02-15-2016, 09:08 AM
2016 30' Classic
Lorton
, Virginia
Thoughts on Hitches for my rig.
Hello guys, I will be pulling a 2016 Classic with my 2016 Ram 2500.
I've been doing some research and believe I've narrowed my purchase to two combo's. ProPride 3P or a Blue Ox SwayPro with AirSafe.
I would like to avoid any brand thumping or all other hitches are junk because it's not what I own talk. Please keep any posts constructive and objective and let me know if there are any considerations I've missed.
1. Weight Distribution. I am expecting to roll around with ~1,000 lbs tongue weight. I will load heavier items towards the back of the trailer and lighter towards to the front to not go much over 1,000 lb tongue. From what I can surmise, both setups would accomplish this task the same.
2. Sway control. Obviously the 3P's geometry setup will be superior to the Blue Ox spring bar sway control. From my understanding, the Blue Ox controls sway by increasing the tension on the spring bar on the inboard bar, applying a force to try and bring the trailer back in line. The 3P's design will be superior in this aspect, but not sure if it would be so much superior to trump not having any shock force limiting.
3. Shock force. I'm a huge believer in limiting load transmittal and shock force propagation. This is huge in the aviation community. The AirSafe videos demonstrate how much work that thing does to keep the shock between TV and trailer to a minimum. From what I can tell, the 3P has no way to limit shock.
4. Price and weight. The 3P would be about $1000 over the cost of both a Blue Ox and AirSafe. The 3P is almost another 100 pounds heavier than both of those items together.
The 3P seems to give the best sway control, with weight distribution but with the penalty of cost and weight and basically no shock forgiveness. (I got an email from Sean at ProPride saying such)
The Blue Ox SwayPro and AirSafe combo would seem to give marginal sway control, with weight distribution but with excellent shock limiting. The cost and weight penalties are also lower.
What are your guys thoughts? Would you go with either of these setups or a completely different direction?
02-15-2016, 09:26 AM
Princeton
, New Jersey
My only exception to your comments would be don't loading your trailer to accommodate your tongue weight. Trailer tongue weight should be between 10 and 12% of the trailer weight. This is a universally accepted design criteria. Deviation from this design criteria results in a natural tendency to sway.
2004 Excursion 4x4
02-15-2016, 09:28 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard....
...our 25 Classic, 1200lb TW. W/1000lb bars. moving 660lb to str axle & 160b to trlr axles. Burb 2500, Hensley 3p, Reese V Tow Beast, no regrets & no weight penalty.
02-15-2016, 09:35 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We have pulled our Airstream 25FB's about 150,000 miles over the last ten years. We have had a Hensley Arrow hitch system from the beginning. We have been very satisfied with its performance. We have never experienced any trailer sway. Our Airstreams run at about 7,400# ready to camp with a 900# tongue weight.
That being said, if we were buying a new hitch system today, we would seriously consider the ProPride as it functions like the Hensley. The ProPride was not yet out when we bought our Hensley.
I cannot comment on the Blue Ox as I have never tried one.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
02-15-2016, 10:26 AM
2016 30' Classic
Lorton
, Virginia
Very true, but my comment was that I plan to keep the tongue weight in the 10-15% zone by moving heavier stuff to the rear and not the front. I'm actually worried about overloading the tongue, not under-loading it.
Originally Posted by moosetags
We have had pulled our Airstream 25FB's about 150,000 miles over the last ten years. We have had a Hensley Arrow hitch system from the beginning. We have been very satisfied with its performance. We have never experienced any trailer sway. Our Airstreams run at about 7,400# ready to camp with a 900# tongue weight.
Brian
For those of you with the Hensley's, do you ever wish for more shock absorption?
02-15-2016, 10:41 AM
2013 30' Classic
Greenwood
, Mississippi
I would go with the ProPride.
I am not a ProPride owner- only wish I was-
I endorse it because I honestly believe in the theory/principle/design.
All hitches are good.
Some are better.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
02-15-2016, 11:22 AM
Tom T
Orange
We've been using the Hensley Cub - their "Jr. Arrow" for a few years now on our much lighter & shorter (than your AS 30') 1960 Avion T20 20'-6" - which is Hensley's smaller unit for trailers up to 6000 lbs.
