Old 04-09-2012, 08:49 AM   #1
dznf0g's Avatar
Oswego , Illinois
Shurline scale accuracy?
Question for you folks with a Sherline tongue scale. Do you find that it "zeros in" on a reading? Or if you push and pull vertically on the tongue does it settle on different numbers.
It seems , with mine, I can get as much as 100# difference when "rocking" the tongue up and down, like the shaft is sticking in the bore.
Any ideas?
-Rich-
Old 04-09-2012, 08:53 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have a tongue scale, brand unknown. Basically a hydraulic cylinder and a pressure gauge. It behaves as you mentioned. Very hard to get consistent repeat readings
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-09-2012, 10:04 AM   #3
Vintage Kin
Fort Worth , Texas
Perfect is not to the point. One must also deduct/add for distance from hitch ball center. It can be checked against the old bathroom scale "method", and checked again using the Ron Gratz Chart I've posted numerous times.
Another way of looking at it: What is the difference in TW percentage as a difference in readings?
A SHERLINE is a tool on my acquisitions list. But few of us can afford the type of tool to which is referred. Good enough is just that.
Old 04-09-2012, 10:56 AM   #4
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Well they say not to lift by or pull on the plunger. I have stood on and off mine to make sure it's moving freely before I weigh. And the tongue weight can vary by 200+lbs between the coupler and the jack stand. It has been a very useful tool for dialing in the tongue weight and packing the trailer with my Touareg.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 04-09-2012, 11:22 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Just took a look and mine is Roadmaster, By Sherline. I find repeat measurements vary by 200 lbs or so.
I guess this is close enough as a % of trailer weight but not nearly good enough for watching effects from changes in loading etc
13 Ram 2500 TD
Old 04-09-2012, 11:27 AM   #6
jimmickle's Avatar
2000 31' Land Yacht
If anybody is interested, I have a like new sureline for sale as health issues have ended my travel years.
jimmickle is offline   Reply With Quote
Old 04-09-2012, 12:17 PM   #7
Lost in America
mojo's Avatar
There are two different scales, 1000lb and 2000lb capacity. My 2000lb scale is fairly consistent but the measurements on the scale are in 50lb increments. It gets you close, but I do not have a 200lb sway in measurements at the same spot.
2017
Old 04-09-2012, 03:03 PM   #8
dznf0g's Avatar
Oswego , Illinois
Hmmm, I wonder why some of us have this "stickiness" and you don't....any theory? I am aware of the "don't lift by the plunger" rule and am confident there is no air in the unit. Last year I even pulled the gauge and checked for air. (not hard to do, BTW). I wonder if fluid amount has anything to do with it...ie...plunger too high in bore and cocking?????
I have the 2000# scale as well.
-Rich-
Old 04-09-2012, 06:38 PM   #9
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
I found if the trailer isn't *perfectly* level, I can get very disparate readings.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 04-09-2012, 10:15 PM   #10
dznf0g's Avatar
Oswego , Illinois
That's not what I'am talking about. Level, I mean. It's about varing readings at level.
-Rich-
Old 04-10-2012, 05:55 AM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I also use the 2000lb Surline.
I step on the tongue directly above the scale and compare reading with my known weight, note that it returns to previous reading. (usually with-in 50lbs), which I think is acceptable. The needle has always returned to zero with-in the brackets.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 04-10-2012, 04:01 PM   #12
Cracker's Avatar
Pittsfield , Maine
The only thing that comes to mind for me Bob is that the rounded top of the Sherline is designed to fit the contours of the female part of the coupler - i.e. - match the ball contour. If it's off center just a bit at the top, inside the coupler - or if the Sherline is not perfectly vertical - or if the trailer drifts slightly in any direction when you lower it onto the scale, it could cause a slight bind in the scale piston - which would probably not happen with a conventional mechanical scale or load cell. Also, the inside top of the coupler could be fairly loaded with trash, since the top of most balls are flat and not in contact with the female part of the coupler at the top - and that's exactly where the Sherline bears!Those factors could cause a variation in the reading as you rock the trailer. I've always just settled on an average reading! A simple swivel ball and bearing pad on top of the Sherline would probably eliminate most of the accuracy problem - but the additional machining would probably double its' cost.
Cracker
Cracker is offline   Reply With Quote
Old 04-11-2012, 05:45 AM   #13
"The only thing that comes to mind for me Bob is that the rounded top of the Sherline is designed to fit the contours of the female part of the coupler - i.e. - match the ball contour. If it's off center just a bit at the top, inside the coupler - or if the Sherline is not perfectly vertical - or if the trailer drifts slightly in any direction when you lower it onto the scale, it could cause a slight bind in the scale piston"
Cracker,
I've abandoned the use of the screw in extension since getting the Arrow.
The concave scale pad stays put very well, I lower the trailer on the scale using the tongue jack and compensate for the difference in the pivot point. It's also much easier keeping everything plumb.
The Shurline is most useful when a visit to the Cat's indicate a difference in loading, usually a lot lighter when not boondocking.
W. H. Auden
Amanamus
"Tahawus"
Old 04-11-2012, 03:12 PM   #14
Cracker's Avatar
Pittsfield , Maine
One of the problems with using the Sherline at the ball is getting a proper height stack under the scale to support it. If you remove the extension and use the scale at the jack, what measurement point do you use to calculate the load at the ball with a dual or triple axle trailer - the center of the axle group???
Cracker
