Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 09-08-2014, 06:15 PM   #181
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Originally Posted by J. Morgan View Post
Post 164
Do you know how much weight those wheels and tires are carrying on a 26' single axle Overlander?
I bet it is a whole lot less than you think.
Lance
Lance M is offline   Reply With Quote
Old 09-08-2014, 06:49 PM   #182
Twinke58's Avatar
1962 24' Tradewind
Independence , Missouri
Right now she is empty. I'm redoing her and when I looked at 58 brochure it said it weighs 3200. She weighs 1800 to 2000lbs now.
Twinke58 is offline   Reply With Quote
Old 09-08-2014, 10:21 PM   #183
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Well still, two axles would be safer.....
Old 09-10-2014, 06:47 PM   #184
Southwestern , Ohio
To get back to the original subject of this thread, here are some Airstream ads from the time the Bambi came out (circa 1961). I am pretty sure the first picture shows a Mercedes 190SL tow car. The second is the Volkswagen "Beetle".
If I remember correctly in 1961 or 1962 the Beetle was up sized from 36 HP to 40 HP.
I wonder what the effect of a couple hundred pounds of tongue weight was on the rear swing axle of the Volkswagen. Or, if they used weight distribution, I can't imagine how they rigged it around the engine.
ID:	221443   Click image for larger version
Nuvite-F is offline   Reply With Quote
Old 09-10-2014, 06:54 PM   #185
Twinke58's Avatar
1962 24' Tradewind
That's cool but I had a 40hp bug and it weighted 1800lbs. My bug I had that pulled anything was a 1600 and the max was 500lbs tow on it.
Getting back to the single axle, I wanted a dual axle but this one was what I wanted so I bought it.
Sent from my iPhone using Airstream Forum
Old 09-10-2014, 07:13 PM   #186
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Tow your Airstream with the Ford Airstream
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-08-2014, 06:15 PM   #187
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Back from the Balloon Fiesta and here are the results: Average MPG 15.08, highest 16.72 from Williams, AZ to Albuquerque, NM, lowest 12.81 from Orange, CA to Barstow, CA.
I tow at 58 MPH, on cruise control, most grades were taken in 4th with cruise control on, some grades downshifted to 3rd and I manually upshifted to 4th, still able to maintain 58 MPH.
On downgrades the transmission shifted as low as 4th while on cruise control
The Liner weighs about 5700 lbs and the tow rating of the Durango is 7200 lbs.
I am very satisfied with the results and the towing capabilities. No issue stopping, but then I have 12" disc brakes on the Liner.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 10-09-2014, 10:10 AM   #188
2015 27' Flying Cloud
Bozman , Maryland
I haven't seen much discussion about tires on the TV. Tires have a specified load rating, so one thing you definitely want to check is whether the tires on your rear axle are rated to carry the load you're putting on them: vehicle, cargo, tongue weight. Overloaded tires get hot and they fail, with potentially catastrophic results. Ask Ford and Firestone. The old Explorer had a very low GVWR, much lower than the truck could pull or the brakes could stop. However Ford wanted a soft ride, which required them to use soft tires with low weight rating and low inflation pressures. Unfortunately many owners overload the vehicle (four good sized passengers and a fair amount of stuff in the back would do it) and also weren't righteous about tire pressures. So, sometimes, the tires failed at speed and the driver lost control. I have no doubt that a Chrysler 300 with the V6 can pull the weight and stop it. What I'd be concerned about is whether the rear tires have the additional capacity to carry 800 lbs of tongue weight plus the weight of stuff in the trunk and stuff/people in the back seat. One of the unfortunate things about the smaller Airstreams is that they have higher tongue weights than the big ones.
DC Bruce is offline   Reply With Quote
Old 10-12-2014, 02:33 PM   #189
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
The rear tires of a 300 have 230-310 pounds of remaining capacity when towing. Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 10-13-2014, 10:04 PM   #190
Name:	ImageUploadedByAirstream Forums1413259482.715370.jpg
samyjam14 is offline   Reply With Quote
Smallest towing vehicle ? youngh Tow Vehicles 14 08-29-2011 08:09 AM
lincoln town car tow car r myer Tow Vehicles 10 03-10-2010 05:30 AM
Car Will Not Fit On Car Dolly! Chaplain Kent General Motorhome Topics 7 11-08-2006 04:46 PM
smallest airstream with seperate bedroom? tom wolseley 1974 - 1979 Safari 11 05-14-2006 11:08 AM
