Old 09-06-2014, 06:33 AM   #99
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by BoldAdventure View Post
Smallest Towing Car
End of debate. I win.
The combo I like in the photo is the yellow VW 181& trailer in the background.
MICHAEL
Old 09-06-2014, 09:10 AM   #100
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Don't tell that to all the 3/4 ton guys who swear the big heavy trucks are what have the true advantage when slowing down on a steep grades.
I guess the gravel truck drivers should just use a Chrysler 300 and just add a trailer to tow. There is something called the "Law of diminishing returns" and I certainly would rather have a vehicle rated to TOW vs a vehicle rated to haul people. Like Forest Gump said "Stupid is as Stupid does".
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 09-06-2014, 09:19 AM   #101
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Smallest Towing car
In my experience, If the trailer brakes are right, they do the stopping of the trailer, and in normal stops, a portion of the TV stopping as well.
In other words, if the trailer brakes are right, the trailer never pushes the TV, uphill, downhill, or level ground.
Old 09-06-2014, 09:52 AM   #102
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Forest Gump is a pretty smart man! Maybe we could convince him to join Air Forums!
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 09-06-2014, 10:23 AM   #103
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
A towing expert has been towing Airstreams with Chrysler 300's for years and reports his results:
Chrysler's 300 Sedan - RV Lifestyle Magazine
Doug and Cheryl
Old 09-06-2014, 11:59 AM   #104
Road Ruler's Avatar
Images: 38
That is a good article Doug. You can't beat real life experiences.
Old 09-06-2014, 12:32 PM   #105
N/A , N/A
Here is another real life experience by one of the forum members:
http://www.airforums.com/forums/f463...es-116384.html
rostam is offline   Reply With Quote
Old 09-06-2014, 12:50 PM   #106
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Are they towing empty Airstreams? Just curious? I mean that's awesome. But what about someone who is full timing? With passengers? Full LP tanks, fresh water? Food in the fridge? I'm just curious since none of that info is in this article.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-06-2014, 02:08 PM   #107
dkottum's Avatar
Actually his towing experience was very good but was not able get a rather lousy dealership to fix an overheating engine on a used car that was probably faulty from when he got it. To his credit he gave it up early.
Doug and Cheryl
Old 09-06-2014, 02:17 PM   #108
dkottum's Avatar
Not really that surprising. You and I are towing mid-to-large size Airstreams with Ram 1500's that don't have a lot more power but weigh over 1,000# more than the Chrysler 300. And it has the advantage of full independent suspension and lower center of gravity for much better stability.
Our 5.7 and 6-speed trans work pretty good, but I sure would like the 8-speed to keep in an ideal power/economy range on different grades and wind conditions.
Doug and Cheryl
Old 09-06-2014, 02:35 PM   #109
dkottum's Avatar
I think the point Andrew Thomson makes is you will benefit from considering all the elements that make up a good, stable towing vehicle. Including hitch and trailer design/setup. As well as how that vehicle performs for you when not towing. Bulk of tow vehicle isn't one of them, but the point is lost to those who insist bigger is better just because it is.
Doug and Cheryl
Old 09-06-2014, 02:46 PM   #110
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
They were on vacation with their families so the Airstreams will have been loaded pretty much as anyone else would load them.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 09-06-2014, 02:49 PM   #111
MrUKToad's Avatar
Chatham , Ontario
Wasn't that an overheating engine issue? Wasn't it something that afflicted certain Chryslers whether towing or not? The article in RV Life made no mention of engine issues.
Old 09-06-2014, 03:09 PM   #112
2004 16' International CCD
Chicagoland , Illinois
The Chrysler 300 is grossly-undersized for that load. It doesn't matter what tweaks you make to it, unless you sprinkle 700+ lbs. of fairy dust onto it, you'll still have a grossly-undersized tow vehicle.
Just because you CAN tow with it doesn't mean that you should. Just because you've logged 100,000 miles with it doesn't mean that it is a safe combination to tow.
When I see a miraculous image of Jesus in my morning toast, it doesn't mean that he is real. The onus for proving the legitimacy of these mods lies with those who recommend them. Where is the statistical evidence? Why are there only a handful of happy owners who tout the divine nature of this solution?
The article above claims that an engineer from Chrysler said, "“There is not enough profit in a car like this to take a gamble on a tow rating.” To some that means that it can easily be modified to tow huge loads. To others that means that screwing with the towing capabilities is "a gamble."
Airrogant is offline   Reply With Quote
Smallest towing vehicle ? youngh Tow Vehicles 14 08-29-2011 08:09 AM
lincoln town car tow car rick myer Tow Vehicles 10 03-10-2010 05:30 AM
Car Will Not Fit On Car Dolly! Chaplain Kent General Motorhome Topics 7 11-08-2006 04:46 PM
smallest airstream with seperate bedroom? tom wolseley 1974 - 1979 Safari 11 05-14-2006 11:08 AM
