Old 06-05-2016, 04:26 PM   #1
Groveland , California
Stablizer hitch on Excella?
Hi all. We just bought a '98 Excella and it has some kind of a hitch attachment mechanism on the tongue but no other parts came with the trailer. Can someone please help us get the correct parts so we can get this hooked up properly???
cannonball39 is offline   Reply With Quote
Old 06-05-2016, 04:33 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
How about some pictures?
Do you have a hitch head for the TV or just a bumper ball?
2004 Excursion 4x4
Old 06-05-2016, 05:52 PM   #3
1991 25' Excella
Stanfield , Oregon
Mine came with the same setup but I chosse to remove it. Its just a bar and chain style nothing to fancy.
SpletKay06 is offline   Reply With Quote
Old 06-05-2016, 06:06 PM   #4
HowieE's Avatar
Images: 12
That is a Reese Dual Cam system. If you are considering using that system you might just as well buy a complete new system. Cheaper than fitting out around just the old hangers.
Not sure why I missed the picture the first time
Old 06-05-2016, 07:21 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
All I see is a chain lift?
You need a draw bar and a complete hitch setup. The Reese Dual Cam is what I use and you can see a complete system at Campers World. Another quality hitch system is the Blue Ox. You can look them up on the internet. I would probably go with the Blue Ox if I was starting over. I think it is simpler to install and set up. Good company.
Old 06-05-2016, 07:26 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
At first glance of the picture I thought it was a Monty Python reference to the French!
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-05-2016, 07:38 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
In your photo, that is a snap up bracket from an old trunion style Quality S Hitch, and it is broken (a piece is missing). I have a complete hitch like that, which I still use occasionally. It is 40+ years old.
Quality S does not sell WD hitches or parts for them any longer, but they still sell after market hitch receivers.
Like others have said, you are going to have to find some other WD system.
Old 06-06-2016, 01:54 PM   #8
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
Hitch
Do yourself a favor and scrap what you have. You will need to buy a new weight distribution hitch. It will have all you need for your setup. This part on your trailer is likely an Easy Lift or Reese hitch. They are both good hitches, however you will get more sway control with an Equalizer Hitch. Don't go with the Anderson, it will not give you ample weight distribution. I've used them all over the years and my fav for sway control and weight distribution is the Equalizer Hitch. Just my simple $0.02.
jimfa440 is offline   Reply With Quote
Stablizer jacks replacement with scissor jacks spoonplug Jacks, Stabilizers, Lifting and Leveling 18 11-25-2018 06:22 AM
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
towing the 32 excella vs 34 excella hitch recommendations lakelady Hitches, Couplers & Balls 21 03-21-2008 07:13 PM
Getting sucked in - Stablizer bars or not? FordTruck Hitches, Couplers & Balls 14 09-16-2006 10:09 PM
