Old 05-27-2014, 07:39 AM   #29
Minneapolis , Minnesota
I also have the old style dual cam setup - also set as described above - I though that this photo my be of be of some help -2 other photos to fallow
loons2 is offline   Reply With Quote
Old 05-27-2014, 07:41 AM   #30
this is photo # 2
Old 05-27-2014, 07:46 AM   #31
this is photo#3 - note that the saddle broke at the marks at the top - reese no longer sells the parts for this hitch - I bought the last 2 at the reese dealer 2 weeks ago - I plan on having 2 new saddles without the scoring -hope this helps
Old 05-27-2014, 07:57 AM   #32
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have not read all of the comments above but will make this one.
Reese bars at not manufactured to tolerances that guarantee that the bars are the same length. If you have set up the system correctly and then mark one of the bars for a given side you may see an improvement. I found this after maybe 30 years of using a Reese system. A widow friend who followed we as we would go out weekends said one day that my trailer was all over the road. Then after a couple more trips she said would comment sway not there on one trip and bad bad on another. I checked the setup and found about an 1/8 in. difference in the bars.
This difference is enough to cause the system to become additive to sway rather than subtractive as the bars are actually accelerating the movement at first.
On a nice flat parking lot drive in straight for at least 100 ft. park and check how the bars are setting on the saddles. They should be fully seated on both saddles. Remove the bars and swap them side to side and recheck that how they are seated. If you see any difference that is you problem.
2004 Excursion 4x4
Reese Dual Cam Set Up... norsea Hitches, Couplers & Balls 327 07-05-2016 11:33 AM
Questions on hitch set set up for my Dodge Astriking Hitches, Couplers & Balls 13 04-25-2011 05:03 AM
Reese dual sway and w/d hitch cpaharley Hitches, Couplers & Balls 30 08-14-2009 06:42 PM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
Set-up & Break-down Tips moosetags On The Road... 2 11-08-2006 10:47 AM
