Old 06-05-2018, 08:13 AM   #1
2017 28' Tommy Bahama
Lake Oswego , Oregon
Stainless steel hitch ball?
Iím a rust hater. When I towed a boat, I had a stainless steel hitch ball. The Blue Ox has mild steel. I want to switch it out with a cold forged stainless steel hitch ball. My boat didnít weigh anything like my 27í Airstream trailer. Any concerns here?
Ridget is offline   Reply With Quote
Old 06-05-2018, 08:19 AM   #2
2018 30' Flying Cloud
Gig Harbor , Washington
There is not problem towing with a stainless steel ball hitch setup. Just make sure the gross tow weight meets the specifications. Here is a good site with stainless steel ball hitches and GTW.
https://www.etrailer.com/dept-pg-Hit...ess_Steel.aspx
hoagy_007 is offline   Reply With Quote
Old 06-05-2018, 09:37 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It may be fine, but I could never tow with a stainless ball because I have seen how brittle stainless can be. I would worry about it too much even if there was no cause for worry.
Thatís just me, (opinions will invariably vary).
Old 06-05-2018, 09:38 AM   #4
Mollysdad's Avatar
Good idea as long as the ball can carry the load. I seem to recall that stainless is more brittle than ferrous metal.
Old 06-08-2018, 04:09 AM   #5
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
My hitch ball doesn't rust because I keep it slathered in wheel bearing grease. Living 1,000 feet from the ocean means everything else rusts... but not the hitch ball. Is "more grease!" an easier, proven solution?
GammaDog is offline   Reply With Quote
Old 06-20-2018, 04:42 AM   #6
Trgai's Avatar
2018 26' Flying Cloud
2014 Interstate Coach
Clifton , New Jersey
I have a stainless ball mount. The ball itself is zinc coated. The nut is stainless. I think I got it at WalMart.
Reese has aluminum ball mounts on their website.
Trgai is offline   Reply With Quote
Old 06-20-2018, 05:07 AM   #7
r carl's Avatar
Lin , Ne
One of these may work for you.
https://www.weigh-safe.com/product/universal-tow-ball/
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
Stainless Steel & Mirror Finish LP Tanks TonyBusto LP Gas, Piping, Tanks & Regulators 5 05-05-2004 08:37 AM
Stainless Steel Antenna Mount on AS Body gklott Electrical - Systems, Generators, Batteries & Solar 2 11-17-2003 11:00 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
stainless steel wheel simulators Larry Brown General Motorhome Topics 11 11-26-2002 08:10 PM
