Old 08-26-2016, 09:21 PM   #43
2016 26' Flying Cloud
Spooner , Wisconsin
My rig -- 2016 Ram 1500 and AS 26U -- were purchased before I got to the bottom of the distinction between towing capacity and payload and how the tongue weight of the trailer counted in the payload. I think both the Ram salesman and the AS folks did a poor job of explaining that. In both cases the people and literature talks only about towing capacity with no mention of the related limitation of payload.
My point is that AS should help its customers with this issue: put tongue weight in the literature, along with total weight, with an explanation of how it relates to the TV's payload capacity.
I do appreciate this conversation. I basically follow the speed limits and of course slower -- while towing -- for ramps and curves. I agree, slowing down is a safe move. However, sometimes you end up in heavy traffic going 70. Maybe this is going to kill me, but in these instances it feels safer to go with the flow (at 70) rather than be an obstacle in the road at 65. Trying to change lanes, which must be done from time to time, moving slower than the rest of the herd, is its own hazard.
WherryWillie is offline   Reply With Quote
Old 08-27-2016, 06:06 AM   #44
Gainesville , Florida
The gross weight is on the id tag on the exterior of the trailer. The tongue weight is readily available from AS.com and elsewhere. Hope this helps. One must do his own research, much info is only available that way. The forums is the best research tool available, do your homework on here and any info you need is available.
avionstream is offline   Reply With Quote
Old 08-27-2016, 08:12 AM   #45
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
This website has several airstreams (and other trailers) with lots of picture of the aftermath of towing accidents. www.iaai.com. Scary stuff that provides a lot of reasons to take an extra measure of safety when towing.
RAH is offline   Reply With Quote
Old 08-27-2016, 08:13 AM   #46
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
Have you checked?
I may be wrong regarding others, because I have not checked.
I DID check the owners manual for my tow vehicle.
It clearly advises not to tow at speeds over 65 MPH due to stability and the extra time it affords to react while driving.
Have you checked your owner's manual?
Yes we all know that a lot of that literature is done up by the lawyers. But try as one might, it will always be true that you, as a driver, have more time to react at a slower speed.
And while I agree that from time to time during a day's drive there will be occasions where one must speed up to meet a situation for safety, that is precisely why it is important to be at a safe "base" level that gives you the time to process information, and that you have marginal capacity to speed up if needed.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 08-27-2016, 09:17 AM   #47
Owners manual? We don't need no owners manual! Good point, most of the problems on the forums wouldn't be problems if people read their manuals.
Old 08-27-2016, 09:21 AM   #48
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
One of the things in the owner's manuals is the admonishment not to tow over 65mph, because the speed rating of ST tires is 65. Anything over that dramatically increses the chances of tire-related issues.
Old 08-27-2016, 11:11 AM   #49
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
FWIW, my trailer as it is equipped tows very, very, well behind both of my half ton tow vehicles.
Gradiens super tenui glacie.
Old 08-27-2016, 02:00 PM   #50
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We installed Kodiak 12" Dacromet Finish Rotors with Stainless Steel calipers on our Classic. Due to the lithium battery installation, the front battery box became the home for the electric/hydraulic brake pump. Not mentioned by the vendor was the complete incompatibility of the Brake Rite II pump with any truck's built recently. So the trip home was very challenging through the mountains.
We bypassed the Ram built in brake controller, a one wire modification, and installed the Tuson brake controller that plugs into the ADB port. That cured the erratic brake operation.
Going down mountain now, there is plenty of trailer brake available if needed. I set the cruise or select an appropriate gear in the transmission to control the speed with the Cummins exhaust brake system. I maintain several hundred feet of distance to the next vehicle since 19,200 pounds does not stop as fast as a motorcycle or car.
Note that using the engine exhaust brake is NOT recommended on slick roads.
Old 08-27-2016, 05:25 PM   #51
Good post, very informative, thank you.
Old 08-27-2016, 06:10 PM   #52
Piggy Bank's Avatar
2015 22' FB Sport
I was referring to the tow vehicle (Toyota) owner manual, not the trailer manual.
Do you know, are all trailer rated tires only rated at 65?
Piggy Bank
Old 08-27-2016, 06:21 PM   #53
Well Preserved
1993 21' Sovereign
All ST tires are rated at 65, unless specified otherwise on the tire itself.
Old 08-27-2016, 10:56 PM   #54
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Believe the ST spec requires tires built to that standard must have a minimum rating of 65 mph. Believe that some XT tires have higher speed ratings. My neighbor has a set on his boat trailer that are rated for 85 mph if I recall his saga correctly. Good luck - Pat
Old 08-27-2016, 11:50 PM   #55
Boxite's Avatar
2008 22' Sport
The new Carlisle HDs I bought are rated at 81 mph, but I'm sure not going to tow that fast. 65 is what is comfortable and good gas mileage.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-28-2016, 03:24 AM   #56
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Originally Posted by Jacob D View Post
If you want to tow faster than 65 you have no business on the road with other citizens.
but the most important thing is to know the limitations of yourself and your equipment and act accordingly even if that means not leaving the driveway.
Arbitrary rules are, well, arbitrary.
If your comfort and skill levels and condition of your equipment limit you to 65 mph that is perfectly ok.
But I disagree that your personal limit should apply to every one.
My AS never leaves my property. But I tow a lot with my equipment trailer. I keep it in tip top shape and have pulled it many thousands of miles. If the speed limit is 80 and road, traffic and weather conditions permit, I will drive it 80. And I would do likewise with my AS.
Why?
Because it's legal to do so, I'm comfortable doing so and I'm confident in my equipment.
I like driving my old
tractors. Some people wouldn't even get on a tractor if it didn't have ROPS (roll over protection system) ie, a roll bar and seat belt. Many people would like to make rops mandatory - even old ones like I have.
Myself? If I bought a tractor that had rops I would immediately remove it.
Why?
Because in many ways they're a hindrance. And, it's still legal to drive tractors without it. Plus, I'm comfortable doing so and I'm confident in my equipment.
Ultradog is offline   Reply With Quote
Anatomy/repair of LeDeux openers for the Hehr roof vent bjond Roof Vents, Skylights & Fans 49 12-01-2016 09:36 AM
Anatomy of a Dent Removal gdanderson Ribs, Skins & Rivets 3 12-15-2014 07:52 AM
Greys Anatomy Killo1 Off Topic Forum 4 07-11-2006 12:25 AM
accident bhsl8 General Repair Forum 73 09-11-2003 10:27 AM
