Old 08-28-2017, 01:38 PM   #29
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by AWCHIEF View Post
Interesting, I see UPS trucks at the back loading dock of my local PO all the time.
Hmmm! I wonder what the Canadian Rules are.
MelGoddard is offline   Reply With Quote
Old 08-28-2017, 09:52 PM   #30
2007 22' International CCD
A lot of smallish UPS packages are delivered the 'last mile' by USPS. Happens a lot in my neighborhood.
KE4GNK/AE
Old 08-29-2017, 03:14 PM   #31
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
We have trouble with that also - mail won't deliver to our physical address. So now when we have to order things that require a physical address, we give it, then add "PBX55" (our PO box number) to either that line or the line below it. That way the POBox text won't get error-coded-out by the shipper's software, and the post office (who receives it from UPS) knows you have a PO Box and will accept it.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 08-29-2017, 03:35 PM   #32
Pat
Ah, good point. One of our houses is in a neighborhood that does not deliver to physical address. And, rotten bugger that I am, I didn't sign for the PO box key, so I don't get all the junk mail--that I would have to personally go pick up!
If I had activated that box, I have no doubt that I would get crap-tons of junk mail at both locations...that gets tossed in the recycle anyway...
KE4GNK/AE
Old 08-31-2017, 09:20 PM   #33
Originally Posted by woodfox45 View Post
They use UPS for delivery . UPS can't go onto Post office property .
Aug. 31:
Finally got my 'Riv-Nuts' today.
They were delivered to the Post Office.
I ordered two sets; one to practice with, the other for installation.
(I've only got one chance to do it right!)
Old 09-01-2017, 08:31 PM   #34
And today, Sept.1, I finally installed the two cam brackets on my AS.
It wasn't as easy as the directions stated, (two of the riv-nuts rotated, in spite of being hammered into the holes.); but I 'cheated' and the installation was good.
Tomorrow I hook up the Ford, and complete the job.
Then comes proving it out on the road.
Old 09-02-2017, 03:46 PM   #35
So, TODAY Sept. 2: is "tomorrow".
I did hook up the Ford, took the rig out on the 401, and it worked.
The steering was a little light, but then I had an 'empty' AS, not at all loaded; there was the usual lots of wind in Southern Ontario, so I limited my speed to max. 100 Kph.
The real test is in about a week, when we load up and hit the road again.
I may have to re-adjust the hitch, once I get us loaded.
And this raises a question:
When installing a new WD hitch, there seems to be a lot of measuring, 'fooferaw' and TV 'drops' front and rear and so forth.
So what's the matter with just putting a spirit level on the floor, or door sill of the TV, and one on the floor of the RV, (or better yet, the floor of the freezer); and cranking up the chains until both RV, and TV are level.???
When I'm ready to hit the road, I check the level on the A-frame, and if off a little, I trim the balance by moving stuff fore or aft.
It works.
Trailer Trash, in a Tin Can Shed.
Old 09-10-2017, 06:44 PM   #36
I'm currently at Stony Point CG sitting at a campfire.��
The damned thing worked. It was originally set up by Andy's guys at CanAm; and I just put everything back in place.
The steering still seems a little light to me, but then it always did with this hitch.
The Ezy-Lift seemed to tow a little better, but not that much difference. And it 'groans'.
I'll stay with this Reese.��
Old 09-11-2017, 05:27 AM   #37
CLOUDSPLITTER Phone home
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
Originally Posted by dznf0g View Post
I run a Hensley, but my prior, and backup is a dual cam. I simply coated with boshield the holes and installed the bolts in the frame for future use. No problems for 4 years.
Ditto
Removed the sway mount plate & stuck the bolts back in with 3m 5200 on the threads.
OOP's .....
"I'm a confirmed beginner in just about everything that other folks are expert in...."
RLC
Old 09-12-2017, 10:32 AM   #38
OK, you 'Hitch-perts';
Gotta question for you, 'cause I'm curious. (some people say I look funny too.)
The Reese instructions tell us to assemble the 'ball mount' to the hitch at a 15 degree angle, as mine is.
So, what would be the result if I changed the angle; either more or less?
Big Difference? Little difference?, No difference?? In the towing dynamics??
Trailer Trash, in a Tin Can shed.
Old 09-13-2017, 07:06 AM   #39
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you increase the angle, but keep the chains at the same point, you get more WD. Since you can adjust the chains, it's not clear why you would mess with the angle.
uncle_bob is online now   Reply With Quote
Old 09-13-2017, 06:38 PM   #40
Hi
Well; 'somebody' said that by increasing the angle, there would be more resistance to sway.
(Apparently 'Blue Ox' does the same thing to combat sway.)
(Not that I have sway; I would just like to increase the nose 'authority' a tad.)
[A soon to be academic question, as I'm putting the FC on 'the market' at end of Oct.
DW has drawn the line, and we're getting aged and unhealthy and all that crap.]
Old 09-13-2017, 07:54 PM   #41
2016 25' Flying Cloud
Holly Springs , Mississippi
I've seen that suggested previously, but don't believe it. If the angle were part of a solid bar hinge, yes, it would help correct sway. But it's not--it's a ball and socket. So if you increase the angle, it's still a ball and socket, so no net effect. (Yes, a very slightly different swivel point on the ball, but still a ball and socket.)
In my view, the only purpose of changing the hitch angle is to increase (or decrease) the amount of weight distribution from the bars, using the same number of links in the lift chains.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 09-14-2017, 06:49 PM   #42
Sounds good to me; just exploring possibilities, that's all.
Floor replacement - c-channel bolt holes slipped 1in off frame holes tshannon Repairing/Replacing Floor &/or Frame 2 07-21-2016 04:07 AM
Weight distribution & anti-sway hitches - What changed from the "old days"? Phoenix Towing, Tow Vehicles & Hitches 14 09-10-2014 05:50 PM
Plugging holes on the A frame Tino643 General Repair Forum 2 04-10-2013 07:37 PM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
New toilet holes don't match old holes RichHog Sinks, Showers & Toilets 8 03-15-2009 06:36 PM
