06-21-2016, 02:04 PM
2016 16' Sport
Dallas
Tesla Model X not recognizing 2016 Sport 16 hookup
Help!
I have purchased our second Airstream, a 2016 Sport 16, which is the right size for a Tesla Model X P90DL with 22" wheels. I have the tow package in the Tesla, and a Prodigy RF brake controller installed on the Airstream. Bottom line: the lights do not work on the Airstream, and the Tesla does not detect it (which is indicated by a blue "trailer mode" icon on the dash). Even if I manually engage trailer mode in the Tesla, the lights do not work on the trailer (running lights, turn signals, brake, backup). If I connect the Airstream DIRECTLY to the Tesla, it doesn't work either.
Some more info:
1. I have my own trailer connector tester, and the Tesla connector works fine, passes every test.
2. The local Airstream dealer has a different connector tester, and the Tesla passes all their tests too.
3. I do not have a brake controller installed, instead I have installed a Prodigy RF controller on the Airstream. Nevertheless, connecting the Airstream DIRECTLY to the Tesla (bypassing the brake controller) DOES NOT WORK.
4. The RF brake controller is successfully paired with the hand held control, which means that it is getting power and it registered the "c" for connect on the display of the handheld controller.
5. I connected my Tesla to TWO DIFFERENT BRAND NEW 2016 Airstream Sport 16s, with the same result, i.e, no lights working.
6. We have measured the output voltage of the tesla connector, and all appears within spec.
and finally.....
7. We connected the Tesla up to a Jayco Trailer, and the lights worked!!
8. We tried disconnecting the battery in the Airstream, but no success.
So what is different? The Airstream from 2015 model year up has LED lights. Does the Tesla not recognize a connection, because there is not enough of a current draw for the lights?
Has anyone here connected 2015+ Airstream to a Tesla Model X successfully? Or has anyone had issues like this with any other vehicles, specifically if the trailer has LED exterior lights?
Any other ideas? Many thanks in advance for any advice. I need to get to the bottom of this, because the ONLY reason we purchased the Sport 16 was to tow behind the Tesla for short local trips (< 100 miles), and obviously I wouldn't be caught dead towing it behind my Ram 2500....
06-21-2016, 02:18 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I'm sure all the Tesla owners will chime in.
Oh wait, maybe they already did.
An electric TV is the ultimate dream.
2019 Ford Expedition Platinum
06-21-2016, 02:37 PM
2016 16' Sport
Dallas
Well I know that someone towed what appears to be a Sport 22 onto the stage...
So there is at least one owner. Elon??
06-21-2016, 03:31 PM
I don't recall seeing anyone post here, but I know they should work because someone is starting a coast-to-coast trip across Canada. And there have been other installs.
I would pop one of the LED lights and wire in a dummy load to see if that increases the current and makes it good.
06-21-2016, 03:47 PM
2016 16' Sport
Dallas
Looks like this issue is not restricted to Tesla, but is fairly common with other cars too.... So I have ordered a CURT 57003 LED Trailer Light Adapter from Amazon and will see if that will solve my issue.
06-21-2016, 03:53 PM
Cuddebackville
, New York
[QUOTE=markdoane;1809456
I would pop one of the LED lights and wire in a dummy load to see if that increases the current and makes it good.[/QUOTE]
That has worked on other led vehicles. There is also an adapter that MB or VW or someone sells. The led vehicle and led trailer seems to be a recurring issue.
Other than that, I agree, ask Elon.
06-21-2016, 03:54 PM
Cuddebackville
, New York
On another note, I could help replying, given my avatar and your screen name.
06-21-2016, 05:49 PM
1973 21' Globetrotter
Houston
This problem is very common with other luxury/european brands. The problem is that the LEDs don't draw enough to activate the system, so it doesn't recognize the trailer and doesn't send the light voltage. Look at the solutions for BMW, Mercedes, and VW, and it boils down to wiring a resistor into the circuit.
etrailer.com sells what you need.
good luck
06-21-2016, 05:50 PM
Houston
And the inevitable question: how many miles can you go on a charge while towing?
06-22-2016, 07:49 AM
2016 16' Sport
Dallas
Thanks for the advice.
As for the range towing, it is utterly horrible, as expected. The Tesla has an extremely efficient aerodynamic profile, and the trailer obliterates that. Hills of any description would annihilate the range. But.... within a 100 mile radius of Dallas, I don't think we have to worry about hills!
