Old 05-28-2017, 10:28 AM   #1
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Sharp Turns
A simple question, is there a hitch/trailer clearance problem towing an Airstream on a sharp turn such as a U-turn and if so how do you handle it? Thank you.
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 05-28-2017, 10:36 AM   #2
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
It's very possible to jack knife. If it's going to be close use an outside observer.
Cheers,
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 05-28-2017, 11:02 AM   #3
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Whew! that's close.
Excellent point to bring up as some ended up seriously creasing their AS on tight turns.
In afterthought, we realized could have done the same. We were very lucky due our specific protrusion of the hitch assembly to ball.
Under controlled circumstances, practiced very carefull slow but sharp turn radius tests while sweetheart was on radio observing. Overall, barely an inch of clearance on the tightest turns.
Don't think we could have lucked out more if we tried or a different bumper !
ID:	286363   Click image for larger version
Vantair is offline   Reply With Quote
Old 05-28-2017, 11:12 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Slow and easy in tight spots and don't be afraid to stop, get out and look as many times as it takes.
MICHAEL
Old 05-28-2017, 11:33 AM   #5
Airstreamer In Training
FCStreamer's Avatar
2014 30' Flying Cloud
Yes, when backing up there is such a thing as too sharp of a turn.
http://www.ourflyingcloud.com/2016/1...lesson-52.html
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2013 Cadillac Escalade Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-28-2017, 11:43 AM   #6
Thanks for the quick response. I would like to clarify that I am inquiring about turns while moving forward. It seems some of the new tow vehicles can are capable of a very small turning radius and I'm wondering if this is becoming a potential problem while towing. Again thanks for the response.
Cheers, Dan
Old 05-28-2017, 11:52 AM   #7
Mollysdad's Avatar
Every trailer has it's limit. I'd recommend taking the unit to a vacant parking lot and getting a feel for how close you can get. I know with my former MH, the backup camera was a great help. My Tundra's BU camera is very, very wide angle, but it's no help going forward. (only works in reverse)
The bottom line is, there will come a time when you can't just turn. I remember driving 20 miles out of my way to find a suitable spot to turn around once out west. It's just part of the adventure.
Forget about U-turns unless you have a football field to do it in.
Condition yourself to analyze gas stations before pulling in. That pump facing the convenience store looks great until someone parks in front of the store and now your radius is too small. Pumps parallel to the store are better.
Old 05-28-2017, 12:15 PM   #8
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
A follow up question if you will:
If your TV's turning circle will mean that contact can be made between TV and trailer, what can be done to mitigate this? Can some sort of stop be added to your steering rack, bump stop on your suspension, increased length of hitch extention with ball; or add length to the trailers hitch?
What would you do and why?, or why not?
Cheers
Tony
Old 05-28-2017, 12:26 PM   #9
Llando88's Avatar
2016 30' Flying Cloud
Very good advice above in the thread.
Maybe mine is different due to the ProPride (longer?) and truck (2500) but I've not noticed any issues in turning where the truck and trailers are at right angles.
Not that I make a habit; I understand it is hard on the TT tires.
I've done it once at a gas station in LA; I had to back up 15', then make a large U turn. My wife was outside with the radios marshaling me as I did it. Also, I went very slow, and stepped out once to check clearance.
But yeah, you get to quickly 'size up' a gas station, and react accordingly. I will say it's a bit surprising how many stations I've fit in to. Given I'm only 8'6" wide, 52' overall, but I bend in the middle, it's usually not a problem.
These days I look in Google Maps in the morning to check out fuel options using Satellite view. I typically have a Plan A and a Plan B, if we are doing any drive over 300 miles, for the mid-day fuel stop.
Only thing I really can't predict is unusual elevation changes or very sharp bumps or dips in the road. I have dragged the rear bumper a couple times going into some pumps. Judging by the ruts, I'm not the only one.
Rich
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 05-28-2017, 12:40 PM   #10
Mollysdad's Avatar
I wouldn't do any of those. First, your TV will be often used when not coupled to the trailer, so I wouldn't reduce it's turning radius.
A hitch extension solves one problem but creates another, now your WD hitch is changing the "lift" geometry and stresses the receiver more.
The best solution is to install a back up camera so you can see your hitch. But don't make this more than it's worth. In all my years of RVing, I've never dented the TV or the Trailer. Scared myself a few times. Especially when tired.
You'll get the feel of turing radius, and if there's any doubt, get out and look or don't do it. (forget about making a U-turn on a 6 lane highway.)
Old 10-12-2017, 10:11 AM   #11
2017 27' Flying Cloud
Fort Worth , Texas
Just dented new AS
Wish I found this thread earlier. We took a wrong turn down a narrow road with very few places to turn around. I pulled into a driveway and we were greeted by 3 dogs who looked rather hungry preventing wife from exiting vehicle. I had to turn tightly while backing up and the rear light on my Tundra hit the front panel of the airstream denting the protective panel and scratching/denting the panel underneath. It also broke my tail light!
Depressed!
billrector is offline   Reply With Quote
Old 10-12-2017, 11:15 AM   #12
Johnco's Avatar
2006 19' Safari
Anaheim , California
Yep, early rookie mistake with turning while backing up a steep driveway. Decided camouflage was the least expensive way to go!
ID:	296819   Click image for larger version
Johnco is offline   Reply With Quote
Stressing tires with sharp turns John&Vicki Tires 19 07-06-2016 12:35 PM
Bottom drawers coming out in sharp turns Millionsaver Sprinter and B-van Forum 29 03-25-2016 05:22 AM
Sharp Turns: Blowout Cause? John&Vicki Tires 39 07-09-2015 09:41 PM
Key Turns and Turns..is this normal? help shiny1973 Doors & Locks 10 11-25-2008 05:57 AM