Our T20 is 3000-3500# wet & loaded with 542 lbs. HW including the 120 lbs. of the Cub + the PO's upgrade to 2x 30# LP tanks + 27 gals water (up from OE 20) at the front wall inside, & my Tekonsha RF trailer brake unit with custom steel mounting plate, all on/next to the A-frame - up from the listed 285# HW of the base trailer.
ProPride & Hensley Arrow will add about 180# to your HW FYI, so check your TV's & hitch's HW rating.
I'm very happy with both the excellent sway elimination & WD, as well as it being easier for me to set the WD springs with the wind-up jacks, & the whoe unit stays on the A-frame when parked - so no messing with greasy bars & storing them somewhere off the trailer at home.
I looked at all 3 of ProPride & Hensley Arrow & Cub, but the Cub was about $1500 on sale & all we needed, plus the PP's attachment wouldn't work well with our shorter vintage A-frame without loads of mods. & it was $1000 more for 10,000#/1000# rating which we didn't need. So for us the Cub was perfect, but won't work on your 30' AS.
I can't speak to personally towing with your other choice, but know many others using them who are happy with them, even if the sway control on them can reach limits of the friction or cam type anti-sway, whereas the PP & Hensley types are pretty much no limit & fully eliminates the sway - rather than counteracting it.
Although the PP & Hensley are multiples cost of the BlueOx, I look at it as cheap insurance on a $80-100k new AS (or an $18k vintage kin in my case), for no worries sway elimination + ease of use + easy driving.
However, if your decision is also to go with PP, then I'd suggest that you talk to both Sean at ProPride & Terry Powell at Hensley for both flavors of the 3P hitches, each company's story & best pricing.
Also, if you're modestly mechanically adept & have a helper for lifting the hitch head, you can install either PP or Arrow yourself, or have it done by your AS dealer.
Good Luck!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
02-15-2016, 11:28 AM
2010 30' Flying Cloud
Mocksville
, North Carolina
I have a 2014 Ram 2500 and Flying Cloud 30fb. I started with the Blue OX SwayPro and moved to the ProPride so I can appreciate your dilemma. I think the SwayPro is a good hitch, but my opinion (and experience) is that a 30' trailer pushes it's limits. I was never completely comfortable with it. My dad now uses my SwayPro on his 25' SOB and really likes it though.
I feel like the ProPride is much more stable on my setup and am happy I made the investment. I also think the new Ram 2500's with the coil rear suspension are pretty gentle on an Airstream, especially with a larger trailer that has a heavier tongue weight. My personal opinion is that it tows so much more effortlessly. I do not think it is that difficult to hook up, but even if it were it would not change my mind. I rather have a little trouble hooking up than any type of trouble at 65mph.
02-15-2016, 11:42 AM
Anna Maria
I started with the Equalizer Hitch, went to to Anderson and last year Switched to the Blue Ox.
The Equalizer had good performance both with WD and Sway but the ride was a constant rivet popper. The Anderson was a huge disappointment, difficult to get the WD set right and there is absolutely no sway control. That hitch is over hyped. The Blue Ox does everything it is advertised to do. Excellent WD and great Sway prevention and ride is smooth.
Pulling a 2013- 30' International with a F-150 Ecoboost.
02-15-2016, 01:19 PM
2016 30' Classic
Lorton
, Virginia
Thanks for the input guys. Yes, if all I cared about was weight distribution and sway, I'd get the ProPide in a heartbeat. But it has no shock control.
My Ram 2500 does have rear coil springs though.
I'm just wondering if the Blue Ox with AirSafe would be a more "rounded" hitch package when considering Anti-Sway, WD and shock resistance. Shock resistance is very important to me as I plan on having this Airstream for a long time and don't want it to get beat up.
02-15-2016, 01:30 PM
Santa Rosa Beach
We towed Old Lucy (2005 Safari 25FB) about 110,000 miles with the Hensley and never experienced any issues relating to the trailer getting beat up. We have had three tow vehicles, a 2004 Suburban 2500, a 2005 Suburban 2500, and a Silverado 3500 Duramax.
Brian
02-15-2016, 02:34 PM
Walnut Creek
BO user for exactly the reason you are discussing. Delivers a nice soft ride. Having said that, if I had the weight capacity for another 100#s on the receiver, I would look very closely at the force projection hitch.
There is a concept presented on either the Reese or Equalizer hitch thread that suggests a lighter bar is better ride for the trailer as TV stiffness goes up. It is referenced in the BO thread. Does this work with the PP or Hensley as well?
