Old 07-31-2017, 04:06 PM   #1
2010 30' Flying Cloud
De Pere , Wisconsin
Switching hitches - what to do with old holes in a-frame?
Switching hitches from an old Reese to the BOSP and the old brackets had bolts into the frame, and the new brackets bolt to the frame over the old holes. Any advice on how to prep/fill/or just ignore those old holes?
2wiresdave is offline   Reply With Quote
Old 07-31-2017, 04:27 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
How excited are you about fixing things up?
A good clean, spray primer, proper color over the top is "adequate". Fiberglass / epoxy and some sanding will make them "go away". If you simply have big piles of money and no use for it, a welding shop can re-fill the holes with real metal. Unless there are structural issues (the old holes take up 1/3 of the frame....) the primer is the way to go.
Old 07-31-2017, 05:20 PM   #3
2000 30' Excella
Toledo , Ohio
You could put set screws in the holes with a sealer on them to prevent water entering the holes .
woodfox45 is offline   Reply With Quote
Old 07-31-2017, 06:40 PM   #4
De Pere , Wisconsin
I was figuring I would simply primer and paint. The new bracket cover the holes or I would just run the bolt back in. I am not near the trailer right now, but does anyone know if there are drain holes anywhere? Main concern is excessive moisture entering with no place to exit.
Old 08-01-2017, 11:00 AM   #5
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I would probably put bolts and nuts in the holes just prevent any possible cracking.
TinCan
graysailor is offline   Reply With Quote
Old 08-01-2017, 12:50 PM   #6
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
I concur
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 08-01-2017, 01:43 PM   #7
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
As I understand the holes from a prior thread, they are threaded. So I agree, install set screws with locktite to fill and seal the old holes. That's a great suggestion. If not threaded, it's easy to add them. Might even be tempted to set the screws just below the surface and add a layer of JB Weld for the seal. Pat
Old 08-01-2017, 01:56 PM   #8
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I'd just fill them with paintable caulk, paint them and be done.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 08-01-2017, 02:00 PM   #9
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
How are you going to get the nuts on the bolts?
MelGoddard is offline   Reply With Quote
Old 08-01-2017, 02:08 PM   #10
The holes in the my A-frame are stripped, due to 'idiot-child' using an air impact gun instead of a torque wrench.
I sealed the holes with plastic plugs and RTV silicone to prevent water ingress.
I would remount the Reese hitch if I could find some 1/2" rivet nuts; but all I can find here is up to 5/16".
The hitch was originally mounted per Reese instructions Rev. "K", but there is a later Rev
"S" using riv-nuts.
Unable to find them.��
Old 08-01-2017, 02:48 PM   #11
dznf0g's Avatar
Oswego , Illinois
I run a Hensley, but my prior, and backup is a dual cam. I simply coated with boshield the holes and installed the bolts in the frame for future use. No problems for 4 years.
-Rich-
Old 08-01-2017, 03:08 PM   #12
PKI
PKI's Avatar
Mel - drill the holes to a larger size. Have a machinist thread a set of plugs that will press fit into the larger hole and have a welder weld them in place. That gives you an industrial strength rivnut. If you have the clearance the plugs can have shoulders, which makes them easier to weld. Alternatively the plugs could be threaded in place instead of welded. I'd probably just install a plate with the Reese pattern to attach the bracket and a larger pattern to attach the plate to the A-frame tube. Pat
Old 08-01-2017, 05:59 PM   #13
Sounds Good!
Worth considering.
But if I "thread' them in place, the material in the frame is only 1/4" thick.
Not much 'meat' to hold a threaded plug.
Welding them might work though.
But I still like the idea of Riv-nuts, if only I could find them.
(They work on aircraft.)
Thanks for the ideas.
Old 08-01-2017, 08:03 PM   #14
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Welding them away is best, calking will work just fine
bibbs is offline   Reply With Quote
Floor replacement - c-channel bolt holes slipped 1in off frame holes tshannon Repairing/Replacing Floor &/or Frame 2 07-21-2016 04:07 AM
Weight distribution & anti-sway hitches - What changed from the "old days"? Phoenix Towing, Tow Vehicles & Hitches 14 09-10-2014 05:50 PM
Plugging holes on the A frame Tino643 General Repair Forum 2 04-10-2013 07:37 PM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
