Old 06-29-2014, 07:22 AM   #1
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Thumbs up Share Your Real World Tongue Weights & Trailer Weights
Originally Posted by switz View Post
When I showed up at the dealership to tow our new 2013 25FB International Serenity home, the factory literature tongue weight of 833 pounds was actually 1,150 pounds on my Shureline scale. That was a basically empty trailer with a single solar panel on the roof and street side and rear awning options with a Hensley hitch head attached.
After getting the unit home and loaded for camping, the tongue increased to 1,175 and about 6,900 pounds trailer weight unhitched.
Originally Posted by m.hony View Post
Cat scales ticket ready to camp-
Still don't know the tongue weight or truck and trailer weights unhitched, but i am with all known limits- front GVW, rear GVW, Payload, Towing Capacity- so I am thinking I am within the limit on tongue weight as well. I am guessing the trailer weighs about 8,400# with a 900-1,000# tongue weight.
After all the discussion in the multiple Tow Vehicle threads, and seeing some folks who post this kind of detailed information, and others with cat scale numbers, I thought that a thread where folks shared their trailer model and their real world hitch weights and trailer weights could be beneficial to new members/owners shopping for both Airstreams & Tow Vehicles. I know it's been helpful to myself for my own research.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 06-29-2014, 07:43 AM   #2
SteveH's Avatar
Common Sense , Texas
We are traveling now so can't post the scale ticket but the tongue weight on ours is 1150 with trailer axle weight of 8950. Our combined gross weight is just under 19,000.
Regards,
Steve
Old 06-29-2014, 08:50 AM   #3
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
Good idea! But people should include their rig description in the post.
I have a 1998 safari SS, 25',
6000 lb including a 600 lb thong
Envoy de mon iPhone l'aide de Airstream Forums
1998 Safari 25' SS
2015 Toyota Sequoia Limited
Buck944 is offline   Reply With Quote
Old 06-29-2014, 09:22 AM   #4
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Here you go. My rig, F-150 Larriott 6.2 gasser 145" Super Crew. In January when everything was camp loaded full including water, fuel, propane and about half a grey water tank. Tongue weight (1200 LBS) taken on Shurline without weight distribution connected.
ID:	215133   Click image for larger version
Annette
AirHeadsRus is offline   Reply With Quote
Old 06-29-2014, 05:42 PM   #5
Nomadic , USA
Good stuff so far guys! Hopefully others will share as well.
Old 06-29-2014, 07:04 PM   #6
andreasduess's Avatar
1984 34' International
Toronto , Ontario
1984 34' International. 7500lbs camp ready (factory 6250lbs) with a tongue weight of just under 800lbs. As far as I know this is the lightest 34' model Airstream has ever made.
andreasduess is offline   Reply With Quote
Old 06-29-2014, 07:13 PM   #7
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I checked the tongue weight of my 2000 19' Bambi in my driveway, using the bathroom scale and lever method. With full water and LP tanks, it came in right at 500#, just as stated in the specs. Keep in mind that the early reintroduced Bambis have a single battery. I was surprised that it was that heavy - hardly moves the Sprinter when attached.
I don't have actual trailer weight
robert claus is offline   Reply With Quote
Old 06-30-2014, 06:10 AM   #8
N/A , N/A
Unimportant detail: the 1983 34 ft Excella's have 5800# and 5500# factory weight in rear-bath and center-bath configurations and are the lightest 34 ft ever built.
rostam is offline   Reply With Quote
Old 06-30-2014, 06:46 AM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
2000 Safari SS (Six Sleeper = floor plan C)
Tongue weight ranges 580 empty to 675 loaded heavy (I've weighed it 4 times)
The trailer has 6300 GVWR.
It's 5800 to 6,000 when loaded to camp, including 20+/- gal of fresh water.
It tows well with a 1/2 ton PU.
Hope someone post weights of their 99 34' Excella. I have not been to the scales with mine yet.
add edit: Tongue weight needs to be adjusted for calculating load on truck. In order to get the actual load on the truck's hitch receiver, I need to add the weight of my hitch and anti-sway bar, 87 lbs, to the tongue weight. When I weigh the truck separately from the trailer, the hitch stayed in the receiver and the anti-sway bar was in the truck bed.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 06-30-2014, 02:46 PM   #10
Nomadic , USA
So the initial tow vehicle that I had owned for years was not really up to the task in terms of exceeding the front axle rating and the GVW of the tow vehicle let alone the trailer's weight.
I researched the 1/2 ton arena including the Eco-Boost and realized that I needed more payload, axle and trailer weight capacity and ended up with the Dodge 3/4 ton diesel. I now have a load in the bed of the truck, a 9,200 pound trailer unhitched weight and a 1,345 pound tongue weight. The numbers all work and there is amble power to pull the mountains with not much effort.
Real scale numbers get posted to the forum and helped me with getting into the proper frame of mind for the tow vehicle decision. Wishful thinking does not overcome the designed engineering limitations.
This sort of thing is encouraging, let's see if we can keep this thread going.
Old 06-30-2014, 03:50 PM   #11
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I started a thread called "Calculating Tongue Weight at the CAT Scales" and through the help of many kind folks here who interpreted my scales tickets and process, we came up with 1080# for my 2012 27FB Flying Cloud with ProPride hitch. This is considerably higher than the published weight in the user manual but is real world fully loaded for camping and with a very heavy hitch system.
Old 07-03-2014, 02:47 PM   #12
Nomadic , USA
Good info Steve
Old 07-03-2014, 04:53 PM   #13
Rollster's Avatar
Saint Augustine , Florida
The actual weight of our 2006 25' was 6460 and the tongue was 960. It was loaded for camping (propane, clothes, some food, dishes, other belongings, etc.).
Carol, Aboard "Aggie the DreamStream"
WBCCI# 5248
Rollster is offline   Reply With Quote
Old 07-03-2014, 05:08 PM   #14
2020 Classic 33 on order
Box Elder , South Dakota
2015 FC 25 Rear Bedroom, Trailer weight 6440 and tongue 1040. 2015 Sierra 2500 Duramax and ProPride.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NVPN
ghaynes755 is offline   Reply With Quote
5.7 Tundra Real World MPG? OldVwHunters Tow Vehicles 117 07-16-2015 09:18 AM
Real World MPG -- Avalanche & Bambi grizzy On The Road... 13 06-15-2011 09:06 AM
Share your favorite roadfood spots 63air On The Road... 56 05-09-2008 10:23 AM
Real Answers for Real A/C questions nbk3ad2 Furnaces, Heaters, Fireplaces & Air Conditioning 10 02-06-2007 08:51 AM
First real trip; real dumb mistake... myoung On The Road... 49 03-29-2006 07:37 PM
