Old 02-16-2015, 12:01 PM   #43
2006 28' Classic
St. Francisville , Louisiana
Pahaska do you hook the blue wire in parallel with the magnets?
I have a 2011 GMC Sierra Danall Durmax 2500 HD and new to me a 2006 28' Classic.
Factory brake controller does not work with my AS with disk brakes It work with nmy 5th wheel we just sold..
Thanks John
johnlanglois is offline   Reply With Quote
Old 02-16-2015, 12:18 PM   #44
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
[QUOTE=johnlanglois;1581728]Pahaska do you hook the blue wire in parallel with the magnets?
Thanks John[/QUOTEGround any one wire from each magnet. Connect the remaining wire from each magnet to the blue wire. The magnets will then be in parallel, just as they would be on a single axle drum brake trailer. It doesn't matter which wire you choose.
John W. Irwin
WBCCI #9632
Old 02-17-2015, 02:51 PM   #45
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by dznf0g View Post
I prefer the exhaust brake to decel and hold back on downhill runs, over the TH mode.
Absolutely !
Old 02-17-2015, 05:58 PM   #46
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
My 2007 3/4 silverado w 25' safari is set at 7. Seems to work fine, set up according to the manual.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 03-08-2015, 08:59 AM   #47
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
I tow my 30FC with a 2014 GMC Sierra HD. Looks like I am in the minority here on two fronts: I set the brake gain to 10. And I use the Tow/Haul mode with the exhaust brake on when towing. They seem to work well together. Our trip last summer was to Santa Fe, then Mesa Verde, then up to middle Colorado, and then back east through Denver, Nebraska, etc. Towing was a pleasure with the Duramax Diesel.
For a hitch lock I use a 5/8 lock from Bolt Lock, keyed to the truck key.
I believe the OP uses a Hensley. I also have a Hensley and after I got the GMC truck as TV, I switched the Hensley bars from 1400 lb bars to 1000 bars.
RAH is offline   Reply With Quote
If there is a factory 7 pin connector is there a brake controller already? RhinoWW Tow Vehicles 3 01-19-2014 09:15 AM
2012 Chevy Silverado 1500 Brake Controller Wiring AirHeadsRus Brakes & Brake Controllers 9 11-20-2011 05:20 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
GM Silverado and Sierra brake controller Pahaska Tow Vehicles 23 11-29-2007 05:17 AM
Hitch and brake controller recommendations for Excursion/28' Safari PWRSTRK Hitches, Couplers & Balls 15 08-17-2004 08:45 PM