Good luck with your inquiry. Pat
02-15-2016, 03:21 PM
2016 30' Classic
Lorton
, Virginia
Ya, the problem with force projection though is no shock reduction.
I've contact both AirSafe and ProPride and both say there is no solution to connect a force projection hitch to the AirSafe.
I guess you could contract a machine/welding shop...
02-15-2016, 03:55 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
"For those of you with the Hensley's, do you ever wish for more shock absorption?"
We have had problem with our 2500 Burb, it does have the Autoride active suspension and I use 1000b wd bars with the haha.
Using the 'softest' bar that transfers the weight needed will contribute a lot towards softer ride.
If you install the ppp yourself you'll learn everything you need to know about the care and feeding, not difficult at all.
02-15-2016, 04:16 PM
2016 27' Flying Cloud
Olympia
Dear Zybane,
I'm pulling a 2016 27 FB with a 2015 Ram 2500 diesel + Blue Ox Sway Pro; so far, that combination has worked well for me.
Impressed by their videos, I've been debating getting an Air Safe Class V.
Please see:
http://www.airforums.com/forums/f238...le-146495.html
in which I asked for comments on whether or not getting the Air Safe was substantially worthwhile. You can read for yourself the 40+ comments posted so far. Bottom line: some yesses & some nos.
This past week, Air Safe had a 10% discount on orders, so I broke down & ordered one. What was not disclosed in the sales information is that there is a $100+ shipping & handling charge. So even with the 10% discount, the Class V Air Safe + the WD attachment was $1,130, so I canceled by order. Now, without the discount, it's around $1,250.
While I accept that some others believe the Air Safe with my rig (namely, a recent Ram 2500, with coil springs --- and I have also added Firestone Air Bags to it) might be worthwhile, at this point, I'd like to put a few more miles on the rig & make some discerning observations before plunking down over $1,000 for an Air Safe. If you proceed with getting one, I'd be interested hearing your observations with it.
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
02-15-2016, 04:24 PM
2013 30' Classic
Greenwood
, Mississippi
Is it not possible to have AirSafe and ProPride together?
TAC #MS-10
Airforums #70955
2012 25' Flying Cloud
Battle Lake
You would defeat the benefit of a Projected Pivot Point hitch by adding an AirSafe, even if possible. The Hensley/Propride design moves the effective pivot point of the trailer forward near the rear axle, taking away the leverage of the bumper located hitch ball to transfer yaw forward to the steering axle. The AirSafe would position the Hensley/ProPride (and effective pivot point) about a foot farther aft, ruining what you paid good money for.
Nor do you need the AirSafe if you study the causes rather than the Band-Aid to reduce shock transmitted through the hitch to the trailer. Heavy truck suspension rate, heavy rear differential and axle without enough shock dampening, heavy loads in the rear of the truck bed, rigid sidewall tires with higher than needed air pressure, heavy loads in the front of the Airstream, weight distribution bars without good flexibility, poorly adjusted weight distribution hitch are a few that come to mind. And then the trailer tires, too stiff sidewall (more than factory OEM), excessive air pressure for the load, and maintain good shock dampening on the trailer as well.
Doug and Cheryl
02-15-2016, 04:34 PM
2012 27' Flying Cloud
W
, New England
I have an email from Sean saying the airsafe COULD be used with a ProPride but that didn't mean he recommended it.
To the OP - since shock control is most important to you, it sounds like the BO/AS combo is your best choice.
My #1 interest was preventing sway which is why I went w/PP.
Knowing what you want and that there isn't a single perfect choice - you should be happy with your combo. Go camping and enjoy!
02-15-2016, 04:42 PM
2013 30' Classic
Greenwood
, Mississippi
So...
My goal should remain what it has been-
Hold out for a ProPride-
TAC #MS-10
Airforums #70955
02-15-2016, 06:08 PM
2016 30' Classic
Lorton
, Virginia
Ya, Sean at ProPride said he has no way to connect the 3P to the AirSafe.
Interestingly, I've been speaking to one of the techs at Blue Ox about connecting the SwayPro to the AirSafe. He said it is not recommended as they will "fight" against each other.
I explained to him the dozens of AirSafe users out there using WD systems with good results with the AirSafe. He says the Blue Ox Swaypro doesn't use cold rolled bars, but heat treated spring bars.
I guess I don't get why that would matter if both are providing the same forces at the same points? I'm not sure that I buy that the SwayPro and AirSafe would lead to sway. I think they would make a great combo.
Any thoughts?