However the Tesla comes with an adapter to plug the car into a 50A 4 prong RV outlet. So with a practical range of maybe 100 miles, as long as there is a 50A hookup at the campsite, it should be good. Of course, a regular 15A 110V would also work, but that would require probably about 2 days to charge the car up. On a 50A, it would take 6 hours or so. In the charge settings, you can set up a charging schedule (to start after 10pm for example) and you can also limit the current. I will have to do some experimenting to see if I can have the Airstream connected to the 30A outlet (need AC all night long in Texas!!) and the Tesla connected to the 50A, and not have the circuit breakers pop. Otherwise, I can limit the Tesla current draw to a lesser amount (say 20A), and then it would take maybe 10-12 hours to charge up.
In reality, with my family of 4, we are not going to want to spend more than 1 night in a Sport 16!! This is really just an option to spend a night occasionally at a nearby state park or lake. And of course the enjoyment of seeing the shocked look of people who see an electric car pulling a trailer! And also blowing sports cars off the line with our trailer in tow...
06-22-2016, 09:00 AM
How many solar panels can you fit on the roof of a 16 ft Sport?
06-22-2016, 09:06 AM
Central
, Mississippi
Originally Posted by Unherdable
However the Tesla comes with an adapter to plug the car into a 50A 4 prong RV outlet. So with a practical range of maybe 100 miles, as long as there is a 50A hookup at the campsite, it should be good...
Keep in mind that 50A service is actually 2 x 50A legs. 30A service is a single 30A leg.
Grab a 50A x 2 30A pigtail. The camper can use one leg of the 50A to run the AC, the other leg can charge the vehicle.
06-22-2016, 09:17 AM
2018 27' Flying Cloud
Austin
I'm really thinking a second vehicle for towing wouldn't be such a bad idea.
06-22-2016, 09:55 AM
I like your problem solving ideas, but I don't think this will work with a Tesla. If you adapt down to single pole the charging rate is controlled to the same rate as a regular 120 Vac wall plug. So it wouldn't be any better than using the 20a outlet on the pedestal.
06-22-2016, 09:57 AM
2016 16' Sport
Dallas
I thought that the 50A service was actually 2x20A 120V services, which could be combined into a single 40A 240V service. This is based entirely on experience and what I have measured.
In addition, the Tesla has dual chargers and it "sees" the 50A outlet as a single 40A charging source. So the 50A outlet would be quicker than a single 30A 120V leg, which is actually a 120V 20A leg...
Most Tesla owners install the 50A plug at home for charging.
06-22-2016, 09:59 AM
Does the Model X come with dual chargers?
06-22-2016, 10:21 AM
2016 16' Sport
Dallas
My S did but you're right the X does not! I typed too quickly.
Anyway doesn't matter, one leg of the 50A is +120V the other is -120V, so they are combined in the adapter to create a single 240V connection at 40A.
06-22-2016, 10:36 AM
You are well set at home, but weren't we talking about options for recharging at a campground?
I agree using the 50a plug for the car and the 30a plug for the trailer is the best solution.
If a 80a or 100a pedestal is available and not shared with another site.
06-22-2016, 11:51 AM
Tom T
Orange
"So what is different? The Airstream from 2015 model year up has LED lights. Does the Tesla not recognize a connection, because there is not enough of a current draw for the lights?
Has anyone here connected 2015+ Airstream to a Tesla Model X successfully? Or has anyone had issues like this with any other vehicles, specifically if the trailer has LED exterior lights?"
From what I understand, your comment quoted above which I bolded is the light problem, & it's also on other Euro SUVs & tow capable cars too.
I think what you need is this Reese adapter as used for the Porsche Cayenne, it's siblings & other Euro SUVs (apparently the Curt version doesn't work for these Euros)....
http://www.etrailer.com/s.aspx?qry=R...+adapter+20142
More info is here related to Euro/Cayenne which I've researched, & I'm sure the Tesla X crowd will get time too as more get on the road & towing, but try this now for your pairing issues & lights should/may work with the Reese adapter above.
https://www.etrailer.com/question-77832.html
https://www.etrailer.com/question-51182.html
https://www.etrailer.com/question-43386.html
I do see that your 1st post says you're paired with the "c" - so the above may not be a problem for you, but I included it just in case once the adapter is added - as well as for other X owners who may have RF pairing issues.
We also have the Tekonsha RF unit on the trailer, & once it's paired, it remembers the vehicle type (we've been renting various TV since July 2012 & just have to pair once per make/type/model), but we're still on the hunt for our Cayenne, so can't speak to that yet.
It may also be worthwhile to post your own question with eTrailer, but their "experts" may not know. Also ask Tesla, for their vaunted customer service.
Good Luck!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
06-22-2016, 01:01 PM
2014 25' FB Flying Cloud
Oak Grove
, Kentucky
we had same problem with VW TOUAREG...ended up buying adapter cable from a trailer shop for about $20 bucks - which boosts output signal from AS. It works perfectly every time!
