Old 01-24-2015, 10:32 AM   #1
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Show Your Tire & Load Info (Payload) Label
Take a photo of your load label on your drivers door and post it with your vehicle make and model, 4x4 or 2x4, trim level engine size and GVWR Include Airstream model and year.
I'll start with mine
2010 Toyota Tundra 5.7L Double Cab 2x4 SR5 GVWR 6900
2008 Airstream Classic 25fb
Kelvin
Old 01-24-2015, 10:46 AM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
2014 GMC Sierra 1500 SLT MaxTow 5.3L (gas) Crew Cab 4X4 3.73 AR GCWR 7576 kg
2009 Airstream Flying Cloud 23FB
Name:	2015-01-24 10.38.55.jpg
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 01-24-2015, 11:19 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
2006 Suburban 2500 LT trim, 8.1 Autoride,(electronic shocks,w/o auto leveling). 4X4
Tire up-grade...Michelin LT 265/75R16 load E
Old 01-24-2015, 12:07 PM   #4
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I can't get a decent picture of the tag on my truck yet, but here's the info for my 1995 Ford F250 Extended Cab 2WD PowerStroke with the E4OD transmission, 155" wheelbase, 4.10 rear end:
Build date 09/94
GVWR 8800
Front GAWR 3965
Rear GAWR 6084
Tires LT235/85R16E 16x7 rims
Front 55 psi Rear 80 psi
GCWR 20,000
From the Towing Specs: Max trailer weight 10,000. 12,000 with wt. dist.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 02-09-2015, 06:52 AM   #5
1965 mustang's Avatar
Stoughton , Wisconsin
This is my 2011 Tundra.
Name:	ImageUploadedByAirstream Forums1423489825.001347.jpg
1965 mustang is offline   Reply With Quote
Old 02-09-2015, 06:58 AM   #6
This is my 2005 Tundra double cab. They adopted the new standard in 2011. I'm not changing my TT so I'm worried. The new truck has bigger everything.
Name:	ImageUploadedByAirstream Forums1423490050.334173.jpg
Old 02-09-2015, 11:16 AM   #7
Question
No axle ratings?
See my sticker above.... GAWR. Frt & rear
Is there a separate sticker....glove box maybe?
Old 02-09-2015, 11:18 AM   #8
dznf0g's Avatar
Oswego , Illinois
Bob, More and more, they are becoming separate labels.
-Rich-
Old 02-10-2015, 07:01 AM   #9
Here is my 2011 Tundra. My 05 isn't here right now, I'll post that later.
Name:	ImageUploadedByAirstream Forums1423576744.769180.jpg
Old 02-10-2015, 07:02 AM   #10
I also found this.😞
Name:	ImageUploadedByAirstream Forums1423576908.847632.jpg
Old 02-10-2015, 04:40 PM   #11
Both trucks are SR5 4x4 double cab.We pull a 2005 safari 25' ab. The 05 pulled it pretty good but struggled a little on steep grades. I'm hoping the 2011 with the 5.7 will do a little better.
Old 02-11-2015, 08:03 AM   #12
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Your GVWR is slightly higher than my 2010 DC 2wd SR5 6900lbs. I don't have the 275 sized tires but 255/70x18. I wonder if the tire size is the only reason your GVWR is 200lbs more? But your payload is slightly less due to the weight of the 4x4 components.
I used to have the 4.7L V8 in my 2005 4Runner towing a 17' Casita (3500lbs) and it would slow down on the longer grades. Being only a 5 speed transmission I would have to shift to 3rd to maintain 55-60mph on longer grades out west. I noticed this on the climbs between Sheridan, Wy to Billings, MT. The diesel's pulling 5th wheels blew past me like I was standing still.
I haven't had an opportunity to tow my 2x heavier 2008 25fb out west yet. I'll be heading out this June. I'm sure 3rd gear will have to be used to pull my 7000lbs up some of the anticipated grades.
Kelvin
Old 02-12-2015, 09:10 AM   #13
dznf0g's Avatar
Oswego , Illinois
Name:	2015 Sierra.jpg
2015 GMC Sierra SLT - Non-MaxTow, double cab, 6.2L, 8 speed, All Terrain Pagkage
-Rich-
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Tire pressure label conflict Bambi75th Tires 15 07-30-2008 09:13 PM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
what's your favorite airstream WARNING label? 2airishuman Off Topic Forum 39 03-27-2008 07:23 PM
