Old 09-07-2018, 06:40 AM   #41
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I see your point, but at some point a black tank flush hose is gonna meet with the campgrounds water supply. I could buy a fresh hose every time I need to flush.
But I do see your point. I guess we all need to dip the campground spigot into clorox before using for this reason. I'm not being facetious as a previous camper (and in this case me) may have used a hose dedicated for black rinse. Maybe in this example, my Y actually protected against this problem.
x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
turk123 is offline   Reply With Quote
Old 09-07-2018, 06:50 AM   #42
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Yup, agree all. My routine is flush supply spigot, slather with hand sanitizer, flush, hook up potable hose. After using the black water flush hose, do same for my potable reconnect or the next guy. I might be wasting a lot of hand cleaner, but I'm following the "prescription" .
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 09-07-2018, 06:58 AM   #43
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Never thought of using hand sanitizer. I guess since I never had a problem before, I just didn't think of this. It's probably not what most would do, but I think I'm gonna get out the sanitizer on the next trip. Since the point of possible contamination is not closely connected in time to the next time you have the "runs" you can never be sure this wasn't the cause
Good catch. It all makes good common sense.
Old 09-07-2018, 08:49 AM   #44
Long Island , New York
At a bare miniumum, we run the CG hose bib for a minute or so, to clear out any lead-based solder residing in the pipes coming from the city water or well-based pressure tank. Lots of old systems contain lead solder.
Then reduce the water flow, and cup one hand over the end of the hose bib, so that you are rinsing the threads off very well. You can even "scrub" the threads with your clean hand.
Additional steps like bleach or hand sanitizer optional!
Peter
Old 09-07-2018, 02:25 PM   #45
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The weight of all my stuff!
The relationship between how we dump and what it weighs is...? 😂
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you can’t."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 09-08-2018, 08:14 AM   #46
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The fact that they apparently don't work as plumbers and thus don't have all those big heavy wrenches to carry as part of their load. If you panic at the thought of a rinse hose, you *don't* want to ask a plumber about his routine daily chores ....
Old 09-08-2018, 10:44 AM   #47
2007 22' International CCD
“It ain’t all water”
Old 09-08-2018, 12:55 PM   #48
Umm..how much heavier is a full BT vs a full FWT.
We need a Wastewater Engineer. 🤓
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 09-08-2018, 01:43 PM   #49
Half a Rivet Short
Hi
If you are sensitive to the idea of a black water hose being here or there ..... avoid bringing this topic up with a plumber when you have just eaten. They deal with both water into and water out of the house on a *very* regular basis. So does the roto-rooter man and the septic tank pumper guy. They all have a number of very graphic / gross / funny stories to tell. None of them seem to have died (or even gotten sick) from the many experiences ....
Old 09-09-2018, 10:40 AM   #50
Obviously-NOT
Kalispell , Montana
Well, if it floats, it's lighter than water, but only floats because it displaces some water, so 5 gallons of BT feels about the same as 5 gallons of water, when schlepping to the recently install septic clean out fitting. Is also interesting what is in BT fluid that never dissolves, digests, or disintegrates.
Old 09-09-2018, 10:43 AM   #51
Obviously-NOT
Kalispell , Montana
Okay, yes you can have a cement boat that floats due to configuration, but is heavier than the water it displaces if sunk. Haven't seen that in any 5- gal buckets.
Old 09-09-2018, 11:22 AM   #52
turk123's Avatar
2019 30' Classic
Canfield , Ohio
New developments!
Well, at the blink of an eye, we've added (or was it my wife!) at least a hundred pounds more. We've decided to take some of her craft equipment and a newly purchased portable printer:
https://www.amazon.com/Wireless-Mobi.../dp/B00NV9LL9Q
And I've added a few tools and a cast iron Lodge pan. My drone is going and my camera gear and GoPro. Still under the 2200 lbs., but counting up!
Old 09-09-2018, 11:54 AM   #53
Anna Maria , Florida
Hi
I have spent my working life (40 years) installing pipes in Chicago and the Chicago Metro area. Water, Sewer, Storm, treatment plants and renovation. Lot of it was removing old decrepit sewer lines and in all those years I never had one incident of any of my employees getting ill from handling waste contaminated materials. And let me tell you some of them where doozies.
Like when they were in the process of connecting a house sewer to the newly installed main and someone would flush a fully loaded commode in the house.
And never wore hazmat suits either. The most dangerous world is a totally antiseptic one.
franklyfrank is offline   Reply With Quote
Old 09-10-2018, 08:45 AM   #54
Half a Rivet Short
Hi
We went with some crazy french made pans that have removable handles on them. They are aluminum so not crazy heavy. Not having fixed handles makes them *way* easier to cram into drawers. Like many aluminum objects, very much *not* the low cost option
One "counter force" to the creep in loading of the trailer is a occasional ( yearly, monthly ... weekly ... ) run through and throw out process. More or less - if it's not been used ... why have it on the trailer ... Each time I go through, I find this and that. It's always a "what was I thinking ???" sort of thing when I spot an item.
Old 09-26-2018, 08:27 PM   #55
turk123's Avatar
2019 30' Classic
Canfield , Ohio
We’ve done that also especially as we transfer to new trailer. Everything we have for the trailer is bought for the trailer. My wife will not bring our coffee pot from home or anything else and move it to the trailer. That way we do not have to pack to go on a trip. it’s all in the trailer ready to go.
What is all the wiring and stuff on top? Interstate65 Sprinter and B-van Forum 6 08-08-2018 06:52 AM
Advice: Where should all this spiffy electrical stuff go? daleyocum Electrical - Systems, Generators, Batteries & Solar 3 05-08-2018 05:22 PM
That time when we sold all our stuff and lived in a tin can... KristinS Full-Timing 22 07-24-2013 09:38 PM
Anti-Hoarding/Paring down Stuff & Weight Foiled Again Full-Timing 11 07-09-2013 06:08 PM
