02-15-2015, 07:16 AM
#41
2011 30' Flying Cloud
Arvada
Thanks again Bob. I can already see the mpg improvement over the Suburban. It would get 9-10 hauling and 17-18 on the flats with no tow. In fact I mentioned the Ouray to Durango highway. We drove it in 2013 on our way to the Southwest Adventure Caravan. In climbing that hill I burned four gallons in sixteen miles. In some places it was a 15 mph, 1st gear pull. No doubt that Duramax will be an improvement. Hopefully one day we'll see you "down the road" Jack
02-15-2015, 07:24 AM
#42
Contributing Member
Austin (Hays County)
Originally Posted by flyerboy
Jack,
For what its worth, the "sweet spot" for mileage for my 2013 Duramax is 1600RPM (which is where all the torque comes in) and 65MPH. I get 22-23mpg flatland no tow, and 12-13mpg towing my '08 Classic @ about 9,000#. Rarely out East does it downshift while towing up the mountains, 1600RPM all the way up and over. These trucks are beasts! I love it! This is how towing should be. It's a blast to pass 18 wheelers going uphill at 65MPH towing 9-10,000#.
Good Luck!
For a long time, I towed at 60 to 62. Then, one time, I was in a hurry and increased to 65. To my amazement, my fuel mileage increased instead of dropping. I now tow at 64 to 65. I get about 14 mpg towing my Classic 28 on most terrains.
Some of my worst mileage is in the Texas Hill Country where there is an endless series of small but steep ups and downs. I lose more on the upgrades then I gain on the downgrades. I can improve my mileage in these conditions by shifting to "M" and shifting down with the button as soon as I hear the engine start to load on the upgrades without waiting for the transmission to shift down on its own.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
02-16-2015, 12:01 PM
#43
2006 28' Classic
St. Francisville
, Louisiana
Pahaska do you hook the blue wire in parallel with the magnets?
I have a 2011 GMC Sierra Danall Durmax 2500 HD and new to me a 2006 28' Classic.
Factory brake controller does not work with my AS with disk brakes It work with nmy 5th wheel we just sold..
Thanks John
02-16-2015, 12:18 PM
#44
Contributing Member
[QUOTE=johnlanglois;1581728]Pahaska do you hook the blue wire in parallel with the magnets?
Thanks John[/QUOTEGround any one wire from each magnet. Connect the remaining wire from each magnet to the blue wire. The magnets will then be in parallel, just as they would be on a single axle drum brake trailer. It doesn't matter which wire you choose.
John W. Irwin
WBCCI #9632
02-17-2015, 02:51 PM
#45
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Originally Posted by dznf0g
I prefer the exhaust brake to decel and hold back on downhill runs, over the TH mode.
Absolutely !
02-17-2015, 05:58 PM
#46
2007 25' Safari FB SE
Bozeman
, Montana
My 2007 3/4 silverado w 25' safari is set at 7. Seems to work fine, set up according to the manual.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
03-08-2015, 08:59 AM
#47
2013 30' Flying Cloud
Cincinnati
, Ohio
I tow my 30FC with a 2014 GMC Sierra HD. Looks like I am in the minority here on two fronts: I set the brake gain to 10. And I use the Tow/Haul mode with the exhaust brake on when towing. They seem to work well together. Our trip last summer was to Santa Fe, then Mesa Verde, then up to middle Colorado, and then back east through Denver, Nebraska, etc. Towing was a pleasure with the Duramax Diesel.
For a hitch lock I use a 5/8 lock from Bolt Lock, keyed to the truck key.
I believe the OP uses a Hensley. I also have a Hensley and after I got the GMC truck as TV, I switched the Hensley bars from 1400 lb bars to 1000 bars.
