Old 05-30-2012, 08:29 PM   #1
wildwoodrver's Avatar
2012 30' International
Pleasant Hill , The Golden State
Shift weight to tow vehicle with Hensley
I've got to shift a few hundred pounds onto my Yukon from the Airstream. What adjustments to the Hensley Arrow will accomplish this?
Thanks.
2012 International Serenity, 30
Reese Trunnion Weight Dist. Hitch
2005 GMC Yukon XL, Tekonsha P3
Reese Tow Beast hitch
Quadrasteer - Autoride
wildwoodrver is offline   Reply With Quote
Old 05-30-2012, 08:40 PM   #2
dznf0g's Avatar
Oswego , Illinois
What process have you used to determine your weight needs? The answer is to crank down (pull up) the jacks, but that may not be the appropriate answer here, without knowing all the weights and heights involved with a proper setup. Do you have more info to share?
-Rich-
Old 05-30-2012, 08:55 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
When setting up a WD hitch the object is not to just shift a given amount of weight from the trailer to the TV. It is rather to transfer some weight that would normally be carried by the rear axle to the front axle. The amount is a function of the tongue weight of the trailer and the spring system of the TV.
What you are attempting to accomplish is to at least return the weight to the front axle that the trailer reduced by the cantilevering effect of have applied the trailer weight behind the rear axle. This insures the steering system is in a normal configuration and improve sway control that would be reduced by the reduced weight on the front axle.
I generally look for a 60/40 ratio of compression on the rear and front axle as measured to the fender wells of each axle. Place masking tape on each fender and measure the height straight down through the center of the wheel. Mark a line on the tape and hook up and remeasure. Make adjustment to your WD system until you have the relationship you are after.
2004 Excursion 4x4
Old 06-01-2012, 09:12 PM   #4
The rig has always towed and handled fine. With the addition of four AGM batteries for the solar package, i now weigh 3,600 #, perfectly divided 1,800 left and right on my 3,000 GAWR axle. I would like to shift as much of the 600# to the tow vehicle as I can.
Is it just a matter of lifting the Hensley spring bars ?
I don't want to spend the $ on weighing again until I'm pretty sure I've shifted the weight and also accomplished weight shift to the steering axle (in another thread)
Thanks.
Old 06-01-2012, 09:17 PM   #5
I'm afraid the automatic level control on the Yukon will mess up the measurements you suggest.
Thanks.
Old 06-01-2012, 09:19 PM   #6
dznf0g's Avatar
Oswego , Illinois
Thanks.
Not if you remove the fuse. I just got out of an Escalade EXT. I hitched per my instructions in the other thread on that one as well as a Yukon XL Denali in the spring of '11.
-Rich-
Old 06-01-2012, 11:59 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The idea of shifting weight to lighten the trailer is not the purpose of weight distribution bars. It is to equalize the tongue weight put on the hitch, among the tow vehicle and trailer axles so that the front of the truck is not too light for safe handling, and the back of the truck is not overloaded.
It is quite possible and dangerous to lift the bars enough so the tow vehicle rear axle is too light for adequate traction. In theory the tow vehicle rear axle could be lifted off the ground with the weight distribution bars. Yikes!
No weight distribution adjustments should be made without measurement of the tow vehicle front and rear fender height to ensure they have been moved equally. Or more accurately, using weight scales to equalize weight distribution.
doug k
Old 06-02-2012, 12:53 AM   #8
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
I once saw a picture of a late 60's Toranado towing with a WD hitch with no back wheels on the car. I believe it was on this forum but I can't find the thread. The weight had been shifted so drastically that the trailer and the front drive vehicle wheels were the only wheels on the ground.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 06-02-2012, 04:34 AM   #9
Airstreamer67's Avatar
It seems that picture was from a hitch manufacturer's ad demonstrating the effect of weight (re)distribution.
Airstreamer67 is offline   Reply With Quote
Old 06-02-2012, 06:45 AM   #10
HowieE's Avatar
Images: 12
Dan
Yes that picture was an ad using a Oldsmobile Tornado. It was just that an AD and did not represent anything that could be repeated on the road.
You have misunderstood the function of a WD hitch. They are as stated above only to used to return some of the tongue weight to the steering axle. Keep in mind in doing that a WD hitch INCREASES the weight on the trailer axles also. Yes the tongue weight is split by reducing the rear axle weight between th front axle of the truck and the trailer axles. That ratio will be a function of the distances between the hitch and those axles.
The only way to reduce the weight on the trailer axles is to lighten the trailer.
2004 Excursion 4x4
Old 06-02-2012, 07:17 AM   #11
dznf0g's Avatar
Oswego , Illinois
In fact, the OP's owner manual states that the rear fender height should be the same after WD as before hitching up. I DISAGREE WITH THIS. IMO, the front and rear fender height should be reduced by equal amounts after WD setup (in a perfect world). If I were to hitch up my 950# TW AS and have the same rear fender height after WD, I would have far too much weight on the front axle of the TV and not enough on the rear Axle.
On a 1/2 ton, with loaded AS and TV, I get about 1" "settling" on the rear fender height and about 3/4" on the front, verified by scale readings. (as a general rule)
-Rich-
Old 06-02-2012, 08:01 AM   #12
dkottum's Avatar
Surprised Hensley would have you adjust fender heights that way. That's wrong because it suggests all the weight shifted forward should go to the front of the tow vehicle. That could leave the back of a pickup dangerously light.
doug k
Old 06-02-2012, 08:24 AM   #13
SteveH's Avatar
Common Sense , Texas
The owner's manual for my GM pickup states to adjust the WD bars to return the front end of the vehicle to the same height it was before hitching up the trailer. This means moving the tongue weight from the ball to directly over the rear axle. I've had good success with this adjustment procedure, and if you think about it, that's exactly how a truck is designed to carry it's load.
I'm talking about a truck here, and not a minivan, or a sedan, or a sports car, or any other goofy thing some people decide to tow with.
I suggest you check your vehicle's owner's manual.
Old 06-02-2012, 08:36 AM   #14
HowieE's Avatar
Images: 12
There is no single answer as to how to adjust a WD hitch. It is a function of the spring rate of the TV. The important consideration is to maintain the steering geometry of the front axle. Too little or too much transferred to the front axle will cause problems. Too little equals a lose of steering control. Too much will cause tire problems.
I generally try for a 60/40 ratio in depression of the fender heights. This will change depending on the springs of the TV.
2004 Excursion 4x4
