, 10:11 AM   #9
SailorSam205's Avatar
Northville , Michigan
I've pulled my 7000 lb SOB with both a 2016 and now a 2018 F-150 with the 3.5 EB. Engine has more power than I've ever needed and easily holds 65 MPH on 12% grades. Integrated brake controller has worked flawlessly on both with over 18k miles on the road. The adaptive speed control is especially nice on longer drives.
Only complaints I've had on the trucks were the nanny warnings - door ajar, you left the truck with the engine running, etc. These were particularly annoying while hitching or unhitching. Picked up a gizmo and downloaded Forscan to update the computers and turned off the ones I don't like. $25 later, I have no other complaints. One other nice setting - you can't shift my truck into gear if the key fob isn't inside the truck.
Al
2017 26' SOB, 2018 F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 12-17-2018, 10:24 AM   #10
StreamNTyme's Avatar
2007 25' Safari FB SE
Carolina Low Country , South Carolina
Images: 27
Proven, buy American.
Ford is best for safety. F 150 or F 250.
Foreign are the worst for safety. Safety should be your first concern.
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 12-17-2018, 10:25 AM   #11
2018 27' Flying Cloud
Atlanta , Georgia
Short answer. If you want the quietest cab experience, get the Sierra. If you want reliability, get the Tundra. I have a Tundra but road noise is noticeable. I knew this going on and still bought the Tundra.
jnm30327 is offline   Reply With Quote
Old 12-17-2018, 10:28 AM   #12
1972 23' Safari
Phoenix , Arizona
My vote is Nissan Titan XD. Love mine also love the 5year/100,000 warranty. Gas or Diesel. All bells and whistles are available. Built in trailer brakes work perfect. Also all American made!
Lensman is offline   Reply With Quote
Old 12-17-2018, 10:37 AM   #13
2019 27' Globetrotter
Larkspur , Colorado
2017 Silverado 1500
So FWIW...
We have a 2017 Silverado 1500 with the 6.2 (but not the heavy duty tow package, so only the 3.23 rear). We have a 2019 27' GT. Although we've only got about 1000 miles towing, I can honestly say that it was a very comfortable ride, plenty of power, felt stable (we have a Equalizer 4 WD hitch). Our 1500 is basically a Sierra in Silverado clothing.
D.
Dmmdtm is offline   Reply With Quote
Old 12-17-2018, 10:38 AM   #14
S/OS # 023
2005 28' Safari S/O
Indianapolis , Indiana
Toyota Tundra TV
We tow our 2005 Safari S/O 28' with a 2010 Tundra It has an aftermarket brake controller installed. We have towed 17K miles over the past 4 years including 2 trips through the Rockies, and a couple of runs through the Appalachians, and the Blue Ridge. We co-drive and many times go 600+ miles / day Extremely comfortable ride and tows like a dream. The only downside to the tundra is a well documented average 10 mpg while towing. The Tundra is also my daily driver and - dependable, reliable, comfortable and versatile All of your possibilities will do the job -suggest you drive each of the trucks and see which ones speaks to you
PovIndy is offline   Reply With Quote
Our new 2015 GMC Sierra Denali Duramax 2500HD time2play Tow Vehicles 91 08-07-2017 07:05 AM
Any experience with the new 2014 GMC Sierra 1500? Pat Cassity Tow Vehicles 15 01-15-2014 11:35 AM
New time streamer, long time dreamer Wilburstream Member Introductions 25 01-12-2009 09:32 PM
Sierra Nevada Unit 2005 rally schedule SierraBreeze WBCCI Rallies & Events 0 11-10-2004 01:05 AM
Can My Sierra Denali Handle a 30' Classic SO Big Dee Tow Vehicles 74 02-26-2004 02:15 PM
