Old 03-26-2019, 07:18 AM   #29
mikesSE's Avatar
2007 23' Safari SE
ROSWELL , Georgia
Images: 14
With the guy building my Suburban in Atlanta,you could use your 2500 as a donor and he will supply the Suburban 2500.Lookup DuramaxSpecialties in Woodstock Ga, on his facebook page.
Mike & Nancy Gore WBCCI #2914 S E Camping Unit 012 Roswell,Ga.
mikesSE is offline   Reply With Quote
Old 03-26-2019, 07:23 AM   #30
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
The Ideal Tow Vehicle Would Be....
I like the previous 'paid for' but If I could choose, I'd love to have a rear wheel drive Dodge Ram dually, mega cab. Rear wheel drive, lower center of gravity. I'd like to try a non 4x4 for a while
have a good one
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 03-27-2019, 10:29 AM   #31
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Lets get ready to RRUUMMBBLLEE!!!
Oh my, another Tow Vehicle thread. I feel like these are done by bots just to get people going.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 03-27-2019, 11:17 AM   #32
Oakville , Ontario
Originally Posted by Rounder44 View Post
Howdy!
In the market for new truck and my 4x4 back ground has me biased for well... 4x4's! May not be the best type of truck but probably what I'll end up with.
That said what are some of the basics a tow vehicle should have?
Things such as:
Wheel size; small or large
Lift: low or high
High profile or low? Is it better to be blocking for AS of slipping under...
Drivetrain: 4x4, 2x4
Suspension: off road or street performance. Stiff or stiffer!
Automatic vs. manual. I found a model I like with manual and it has a higher tow capacity! I thought a clutch would lower it..
How much over tow weight is ideal? For instance towing a 5000 lb Airstream would you notice a difference with a truck with a 6500 rating vs a 12000 tow rating?
Not worried about brands or reliability or deals per se just the basics as a shopping tool.
Rounder44
Any truck can tow an airstream, the real question is what do want it to feel like when not towing, a 2500-3500 truck is going to feel stiff and tough until it is loaded down, a 6000 lb airstream isn't going to ever load that down.
See Hitch Hints CanAmRv.ca Andrew is the towing Master at set up and.adjustments
Ultraclassic is offline   Reply With Quote
Old 03-27-2019, 11:19 AM   #33
2018 30' Classic
Jacksonville , Florida
Paid off.
Overstreet is offline   Reply With Quote
Old 03-27-2019, 11:43 AM   #34
2007 22' International CCD
Amen to that! Thatís the kind Iím driving right now!
Old 03-27-2019, 01:35 PM   #35
1989 34' Limited
Carmel , California
If you're considering the land Cruiser I would also point you in the direction of the Sequoia. It is the same chassis as the tundra and land Cruiser but has the independent rear suspension. It also comes with air suspension if you want it, but I would t hi ink twice as the repair costs for those systems can get pricy. It also has 4x4 available and a center locking diff with low range. It does use the electronic locking system for the front and rear lockers which isn't as good but is far better than nothing. As an added benefit the current design hasn't changed since 08 so good used ones are available for a reasonable price.
I'm a bit biased as this is the vehicle I chose 😉
RedBearded is offline   Reply With Quote
Old 03-27-2019, 10:47 PM   #36
1998 31' Excella 1000
Simpsonville , South Carolina
Originally Posted by out of sight View Post
I tow my 28 alternately with a 3.0 diesel or a 6.7 L diesel. The 3.0 L is more than enough with 455 ft-lbs of torque. A 6.7 L diesel is overkill but it's definitely cool.
The 3.0 L & 455 torque maybe a Ford F-150 ???
sctinman44 is offline   Reply With Quote
Old 03-28-2019, 06:51 AM   #37
Oakville , Ontario
Originally Posted by PKI View Post
Ideal and available, unfortunately are different animals, because your prejudice and those of the market are influenced by the preferance of the OEMs, which is to make money.
Manual vs automatic - In the past, manual, hands down. You pick the gear and manage the change. They often had more gears available. However, the new autos (six speed to ten-speed) are very capable. Shifting on a curve was a very bad practice, but with multiple gears available, the shift change is less upsetting to stability and more effective at torque multiplication for best performance. So, if you are one of those folks who must be in control, get the manual. You will replace a clutch now and then if you are not an excellent driver, but the package is viable. If you are knowledgable enough to out think the computer, an auto will be a great solution. Some are even programmed to correctly chose the right gear before you think it's needed. Being a manual guy, I am amazed at the performance of today's autos. Try one, you may like it. I really do.
Blocking - simple answer. The lower the better, from both a profile and a center of gravity perspective. Unless you plan to spend a lot of time off road, lower ground clearance is better. Do not lift, lower the vehicle. Older designs are lower center of gravity and could be considered. TVs that meet, but do not significantly exceed, the required capacity are often lower profile and should be considered. Adjustable height suspensions are available on some vehicles and of value for dual use.
Capacity - only what you need.
Wheel size - smaller, but that is small sidewall. Tire size needs to be matched to load. Beyond that, the stiffer the sidewall can be, the better stability you will have. From a practical perspective, there is a limit to how low a profile is viable to keep pot holes at bay. A 50 series profile might be the line not to cross. The punt is simply the smaller rim and light truck 70 series tires.
Suspension - independent front and rear with wide track and rack and pinion steering. Stiff as to roll, but maybe not bounce and jounce. Assume stiff and not stiffer. Adjustable is even better.
4x2 or 4x4 - this gets more problematic. Best is 4x2 because it is more efficient and effective on paved roads. You may go to 4x4 if your use profile moves you to that decision, but understand that giving up best suspension to get 4x4 is a bad compromise. If you are getting stuck in a campground, you are staying at the wrong CGs. Disclaimer - we went with all wheel drive with torque vectoring to address bad weather travel issues. All a compromise as to best.
Brakes - best you can get. Upgrade over OEM is not a bad tactic. Exhaust brake is a consideration. Many find it saves the trailer and TV brakes. Note that trailer brakes must be applied to control sway. If you do not regularly practice that, an emergency event will not end well. Application of TV brakes in such an event is less helpful than some acceleration with trailer brake application. Bad weather TV only braking is not good either as the coach trying to pass the TV can result. So if exhaust brake use is contemplated, practice emergency actions until they are automatic rote.
Wheelbase - whatever will make a u-turn without backing and filling. Consider 120" to be the bottom of that range. Whatever length you chose, go for less overhangs and remove hitch shanks when not in use.
The ideal tow vehicle is one you own and use daily. The worst is one you have to buy and store until you tow your coach with it.
Good luck with your research. Go low and slow. Pat
This lines up with what I have learned
, Pat what's your rig?
Sorry in advance if your signature has this info ,I can't see it on my mobile app.using my phone
Old 03-28-2019, 10:58 AM   #38
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
UC - that would be this lashup, shown here just down from a trip over the Million $ Highway 550 down from Montrose, CO. Pat
Ideal tow vehicle for 16 AI GT twin riverdweller Sprinter and B-van Forum 21 01-03-2019 09:01 AM
Ideal tow vehicle? e5earley Our Community 2 07-04-2014 02:21 PM
Would these work on a tow vehicle? Silver Threads Tow Vehicles 5 10-07-2006 03:00 PM
What tow vehicle would you suggest? Kistler Tow Vehicles 63 09-27-2005 04:24 PM
What would the least expensive tow vehicle be? RVNUTTY Tow Vehicles 13 03-10-2004 09:48 PM
