Old 02-25-2012, 10:36 PM   #1
2011 25' FB International
Leawood , Kansas
Tekonsha P3 and Grand Cherokee
Just installed a Tekonsha P3 controller on a 2012 Grand Cherokee with Tow Package. Used pre-made wiring harness from etrailer to connect controller to vehicle harness.
The P3 screen just flickers and am not able to get the menu to come up on the controller even after pushing the buttons and re-connecting the controller. The flickering screen goes blank when i press the vehicle brake pedal. I noticed the LED brake lights on the top of the GC hatch are also blinking when the P3 controller is on. My trailer is not attached to the 7-pin connector at the moment.
Anyone have any suggestions?
Tallgrass is offline   Reply With Quote
Old 02-25-2012, 11:14 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, do the color codes on the wire harness match, or are they in the proper position in the connector? [could have a few wires crossed] Did you do any drilling in the dash board for mounting the unit? You may have drilled into a factory wire harness. Or it could just be a bad unit.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-26-2012, 06:02 AM   #3
Leawood , Kansas
Thank you Bob. I did check the wiring and it matches up. No drilling as I used an existing hole to bolt on the mounting bracket. This is the second unit I have tried (both P3s) and both are acting the same.
Dogwoods and Bluegrass Rally 2012 63Silver The Rally Zone 123 05-02-2012 07:33 PM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 06:09 PM
2000 Airstream Excela Excella 30' Wide-Body ~ My Dad's Pride and Joy eBay Watch Airstreams on eBay 0 02-25-2012 09:40 PM
Grand Cherokee Hoosierdaddy Towing, Tow Vehicles & Hitches 3 02-25-2012 06:05 PM
Tambour On Kitchen Cabinets Hard To Open and Close JillTx General Interior Topics 6 02-25-2012 08:55 AM
