11-10-2014, 11:11 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Tailgate / camper jack interference
Wow, it is nice to be back to where I do not have to unhitch our AS to drop the tailgate on our truck. Not all trucks we have used as TV would allow easy entry to the truck bed by fully dropping the tailgate while the AS was hitched up.
Please note that on level ground, the Chev 2500HD will clear (by ~5/16') the camper jack on the AS for this model year. Yahoo!
11-10-2014, 11:29 AM
2009 23' FB Flying Cloud
Canmore
, Alberta
Airstream power jacks can be rotated 90 degrees to face the drivers side. This allows most tailgates to clear the power head.
11-10-2014, 11:36 AM
Small Town
Would NOT clear THE POST with our Ram 2500; thankful for the Duramax!
11-10-2014, 11:40 AM
Canmore
, Alberta
Nasty!! That's worthwhile info!
I believe that Dodge and Ford trucks have slightly taller boxes (and correspondingly taller tailgates) than Chevys.
I know that Honda 3000 will fit in most Dodge/Fords, won't fit under the tonneau in my 2014 Sierra.
11-10-2014, 12:23 PM
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up
, Traveling the USA
Look for an optional hitch bar that is longer. Mine has two holes for the pins, 1,000 lb TW or 1,500lb TW. THis was confirmed with the manufacture....Reese. 1,000 pin clears by less than 1/4" and 1,500 pin by 1.5+".
I have seen longer hitch bars with varying TW.
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
11-10-2014, 12:48 PM
1995 30' Excella
Bowie
, Maryland
This is the answer. Our Ram 2500 tailgate clears the jack with an inch to spare, because I was careful to order a hitch bar that was long enough.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
11-10-2014, 12:56 PM
2008 25' Classic
Full Time
You replaced your Dodge with a Chevy so the tailgate will clear the jack ?
Seriously, I know this is off topic, but why the switch?
Kelvin
11-11-2014, 10:54 AM
2013 30' Classic
Greenwood
, Mississippi
My Tundra's tailgate goes all the way down when the Airstream is hitched with the Equal-i-zer.
The tailgate would not go all the way down with the previous sob trailer and an EazLift.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
11-11-2014, 11:22 AM
2007 22' International CCD
Corona
No clearance issues at all with a Tacoma and a PP setup. Was vet close with the shorter Husky WD only setup.
11-11-2014, 11:26 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
So does my Dodge Ram with the flag pole holder on the front of the hitch! Wonder if that will change when I swap to a Propride.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
11-11-2014, 12:08 PM
Corona
Probably. ProPride stinger plus mechanism is considerably longer than stock setup. We got. Lot more clearance from the PP setup--I just don't have a measurement on it--maybe a foot or better?
11-11-2014, 12:29 PM
Slowpoke
2012 27' Flying Cloud
Portland
, Oregon
Our Tundra's tailgate wouldn't clear the power head on the jack, so I rotated it 90 degrees to face the curb side (it would rotate either direction) - all it took was loosening three setscrews - and now it clears by about 1/2". The stinger and ball head assembly are standard Reese.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
11-11-2014, 02:19 PM
2015 30' International
FREDERICK
, Maryland
Wow, I didn't even think of that - I am going to go outside and spin it around right now! Thanks!
11-23-2014, 07:34 AM
2015 25' International
Scottsdale
Can you rotate the head only or do you have to rotate the whole jack?
11-23-2014, 08:17 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
The head only rotates. It takes about one minute with an Allen wrench. We had to do this on Little Lucy as we could not open the door to the truck camper when hooked-up.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
11-23-2014, 08:51 AM
Scottsdale
Brian
Great that makes it a lot easier.
11-25-2014, 02:29 PM
2008 25' Classic
Full Time
But now the jack light doesn't shine down on the coupler. I have the older style Barker where the head assembly is 90 deg off the center line and the light is pointed to the hitch. My Tundra tailgate clears. The three holes in the base of the jack will only line up with the holes in the A frame on way.
Kelvin
11-25-2014, 02:54 PM
2015 27' FB Eddie Bauer
Aston
, Pennsylvania
Brian
Curious... is the caution tape functional or decretive?
