Old 07-08-2019, 10:08 AM   #1
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
Stand up and take your chance.
Greetings,
I remember the old days in Afghanistan, when I stood up and took my chance...
Well, here we go again.
"We" being the Airstream towing community.
I am on a fire department. Yesterday we responded to a rollover near the Bozeman pass. And lo, it was ANOTHER 25' Airstream, being towed by a small SUV. It appeared that during a quick lane change, the trailer started to sway and then took over from the TV, rolling 2 or 3 times.
And I say, "another" Airstream? Because its the third one in as many years. At the same place. All with small, 1/2 ton or less, overloaded TV's. All where the trailer took over the TV.
So, yes, you can blame the hitches, the grade, the weather, the driver, or even the dog,
but the bottom line is: three crashes, three Airstreams, and three small TV's.
So, if you have a too-small TV, you get to stand up and take your chance.
Myself, I have a 3/4 ton pickup. Enough chances...
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 07-08-2019, 10:15 AM   #2
2013 20' Flying Cloud
Westerly , Rhode Island
Ok.
smithcreek is offline   Reply With Quote
Old 07-08-2019, 11:24 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Thanks for the report.
Old 07-08-2019, 11:50 AM   #4
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
Originally Posted by hshovic View Post
Greetings,
Trying to convince many newbies to listen to reason in regard to towing capacity can be a challenge. Not wanting to invest in a truly capable TV, they tend to rely on the advice of Airstream and vehicle salespeople over experienced towers.
We tow both of our trailers with a RAM 2500, safely and with confidence.
SilverWind is online now   Reply With Quote
Old 07-08-2019, 12:37 PM   #5
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
We have been through that area looking for terrible conditions. It is a relatively easy tow. Curves are not tight, grades are reasonable and no gusty wind when we were there. However, the Interstate through Montana is known for high wind accidents and that hazard should not be discounted.
Since this one was initiated by a lane change that resulted in sway, the incidents seem to reinforce that above all else, attentive driving skills are critical to safe travel.
Thanks for noting the event. Pat
Old 07-08-2019, 12:41 PM   #6
weirdstuff's Avatar
2018 23' International
San Diego , California
Airstream, or not, there is a general non-educatedness regarding picking a tow vehicle. I've heard so many people say things like, "My trailer is 4500 lbs, and so I'm buying truck "x" because it's rated to tow 5000 lbs." They have no idea about tongue weight, axel ratings, payload, etc.. I used to speak up, but now I just stay quiet and roll my eyes, because nobody listened to me at all.
weirdstuff is offline   Reply With Quote
Old 07-08-2019, 12:51 PM   #7
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
How 'small' was the SUV? Conflating that vehicle with a 1/2T pickup might be questionable. And in this case (based on my view of this accident from hundreds of miles away) the key element was 'quick' lane change. Should be no such thing with any trailer/tow vehicle combo. Maybe it was a reactionary avoidance move? My questions would also include...was there a W/D hitch? Sway control? What was the speed?
Not sure if it's one of the three you've mentioned, but the case I recall reading about on here a year or so ago, they were newbies pulling on the ball with no W/D/ no Sway control, etc when they took their roll.
Not being argumentative, this might certainly be a case of way too much trailer for the tow vehicle. Would a half-ton pickup have also rolled? A 3/4? We don't really know.
pcskier is offline   Reply With Quote
Old 07-08-2019, 12:53 PM   #8
pcskier's Avatar
Park City , Utah
You nailed it Pat.
Old 07-08-2019, 12:58 PM   #9
Long Island , New York
Thanks for the update. Do you have any links to news reports about this?
FEI -- earlier threads:
http://www.airforums.com/forums/f42/...ee-171608.html
http://www.airforums.com/forums/f463...ml#post1645004
Peter
Old 07-08-2019, 01:43 PM   #10
Mollysdad's Avatar
Old 07-08-2019, 01:50 PM   #11
PKI
PKI's Avatar
Does anyone know the brand, model and vintage of the tow vehicle that did the dirty deed? Pat
Old 07-08-2019, 02:57 PM   #12
2012 19' International
Southeastern MI , Michigan
I also tow with a diesel Ram 2500, and a Hensley hitch, installed by the dealer whose name I know is coming because these threads always bring it up. But these accidents (one per year) may not be significant when you consider the thousands of RVs that ran that route and many others without incident.
I’ve always liked big pickups but give my setup to an inexperienced or skittish driver that jerks the wheel every time they think they were “cut off” and the result will be the same as the one you responded to.
2018 International Serenity 27' FB
Michelin 16Ē tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 07-08-2019, 03:21 PM   #13
2007 22' International CCD
Even with a superior sway prevention Hensley Manufacturing or ProPride hitch system, properly set up, inattentive driving, sharp maneuvers or really bad wind combined with excess speed can overwhelm a rig.
No argument there.
rmkrum is online now   Reply With Quote
Old 07-08-2019, 04:08 PM   #14
2019 30' International
Pennsylvania , Pennsylvania
All I can add to this thread is that I tow with an F250.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is online now   Reply With Quote
Do i take a chance! dr1958 Member Introductions 3 04-10-2010 11:27 PM
Chance To Get Your Airstream ON TV (Great Chance) TVone1232343 Our Community 0 06-22-2009 11:32 AM
Now is your Chance to tell Jim where to go Jim Clark Off Topic Forum 39 05-25-2006 04:55 PM
Here's Your Chance... flyfshr Off Topic Forum 3 05-21-2006 08:20 AM
Here's your chance to spend someone else's money. guy99 Mechanics Corner - Engines, Transmission & More... 27 03-04-2006 12:46 PM
